Is our 3.4 V6 TT overstressed?
Discussion in '3rd Gen Tundras (2022+)' started by Jettster, Jun 13, 2024.
  1. Jun 13, 2024 at 12:47 PM
    Jettster
    Jettster [OP] New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    There seems to be a small but growing consensus that 389 hp and 479 tq under 15-16 lbs of boost is too much for power for Toyota like longevity. My question is compared to what? The Ford Ecoboost can make 400 hp from 3.5 liters and the HO version of Ram's 3.0 Hurricane straight six TT is 540 hp. I can't see why Toyota seems to have screwed the pooch here. How long is that Hurricane going to blow under towing or high loads? yet to be seen. Ford Ecoboost engines generally go @ 100k on original turbos but maybe 50k on cam phasers. Never seen one just blow up...Might be the reason we haven't seen the TRD Performance package emerge yet...
  2. Jun 13, 2024 at 12:55 PM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    You're saying that most people, the consensus, think the V35 is too stressed?
  3. Jun 13, 2024 at 1:02 PM
    Jettster
    for Toyota like longevity...like my 2003 3.4 Taco with 259k or my 99 Land Cruiser with 138k or my 95 Land Cruiser with 262k...or SC300 with 167k none tap smoke or burn oil...much less spinning the front main bearing
    Terndrerrr and Toyotoholic like this.
  4. Jun 13, 2024 at 1:06 PM
    BoulderGT3
    Glen
    But your thesis is that the majority of people think the V35 is overstressed?
  5. Jun 13, 2024 at 1:10 PM
    Jettster
    yes based on all the commentary and the only failure point seems to be the front main bearing...machining debris...bullshit
    IsaiahCanada likes this.
  6. Jun 13, 2024 at 1:13 PM
    BoulderGT3
    Glen
    No, I don’t think the majority of people think it’s over stressed. I’m sure some do but to say consensus is a reach.
    raylo and wxman91 like this.
  7. Jun 13, 2024 at 1:13 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I think he means that the V35 is not built to go the distance such as the proven track record of his own mini fleet of Toyota/Lexus vehicles. If the V35 is built to go 100k. Then something must be stressing the motor to ONLY last 100k (comparatively to Ford/Ram) where you're lucky to even get to 100k
    Black Wolf and Jettster[OP] like this.
  8. Jun 13, 2024 at 1:27 PM
    reded301
    reded301 New Member
    2022 SR5 CM 5.5
    Westcott level TRD Wheels 35” Kenda Klever
    I don’t think the engine is, but some of the members on this board are absolutely overstressed…
  9. Jun 13, 2024 at 1:34 PM
    wxman91
    wxman91 New Engine Enthusiast
    Montana
    2022 TRD Sport 4x4 Army Green / 2021 4Runner Limited
    CBI Baja Bumper / BD S2s Falken Wildpeak AT3W 315/70R17 Method 316s TRD Pro Fox Suspension w/Total Chaos UCAs TRD Dual Tip Exhaust TRD CV Axles TRD Pro Flares + Heritage Grille Alpharex Headlights Dobinson Coils RCI Skid
    I think it's built to handle even more power. Unfortunately the building process has been the limiting factor.
  10. Jun 13, 2024 at 1:39 PM
    mmasse
    mmasse Digital Forensics Cowboy
    Idaho
    2022 Magnetic Grey Tundra
    People tend to report rumors, speculations, and projections as facts. Why not let the facts and truths speak for themselves instead of throwing another log on the hysteria fire?
    BoulderGT3 and raylo like this.
  11. Jun 13, 2024 at 1:42 PM
    Lexus LS 500 3.4 416hp/442tq on a 4700 lb car.
  12. Jun 13, 2024 at 1:44 PM
    Jesus...
  13. Jun 13, 2024 at 1:58 PM
    raylo
    raylo not so new member
    Frederick, MD
    Don't forget Mary and Joseph!
  14. Jun 13, 2024 at 2:00 PM
    Hell Fire!
  15. Jun 13, 2024 at 2:01 PM
    raylo
    Frederick, MD
    Smells like melting and burnt tires!
  16. Jun 13, 2024 at 2:06 PM
    Needs more main bearings.
  17. Jun 13, 2024 at 2:18 PM
    And that’s a legit post. It’s has fewer main bearings to spread the load than other engine configurations and designs.
  18. Jun 13, 2024 at 2:23 PM
    I wondered what the difference was. This whole issue is very confounding. I hope their tooling was properly calibrated....:anonymous:
  19. Jun 13, 2024 at 2:36 PM
    blanchard7684
    blanchard7684 New Member
    The new Nissan twin turbo v6 in the qx 80 will top 500 ft-lbs and have 450 hp.
    I wonder when oems will have to start using tilt pad bearings.
  20. Jun 13, 2024 at 2:37 PM
    BoulderGT3
    Glen
    Asked earlier in the thread that was closed. Are you a Six Sigma Black Belt?
  21. Jun 13, 2024 at 2:39 PM
    That being said, the Nissan VR series (Godzilla GT-R) has the same number and makes gobs of power without eating itself.
  22. Jun 13, 2024 at 2:46 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    The truth will come out eventually, if it’s thru Toyota or someone that does not like their explanation (whistle blower).
    Right now everyone has heard what they have said to date and no one should question that until found out otherwise!! We have no reason or foundation to think otherwise because no one has stepped forward with any other first hand knowledge!
    And I’ll close with my usual!,,, I hope they do something before someone gets seriously hurt!!
    ChucklesToy, raylo and BoulderGT3 like this.
  23. Jun 13, 2024 at 2:46 PM
    Clockwatcher68
    Clockwatcher68 New Member
    23 MGM Tundra TRD Offroad
    I keep a half dozen main bearings tucked away in my non-hybrid rear seat storage. Problem solved.
  24. Jun 13, 2024 at 2:50 PM
    raylo
    Frederick, MD
    But fewer does not necessarily mean not enough.
    BoulderGT3 likes this.
  25. Jun 13, 2024 at 2:56 PM
    blanchard7684
    Used to be. Quit the industry. Went to another industry. My certs were for black belt and done via company resources ( which is fairly typical) This is different for being a cssbb ( certified six sigma black belt).
    BoulderGT3[QUOTED] likes this.
  26. Jun 13, 2024 at 2:56 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Same engine in the LX 600 is tuned for more HP if memory serves correct. **edit** yes, 409HP.
    Hadn't heard of any issues with those vehicles, but I'm sure they have low production numbers.
  27. Jun 13, 2024 at 3:09 PM
    Post was partly in jest, wish it was an Inline 6 configuration instead of a V. Second coming of the JZ series. And inlines are so smooth.
    4genRunner and raylo[QUOTED] like this.
  28. Jun 13, 2024 at 3:55 PM
    SD Surfer
    Bruce
    So Cal
    IIRC, didn't they have problems with the GT-R early on 'cuz they launch so hard they were twisting drive shafts? Freaking monsters!
    KNABORES[QUOTED] likes this.
  29. Jun 13, 2024 at 4:22 PM
    reded301
    reded301 New Member
    2022 SR5 CM 5.5
    Agreed, should have gone the direction of Stellantis, even though I’m not a fan of most anything Chrysler related. It’s not like they didn’t have room, the hood’s long enough to cover a straight 8.
    4genRunner likes this.
  30. Jun 13, 2024 at 4:31 PM
    It’s gotta fit in everything though, not just the Tundra
