Is replacing a water pump labor intensive?
Discussion in '2nd Gen Tundras (2007-2013)' started by alexusw, Jul 18, 2022.
  1. Jul 18, 2022 at 5:18 PM
    alexusw
    alexusw [OP] New Member
    2007 Desert Sand Mica Tundra LTD
    Why is replacing a water pump so expensive at the dealer? I was quoted close to $1K just to get it replaced. It’s leaking for the second time.
  2. Jul 18, 2022 at 5:37 PM
    Mr Badwrench
    Mr Badwrench New Member
    If they are anything like the 2018 5.7 liter, it is probably all labor. It looks like surgery to replace it.
    Do you have a warranty of any kind on the one you had replaced? They probably won't cover labor, but it may help.
  3. Jul 19, 2022 at 7:43 AM
    Jaymohn moto
    Jaymohn moto New Member
    Not too difficult. Just takes some patience and about 4 hours.
    baraynavab likes this.
  4. Jul 19, 2022 at 10:54 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  5. Jul 19, 2022 at 10:56 AM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Is it pumping the water?
  6. Jul 19, 2022 at 11:39 AM
    AZBoatHauler
    So.Arizona
    My thoughts - it’s 2022 - $1,000 for a dealership install of a new major component shouldn’t be a surprise. Some charge almost $200 for an oil change that costs $15 and takes 12 minutes.
    Sounds like you’re getting 8 years out of the water pumps - while it would be nice to last longer I don’t think you can expect much more then 8-10 years out of these parts. Did you use OEM or aftermarket when you replaced the first one?
    If I were you, I’d go ahead and replace the radiator, hoses, and thermostat while I’m at it and call the cooling system good for another 8-10 years.
