Is TGMO the best oil for our engine?
Discussion in '2nd Gen Tundras (2007-2013)' started by NickG, May 24, 2023.
  1. May 24, 2023 at 5:40 AM
    NickG
    NickG [OP] New Member
    Nick
    2009 Toyota Tundra Limited DC 5.7L
    It’s the only oil that’s been used in my truck and I just want to know if it’s great for longevity and want to know what you all use.
  2. May 24, 2023 at 5:58 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    changing oil @ 5k is great for longevity.
    any Synth oil.
    Toyota oil is just as good as the rest.
    are you buying the toyota oil and putting it in?
    because Toyota dealers don't use toyota oil.
    07 Tundie, Mater, texasrho83 and 2 others like this.
  3. May 24, 2023 at 6:09 AM
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    Have to agree with @nobodyintexas that changing oil on a regular basis, 5k/6k is the key for longevity, or as I do, before and after a long trip, which is usually over 3K and I am driving it hard during that time.
    Now, whereas the argument for 0W-20 or any other oil, please check the forum and conform to your location as it is not listed in your bio, but for me, I went 5W-30 cause we are in hell and 0W-20 to me was a tad too thin.
    Mike59 likes this.
  4. May 24, 2023 at 6:18 AM
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I would bet that a person could use the cheapest synthetic oil they could find and as long as it was changed regularly the truck would last a lifetime without an issue. I like to help the odds a bit and use Kirkland brand synthetic in 5W-30.
    nobodyintexas likes this.
  5. May 24, 2023 at 6:27 AM
    Ghost Rider
    Ian
    Cypress, Texas
    Hehe..... Last time Costco had those big jugs on sales, I think I hurled 6 boxes home?
    I have a friend also uses 5W-30 on his Taco and 7 other cars, I will also be switch Mrs. Pilot to 5W-30 once I use up my 0W-20 stock, which I think I just did but need to check there's not another bottle lying around that crap in the garage.
  6. May 24, 2023 at 6:28 AM
    Oil doesn’t know what brand it is :anonymous:
  7. May 24, 2023 at 8:19 AM
    NickG
    Nick
    The dealer in my area uses it. If I ever go anywhere else I order the oil and oem filter myself
    nobodyintexas[QUOTED] likes this.
  8. May 24, 2023 at 8:21 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    I'm sure amsoil does :rofl:
    coldcanuk, ATV25 and AZBoatHauler like this.
  9. May 24, 2023 at 9:29 AM
    IowaGuy
    IowaGuy New Member
    In Process
    I have smart oil because it is what engines crave.
    NDTundra18 and hagrid like this.
  10. May 24, 2023 at 10:19 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Specifically it’s Mobil Super Synthetic with a custom additive pack (though that could have changed at any time if Toyota wanted to update the formula)
    ryanwgregg likes this.
  11. May 24, 2023 at 10:21 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    <flushing out the Amsoil boys>
    can't we say the same about Amsoil?
    decent base stocks come from maybe 3 suppliers?
    coldcanuk and ryanwgregg like this.
  12. May 24, 2023 at 10:27 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    :spy:
  13. May 24, 2023 at 6:45 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Ok, I will play, generally i don't care about oil threads as I use mobil 1 in my truck and kendall or valvoline in my camry. This is coming from my uncle who was an master mechanic on fords for 27 years. If there was ever a company that needed mechanics, that would be FORD !!!!! They all break, but FORD kept my uncle gainfully employed.
  14. May 24, 2023 at 7:24 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    They don’t even use specd transmission fluid, either. At least not all Toyota service departments
  15. May 24, 2023 at 8:42 PM
    737fixer
    737fixer New Member
    Toyota's oil is fine. I mean it's just Mobil 1 with a few additives. Please don't think these additives are some special super Toyota secret cause they are not. My only concern is when you say that TGMO is the only oil ever used in your truck I assume your stating you have done all your own oil changes and purchased the oil form a dealer. If you are saying that the reason TGMO is in your truck is because only the dealer has changed your oil then I am sorry to break the news to you that NO Toyota dealer on the planet is using Toyota branded oil. They put in whatever cheap 55 gallon drum of synthetic they can get their hands on that meets the absolute minimal criteria.
  16. May 30, 2023 at 7:27 AM
    NickG
    Nick
    Should I use 5w20 year round? I just read how good Mobil 1 advanced full synthetic 5w20 is. I feel like my truck would be quieter if I use the 5 weight oil. It always sounds like a diesel when I first start it up in the morning with 0w20.
  17. May 30, 2023 at 7:28 AM
    NickG
    Nick
    upload_2023-5-30_10-28-44.jpgThis oil
  18. May 30, 2023 at 7:29 AM
    NickG
    Nick
    As long as it has good cold flow I don’t mind using it.
  19. May 30, 2023 at 7:36 AM
    PermaFrostTRD
    Northern NY
    Where are you located (in the country)? I'd say if you spend any amount of time where there is snow on the ground, 0W-20 would be better for those months, then swap it in the spring/summer for the 5W-20, to improve the Toyota tick. (Some in the warmer climates have run 5W-30 here without issue - with only a handful claiming 5W-30 completely eliminating the tick noise).
    NickG[QUOTED][OP] likes this.
  20. May 30, 2023 at 7:40 AM
    NickG
    Nick
    I live in Georgia. We get a pretty fair amount of everything
  21. May 30, 2023 at 8:12 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    Yes, but then it's the add packs they put in.
    I'm running HPL 5W20 No VII and so far the truck is loving it. Possibly experimenting with extending the OCI as they have been able to get over 15k miles on the same oil. TBN's come back good with just a filter swap at 5k.
    stevesgraytundra likes this.
  22. May 30, 2023 at 8:16 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Is HPL still ~$15 a quart?
  23. May 30, 2023 at 8:27 AM
    SnrDisregardo
    Wade
    IL
    Depends on which product you decide on, but if you get comfortable at extending out your OCI, even to 10k miles, it brings it back in line with the off the shelf oils, IMO. Seeing how they do things and what they use, I'm confident that I could go 10k or 15k on the oil with doing filter changes at 5k intervals.
  24. May 30, 2023 at 8:40 AM
    stevesgraytundra
    stevesgraytundra New Member
    Stephen
    2021 MGM SR5 CM 4x4
    Seeing what people spend money on, I’m happy to “overspend” on engine oil. Just bought four gallons of HPL’s premium plus 5w30 PCMO.
  25. May 30, 2023 at 8:49 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I ran some Penz Ultra Plat 5w-30 last change.
    I got the same results from Blackstone as my Kirkland 5w-30...except Kirkland lacked Moly.
    so you still push a decent TBN after 10k miles? 15k miles?
  26. May 30, 2023 at 8:53 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    the best oil is clean oil (and filter) changed at 5k miles or 6 months.
  27. May 30, 2023 at 8:57 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    This.
    I'd much rather spend the extra $ on 5k changes.
    Kirklands is my go to. still has strong TBN after 5k. even with an 8psi blower.
    to each his own.:thumbsup:
  28. May 30, 2023 at 9:03 AM
    MadMaxCanon
    Project farm tested the kirkland oil and it was pretty dang close to mobil 1 and its much cheaper. I have a bunch of mobil 1 from the last time costco had a sale but when i run out, I will most likely go with the kirkland. I usually go 6 months because i dont drive a whole lot, I think this last oil change i did at 6 months, i only did like 3700 miles but the oil definitely needed to be changed. I dont burn a single drop of oil either.
  29. May 30, 2023 at 9:03 AM
    SnrDisregardo
    Wade
    IL
    I can't say too much, but I've seen the TBN's come back well above with that many miles where the standard is at for most new oils.
  30. May 30, 2023 at 3:52 PM
    stevesgraytundra
    Stephen
    2021 MGM SR5 CM 4x4
    I haven’t run it yet. I’m only 2,000 into my most recent 5w30 Valvoline EP. I plan to go 5k-6k OCIs even with the HPL. I want to get 500,000+ miles from my truck since Toyota will never make one like it again.
