Is it OK to drive with the rear window down?
Discussion in '2.5 Gen Tundras (2014-2021)' started by IowaGuy, Jul 9, 2022.
  1. Jul 9, 2022 at 11:04 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    Is it OK to drive with the rear bed window down on the crewmax ?
    Edit: I am asking because I was unsure if it would be unsupported in the down position and subject to rattle or break. I thought I read somewhere that the manual says you aren't supposed to travel with it down. That might have been due to debris and crap flying in the cab?
  2. Jul 9, 2022 at 11:06 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    It is as far as I'm concerned. Do it all the time. It's the best part of owning a CrewMax!
  3. Jul 9, 2022 at 11:08 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Why not? I do it all the time if I want increased air flow. Only issue is you'll get a lot of turbulence in the cab depending on your travel speed and what other windows are open.
    At lower speeds I drop all the windows including opening the sun roof. At higher speeds I usually button everything up and crack open the sun roof and crack open the rear bed window.
  4. Jul 9, 2022 at 11:08 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    So long as the bed is clean. The tiniest objects and dirt will come flying in if not.
  5. Jul 9, 2022 at 11:09 AM
    IowaGuy
    In Process
    I was unsure if it would be unsupported in the down position and rattle or break.
  6. Jul 9, 2022 at 11:12 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    uhh, this is one of the reasons why i bought a tundra.....so i can flex on my parents F150 that has a midget window in the back
    jomikepa, clarkritchie, 1UP and 8 others like this.
  7. Jul 9, 2022 at 11:12 AM
    Double Entundra
    Double Entundra New Member
    Scott
    White 4x4 SX
  8. Jul 9, 2022 at 11:16 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Its the reason I bought a Tundra, I have a cap and keep my dogs in the bed
  9. Jul 9, 2022 at 11:17 AM
    Saltyhero13
    You'll have the rear belts rattle and you'll get a lot of debris sucked in from the bed. The newer Tundra has two mini spoilers that help reduce if not eliminate the bed turbulence.
  10. Jul 9, 2022 at 11:32 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    This.
    Don't do it for a few weeks after you have hauled soil and 1/4 down. :rolleyes:
  11. Jul 9, 2022 at 11:33 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    As juvenile as it is, I love rolling the window down at stop lights when another truck pulls up behind me.
    Gieser0909, jomikepa, Bammer and 12 others like this.
  12. Jul 9, 2022 at 11:39 AM
    IowaGuy
    In Process
    I have a tonneu cover that I keep clean so debris isn't too much of an issue. I really wish someone would make a rear screen for these trucks. I think with a large 3D printer a person could make a screen frame that could be put on with 3 m tape.
  13. Jul 9, 2022 at 11:41 AM
    IowaGuy
    In Process
    I would also like to be able to send my wife into the truck bed to check the trailer hitch or get drinks out of the cooler without stopping.
  14. Jul 9, 2022 at 11:41 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    crewmax = max airflow
  15. Jul 9, 2022 at 11:54 AM
    737fixer
    737fixer New Member
    On 1.0, 2.0, and 2.5 your fine. On the 2022 Tundra were not sure if the bed will fly off, the front axle will fall off, the sunroof will implode. Since Toyota has chosen to instead of wasting money testing this truck we will just let the customer be our crash test dummi........people.
    hagrid, Kgfit85, WFD473 and 2 others like this.
  16. Jul 9, 2022 at 1:06 PM
    Cajun1977
    Cajun1977 New Member
    Shawn
    Northwest Arkansas
    2020 CM TSS
    Level lift Tonneau cover
    Just out of curiosity OP if you didn’t think you could travel with the window down …when did you think you could use the down feature?
    Sumo91, snivilous and NH 2018 Limited like this.
  17. Jul 9, 2022 at 1:17 PM
    Taco-Spike
    Two Trucks
    Yes. Good to go
  18. Jul 9, 2022 at 1:21 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    It is fine. Manual says not to do that, because exhaust can enter the cabin but I think we all do. As mentioned before, make sure the bed is clean or any dirt and crap back there will fly up into the cab.
    jewsNbrews and Retired...finally like this.
  19. Jul 9, 2022 at 1:22 PM
    IowaGuy
    In Process
    Picnics, waiting for the wife while she is shopping or to throw beer cans in the bed when parked or maybe as a portable deer blind?
  20. Jul 9, 2022 at 1:32 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Toyota actually tells us not to drive with it down, only to use parked, truck not running, because of fumes.
    I think it's in the manual somewhere.
    Tripleconpanna likes this.
  21. Jul 9, 2022 at 3:40 PM
    Cajun1977
    Shawn
    Northwest Arkansas
    2020 CM TSS
    Gotta say it’s true. I learn something new everyday
  22. Jul 9, 2022 at 3:49 PM
    Kgfit85
    Kgfit85 MR MRPH
    Kevin
    Jacksonville, TX
    2018 Tundra TRD Sport 4x4
    4” RC lift 35” Toyo 18” KMC Air ride bags for towing
    The only time mine is up is at night when I’m sleeping or torrential down pour (which doesn’t happen so much in SoCal). Other then that it’s always down, all 5.
    WFD473 likes this.
  23. Jul 9, 2022 at 3:52 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    5 windows down when cruising around town :cool:
    There was that one time a leaf blew in from the bed, swirled around, and then slapped me square in the face though. :anonymous:
    Bammer, Sumo91, WFD473 and 7 others like this.
  24. Jul 9, 2022 at 4:23 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    First thing we do when we get in the truck, if it's nice out and we aren't running a/c.....roll down the rear window and throw it in Tow Haul.
    WFD473 and Tripleconpanna like this.
  25. Jul 9, 2022 at 4:32 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I've seen that as well; but I wonder if the spirit of that cautionary line doesn't emanate from someone sitting in their garage w/the truck running and the rear window down???? Kinda like the whole floor mat campaign...
    Anyhow, while I'd never advocate anyone operating outside of the scope of their owner's manual, I can't image that if you are running at least one more or two more windows down that it wouldn't prevent exhaust fumes from entering and pooling up in the cab. For years, if I wanted the sunroof open (but didn't want to crack the side windows), I'd crack the rear slider and it would eliminate the sunroof noise and any unwanted wind in your face. But, that's just me!
    I just hope this doesn't turn into another towing thread...
  26. Jul 9, 2022 at 6:19 PM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    Two years, EVERY chance I get. The cabin dusting from bed debris is the only negative I've encountered.
  27. Jul 9, 2022 at 11:24 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Never knew the manual said don't drive with it down. But yeah, the two reasons I see they listed don't concern me much.
  28. Jul 9, 2022 at 11:51 PM
    chingyeunglo
    chingyeunglo New Member
    I do it all the time, but winter.
  29. Jul 10, 2022 at 12:06 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    We survived. ;)
    Cody1060, Kgfit85, WFD473 and 4 others like this.
  30. Jul 10, 2022 at 1:18 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Just don’t do it when you’re hauling a bed full of hay bales…
    :anonymous:
