Is my 2018 shifting normally?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mr_Ed, Nov 14, 2021.
  1. Nov 14, 2021 at 12:25 PM
    Mr_Ed
    Mr_Ed [OP] New Member
    Ed
    2018 Limited 5.7
    None
    I've never had an automatic anything that acts like my 2018 Limited 5.7 liter. But, then, I've never had one later than a 2013.
    I can be rolling along at 45 mph, the tach at 1200 (or so) rpm, and let off the throttle. It doesn't freewheel at all. It just stays at 1200 rpm and starts slowing. It acts like a standard transmission. Other automatics I've owned will start coasting, or freewheeling, and the engine will drop to near idle. The truck acts sort of like it's in tow/haul mode when it's not.
    Bear in mind that almost all of the 3000 miles I've driven this truck so far have been in tow/haul mode pulling a 6000-pound trailer. Could it just be remembering my driving style and adapting accordingly?
    Mike59 likes this.
  2. Nov 14, 2021 at 12:44 PM
    Retired...finally
    My 21 does the same thing. But wait! it gets even better! Start decending a hill and it downshifts to add engine braking.
    jomikepa and Oey12 like this.
  3. Nov 14, 2021 at 12:51 PM
    Mr_Ed
    Ed
    2018 Limited 5.7
    None
    Bingo! And that's expected behavior in tow/haul, but I've never had one act this way just driving. If it's normal, though, that's OK.
    Thanks for the answer.
  4. Nov 14, 2021 at 12:57 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Both of the Tundras I've owned have been that way, and personally I don't think there's anything wrong with that. Only ever owned one other truck that had an automatic transmission and I think it was the same way.
    Oey12 likes this.
  5. Nov 14, 2021 at 1:05 PM
    Mr_Ed
    Ed
    2018 Limited 5.7
    None
    My 2003 Tundra didn't do that, but then, it was a 2003 :) No, I have no problem with it if it's normal. I just wanted to see if it was normal.
    Thanks for the answer and putting my mind at ease.
  6. Nov 14, 2021 at 2:15 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I've had multiple tunes on my 2008, and regardless I always have to do S6 to make the truck behave like a normal automatic. Otherwise it won't upshift, holds gears when it shouldn't, list goes on of weird shit it does.
  7. Nov 14, 2021 at 3:33 PM
    Mike59
    Mike59 Kentucky Traveller
    Central Kentucky
    2021 Tundra DC Limited 4x4 SSM
    my '21 does this, and I wish it didn't.
  8. Nov 14, 2021 at 5:21 PM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Yeah, it doesn’t coast like other trucks. I always thought it was due to the 4.30 rear end.
    If you just barely keep your foot on the gas it seems to coast better. Mine doesn’t downshift any more when coasting, and I think it’s at least in part due to the fact that I keep my foot on the gas just a little when going down a long grade instead of purely coasting. Keeps the instant MPG bar lit up all the way, and the truck doesn’t decelerate as quickly. Seems the transmission has learned this as part of how I drive.
  9. Nov 14, 2021 at 5:58 PM
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    I guess you could say it is a standard transmission, in that there is a lockup clutch that will give you direct drive from engine. It helps with fuel economy and heat by not having the torque converter spinning and slipping loosing efficiency at highway speed. I really like this Toyota design, think they have done a great job with their transmission. I don't know if all trucks out now have this feature but know several do.
  10. Nov 14, 2021 at 5:59 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Yes our trans does weird stuff. It has to make sense to some engineer
  11. Nov 14, 2021 at 6:22 PM
    Mike59
    Central Kentucky
    or some government bureaucrat/lawmaker.
  12. Nov 14, 2021 at 6:26 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    At this point I don’t think anything of it because my 4.0 2012 Tacoma and my 4.0 2017 4Runner did the exact same thing. It “seemed” odd for the first few months with my Tacoma.
  13. Nov 15, 2021 at 5:57 AM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    MY 06 and 18 do it.
  14. Nov 15, 2021 at 10:46 AM
    CMikeB
    CMikeB New Member
    If you're someone who notices what the Transmission is doing and you're not happy with it, then take control of it. Toyota made it really simple with their Sequential Shifter. It's a touch more 'involved' than just putting it in "D" and letting the truck do the "thinking" but it's worth the effort.
