Is it normal for alot of fumes to come out of the exhaust for a new 2023 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by DPhantastic, Dec 13, 2022.
  1. Dec 13, 2022 at 8:32 PM
    DPhantastic
    DPhantastic [OP] New Member
    I use 87 Octane gas as recommended in the manual, but I notice alot of fume coming out of the exhaust when I'm at a stop.
  2. Dec 13, 2022 at 8:43 PM
    mass-hole
    mass-hole New Member
    Its probably water vapor due to the colder weather of winter
  3. Dec 13, 2022 at 8:56 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Not much else to add. It’s cold, the ECU will run rich to warm up the catalytic converters for emissions.
    If it’s still doing this at idle when everything is up to operating temp, then it could be a problem. Assuming it’s not below 0 where you are, then it’s just how it is.
    DPhantastic[OP] and Durtywrench like this.
  4. Dec 14, 2022 at 5:34 AM
    AWDDude
    AWDDude New Member
    2023 Tundra Limited - Crew Max TRD Off Road 4x4
    Unless the smoke has a blueish tint, then you are fine, it’s just water vapor. Blue smoke means it’s burning engine oil.
    DPhantastic[OP] likes this.
