Is it sap?
Discussion in 'Detailing' started by Mustang67ford, Aug 12, 2023.
  1. Aug 12, 2023 at 6:45 AM
    Mustang67ford
    Mustang67ford [OP] New Member
    I have a couple spots on the paint that I am not sure if it is sap or paint scuffs? What can I use to figure it out without causing damage, rub it with googone or wd40?
  2. Aug 12, 2023 at 7:44 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Auto paint safe Bug & Tar remover.
  3. Aug 12, 2023 at 7:50 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Kinda hard to see
    reywcms, Leo's first and 2mchfun like this.
  4. Aug 12, 2023 at 8:14 AM
    2mchfun
    A dab of WD-40 should work fine.
  5. Aug 12, 2023 at 5:46 PM
    briarpatch
    briarpatch New Member
    If its tree sap...hand sanitizer will dissolve it without causing any damage. I've used it on customers cars countless times without an issue
  6. Aug 12, 2023 at 10:34 PM
    White 2.5
    White 2.5 New Member
    Mt P, SC
    2020 White DC
    Running your fingers across it should let you know if it’s raised (sap) or sunk (scratched). Simple clay bar will take care of sap and minor scratches for that matter.
  7. Aug 13, 2023 at 4:40 AM
    briarpatch
    Clay barring will not get rid of sap. It's designed to remove contaminants, but tree sap is another matter....especially if there's any thickness to it. Likewise, the clay process will do absolutely nothing for minor scratches. It has been known to produce micro-marring, depending on the quality of the clay lube and the aggressiveness of the clay.
    ToyoMafia likes this.
  8. Aug 13, 2023 at 5:02 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Similar to the hand sanitizer, isopropyl alcohol mixed to no more than 50% strength with distilled water works miracles. I always have it premixed and in the truck while camping. Works great as a window cleaner, too. Just make sure you're using a clean microfiber.
    SwitchThrottle likes this.
  9. Aug 13, 2023 at 5:42 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Is there a clay bar you can recommend to me, an amateur like me?
  10. Aug 14, 2023 at 5:38 AM
    War Machine
    War Machine SSEM # 5 3MW
    I use a Nanoskin clay mitt. It’s reusable and faster than a traditional clay bar. I’ve used the clay mitt, then gone over the paint again with traditional clay to see if it picked anything up the mitt didn’t, but if it did it was minimal.
    Nanoskin AUTOSCRUB Fine Grade Wash Mitt,Weft Knitted Microfiber [AS-016] Blue, 6" x 8.7" https://www.amazon.com/dp/B00DOS0LH2
  11. Aug 14, 2023 at 4:48 PM
    briarpatch
    The clay mitts and clay towels are very popular, but I'm old school. I like to see what's coming off the surface. I keep two brands in the cabinet.....3M Perfect It for the more contaminated surfaces....Griots Detailing Clay for the less contaminated ones. I've been using Griots Speed Shine as a clay lube for many years. Griots was what I started with...I recommend it for someone who has not used a clay bar before.
  12. Aug 15, 2023 at 5:02 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Thanks!
  13. Aug 16, 2023 at 2:03 PM
    Mustang67ford
    Thanks. Will try the rubbing alcohol mix. Can Terry towels be used with regular waxing and quick detailer or only microfiber?
  14. Aug 16, 2023 at 3:09 PM
    bflooks
    bflooks New Member
    Metrowest MA
    If you are asking me, I'd encourage microfiber since you're touching your paint and they leave a ton less lint on windows than traditional towels, but do what you are comfortable with. Suggestion: let it work for a few seconds, feel free to hold a damp portion of the towel over it, too. You'll see it work miracles when you gently wipe it. Repeat as necessary.
  15. Aug 17, 2023 at 6:57 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    I know this sounds absolutely crazy but diaper wipes will remove tree sap. When the kiddos were small we carried a Costco pack of them in the car and one day I grabbed one to wipe some sap off the car. I was astonished how well it worked! :D
