Is it normal to have starting problems after reconnecting the battery?
Discussion in '2nd Gen Tundras (2007-2013)' started by bleach, Jun 22, 2021.
  1. Jun 22, 2021 at 6:34 PM
    bleach
    bleach [OP] MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    The past couple of weekends I needed to borrow the battery from my Tundra to start another car. Each time after putting it back and then trying to start it, it fires then dies right away. I even tried pressing the pedal slightly but the same thing happens. It starts on the second try and runs fine after that. I've never had something like this happen to anything else I've owned or own.
  2. Jun 22, 2021 at 6:36 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Yes, if I remember correctly it is the vehicle doing quick diagnostics, establishing min max parameters. Like a test run so to speak. My previous Tacoma did it when I unplugged the battery and we just put a new battery in my dad's tundra and it also did it.
  3. Jun 22, 2021 at 6:40 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I would say it's normal. I'm on my 2nd battery swap. First turn over dies.
    bleach[OP] and LarryDangerfield like this.
  4. Jun 22, 2021 at 6:43 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Yup, it’s normal.
  5. Jun 22, 2021 at 6:46 PM
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    Same here. Caught me off guard too but trust is normal as all good since.
    Matt56258 and bleach[OP] like this.
  6. Jun 22, 2021 at 7:03 PM
    DerfM
    DerfM Knows nothing about trucks
    South Dakota
    2021 TRD Pro MBM
    Yes, mine does this also. I remember seeing it in a video but it was still concerning the first time it happened.
    bleach[OP] likes this.
  7. Jun 22, 2021 at 7:06 PM
    Yes, it is normal and by design.
    mountainpete likes this.
  8. Jun 22, 2021 at 7:09 PM
    If you are still needing to use your Tundras battery to start another car, invest in one of these. Its a hell of alot easier than battery out, battery in.
    https://www.amazon.com/NOCO-GB40-Ul...3&sr=1-3-64f3a41a-73ca-403a-923c-8152c45485fe
  9. Jun 22, 2021 at 7:25 PM
    bleach
    DJ
    Battle Ground, WA
    Nice gizmo but what I really need is another battery for the other car. It's a car I rarely drive and was doing some work on it. I'll buy the battery once I get it running right.
  10. Jun 22, 2021 at 7:35 PM
    Gotcha. Another option after you replace the battery and if its parked outside is a solar maintainer. I have one on my TT battery. I disconnect the negative cable (the radio is always powered) and have the solar connected...it works really well.
    https://www.westmarine.com/buy/natu...tery-maintainers-2-pack--19187608?recordNum=3
    bleach[QUOTED][OP] likes this.
  11. Jun 22, 2021 at 7:40 PM
    bleach
    DJ
    Battle Ground, WA
    The car is always garaged. I plan on some sort of battery tender after I get that battery. It's a bit of an oddball size and not cheap.
  12. Jun 22, 2021 at 7:41 PM
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    If you turn the key to "on" and wait like 30 seconds before cranking, the truck shouldn't stall. I believe it's something to do with the throttle body calibrating as others have alluded to.
  13. Jun 22, 2021 at 7:42 PM
    bleach
    DJ
    Battle Ground, WA
    That's good to know. Usually I just turn the key and go.
  14. Jun 22, 2021 at 7:44 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Normal I go through this often enough..
  15. Jun 23, 2021 at 5:17 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    +1....... I keep one on my Tundra if its going to sit for a week or so. Both my Tundra and Tacoma start then die after reconnecting the battery, normal.
  16. Jun 23, 2021 at 7:01 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    Yup. Totally normal. It freaked me out too when it first happened to me. Now, I use one of these whenever I disconnect the battery. It saves all the ecu settings, the custom tune, the head unit settings, and it prevents the truck from dying on the first startup after reconnecting the battery:
    Amazon.com: OBD Connector Memory Saver AC/9v for Vehicle Battery Replacement/Disconnect Short/Long Term Memory Storage: Automotive
  17. Jul 4, 2021 at 11:16 AM
    bleach
    DJ
    Battle Ground, WA
    I had the battery out again yesterday to use in my other car. This time I waited about 30 seconds with the key in the on position before restarting. It started fairly normally without dying as it it did before.
    YardBird and NewImprovedRon like this.
  18. Aug 25, 2021 at 1:38 AM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    If it only did once and was after the battery replacement and is completely fine now I wouldn't worry about it. Probably after having the battery out both positive and negative grounded and drained any left over electricity out of the capacitors in the electronics.
    or if it sat for a long period of time with out battery.
    when I swapped my battery I didn't have a issue , but I wouldn't chalk it up to uncommon givin several variables in effect.
  19. Aug 26, 2021 at 6:28 PM
    bleach
    DJ
    Battle Ground, WA
    Actually the battery wasn't out for too long, maybe just for a couple of hours. I'm not sure if the cable ends touched anything while they weren't connected to anything. Either way I don't worry about it anymore when I borrow the battery. It just happens the battery in the Tundra is the easiest one to remove for borrowing.
    YardBird likes this.
  20. Aug 26, 2021 at 6:30 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Cleaning the throttle makes them start up much better and run smoother after battery replacement.
  21. Aug 28, 2021 at 5:33 PM
    mrballcb
    mrballcb New Member
    Todd
    2008 Grey Tundra CrewMax Limited TRD 2x4
    Black nerf bars
    How long does it take the "miles to empty" estimator to get accurate again? It was way off on the first fill up (40% too high). It's been a month and it's still about 15% too high.
    ...Todd
  22. Aug 28, 2021 at 5:46 PM
    bleach
    DJ
    Battle Ground, WA
    I've never paid attention to it. I just watch the gas gauge. If it gets down to around a 1/4 then I fill up. That's never let me down.
    I just set on outside temperature. It's too depressing to see the mpgs.
    Steplift20 likes this.
  23. Aug 28, 2021 at 7:20 PM
    georgiey22
    georgiey22 SW Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    All 3 Toyota’s I’ve owned have behaved this way when disconnecting/reconnecting the battery.
  24. Aug 29, 2021 at 8:22 AM
    bleach
    DJ
    Battle Ground, WA
    This is the 1st Toyota and only vehicle I've had that would do it. It's also the only drive by wire I've owned. Turning the key to just on for a few seconds before starting seems to solve the issue.
  25. Sep 13, 2024 at 9:40 AM
    Steplift20
    Steplift20 New Member
    2018 Tundra
    I feel it’s a Toyota thing, I had a 2003 solara and anytime you disconeneted the battery it would stall , I had to run the engine about 5 to 10 minutes before it was right. Imgo8ng to replace my tundra battery soon and was thinking the same thing.
  26. Sep 18, 2024 at 4:40 PM
    S0CKETMAN
    S0CKETMAN New Member
    07 Limited 4x4 CM Slate Metallic
    No worries. Completely normal. I've changed a lot of batteries on toyotas as a mechanic, and it happens all the time.
