Is it necessary to relocate my shock mounts?
Discussion in 'Suspension' started by SanDiegoSlovak, Jan 5, 2023.
  1. Jan 5, 2023 at 8:26 PM
    SanDiegoSlovak
    SanDiegoSlovak [OP] Junior Woodchuck
    San Diego, CA
    2008 Double Cab SR5 4x4
    Eibach Pro Truck Coilover Stage 2, RCI skids (engine, transmission, rear diff), Demello Hybrid Sliders, Morimoto XB headlights
    About a year ago I installed the Eibach Pro-Truck Coilover Stage 2 kit and set my front suspension at ~2.5 inches of lift.
    This approximately leveled the truck out. But increasingly I'm doing my camping/wheeling with 400-500 pounds of weight in the back, so I'm getting a negative rake.
    I'm pretty sure I want to use the Icon RXT Leaf Pack set to Option 2 so I end up with something like a 1 inch lift under my typical load.
    In talking to my local suspension shop, they recommended I get the shock mounts relocated as part of installing the Icon leaf pack because my Eibach shocks can only handle ~2 inches of lift over stock. They said when off road, I might over-extend the shocks even under 500 pounds of load when at full droop/articulation.
    Initially this made sense to me since the Icon advertises the Option 2 setting as providing 3 inches of lift over stock unloaded. But then I called Toytec and Icon to get their take and they said I would be fine with the shocks in the stock mounts.
    Any opinion about whether the shock mount relocation might be necessary? It's not terribly expensive (~$90) so I'm leaning towards following my local shop's advice.
    Thanks!
  2. Jan 5, 2023 at 8:39 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    How much static weight do you have in the rear? Are you saying that how you load up the truck on average you would be sitting at +1" over stock ride height when at RXT option 2?
  3. Jan 5, 2023 at 8:46 PM
    SanDiegoSlovak
    San Diego, CA
    My rough estimate of my minimum static weight is ~300-400 pounds (camper shell, ~11 gal of gas, recovery gear, etc) and then when I load up to go camping a few hundred pounds more.
    The Icon RXT Option 2 says it provides 3 inches of lift unloaded and 2 inches of lift with 250 pounds. So I'm guessing I'll be safely under 2 inches most of the time, perhaps about about 1 inch of rear lift.
  4. Jan 6, 2023 at 7:00 AM
    memario1214
    Colton
    Missoula, MT
    So the Eibach shocks are generally good for +1.5" of rear lift. Do you have a shock that might come in a little short? Yes. However, shocks are designed to limit droop travel (low force), but not compression travel (high force). I tell people that you can use a shock as a limiting strap, but you can't use it as a bump stop. That said, if you're someone running suspensions very hard you don't want to be relying on that, and get a proper length shock and/or limiting straps. Most people don't use their vehicles hard enough to warrant straps though.
    Do you know where they are proposing to relocate the shock to? It's commonplace to relocate a shock mount for a longer shock, but we generally aren't in the game of making things shorter, but I see where their head's at in keeping you in the pocket of available travel with the shock that you have. If you have a good feeling about them go ahead, but my personal recommendation would be to get the leaf pack up underneath there and see where things are sitting for your "everyday" load. There's a chance that you are riding the end of the shock, and as a result will have no downtravel. However, there's a chance that with your additional load you'll be sitting in the middle of the available travel for that shock.
    AccuTune Offroad likes this.
  5. Jan 6, 2023 at 7:03 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Get some RAS back there and problem solved for cheap. You get a sway bar, a lift, control and stability. Done.
  6. Jan 6, 2023 at 7:41 AM
    memario1214
    Colton
    Missoula, MT
    While I do like the RAS systems in general (we're actually a dealer now even :spy:) I don't love them for overland or offroad builds. Modestly lifted street builds that tow stuff from time to time? Absolutely. However, the downside to those systems is that they do limit down travel by a decent amount so if articulation is wanted this isn't the setup.
    M3Tundra-JK likes this.
  7. Jan 6, 2023 at 7:45 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    FWIW, the RXT's will likely have too much downtravel for your current shocks. I ran OEM main leafs with a Deaver mini-pack mated with Fox 2" resi's for years and they matched up perfectly for up and down travel.
    When I installed my RXT's at Option #2, they were ~1-5-2" too short at full droop. I ran them like that for a few months until my RXT shocks came in, I just tried to not run them too hard. Another option would be to install limit straps...
  8. Jan 6, 2023 at 7:47 AM
    memario1214
    Colton
    Missoula, MT
    Were you running Fox 2.0s or 2.5s out back?
  9. Jan 6, 2023 at 7:56 AM
    VWTim
    Corvallis, OR
    Fox 2.0's, sold for 1.5-2" lift. They're in my garage now if an extended length measurement would help?
  10. Jan 6, 2023 at 8:11 AM
    memario1214
    Colton
    Missoula, MT
    Sure! I'd love to see what you've got! The reason I asked is because the Fox 2.0s are shorter than the 2.5s by a bit. I don't recall Fox making a 1.5-2" lift version for the Tundra anyway (one of my complaints for them). They definitely don't sell them now. The Eibach rears are the same length as the Fox 2.5s. All said, he's still going to be short of his maximum droop potential as you've stated.
  11. Jan 6, 2023 at 8:16 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I snapped quite a few shocks before I figured out I needed limit straps :rofl:
    All it takes is a quick shift in the body roll (left to right/right to left) like when you crest a mound or little sand dunes.
    Sunnier likes this.
  12. Jan 6, 2023 at 8:25 AM
    memario1214
    Colton
    Missoula, MT
    Your videos on your build page indicate to me for sure that you would be a solid candidate for limiting straps... :bananadead::bananadead::bananadead::anonymous:
    Sucks you had to find out the hard way though.
    Cruzer[QUOTED] likes this.
  13. Jan 6, 2023 at 8:43 AM
    VWTim
    Corvallis, OR
    Sure, I'll try to remember and measure them this weekend. They're certainly old NLA models, I bought them in Dec 2011 and they were on sale as a closeout model then. They're 2" piggybacks.
  14. Jan 6, 2023 at 12:24 PM
    MadMaxCanon
    I do offroad and overland and I have not found them to limit me in any way. Granted I don't do anything that requires a crazy amount of articulation most of the time. I think for most guys here they would be fine for the majority of the time.
  15. Jan 6, 2023 at 1:40 PM
    blenton
    blenton New Member
    @memario1214 is on point, as is @MadMaxCanon .
    I have found my shocks to be the limiting factor in rear suspension articulation without any issues or blown shocks. I don’t flex it that hard or at speed. I do drive forest service roads at speed, though. 50-60 mph and most of them float :) I have a topper and about 5-800 lbs in the bed at all times. I ran a +1 shackle, then added bags, then an icon 3 leaf pack. All have worked well for me but I find the leaf spring upgrade best for static weight, with airbags for my varying loads and trailering (which is often). I’ve used factory bilsteins, fox 2.0, Eibachs, and Bilstein 5160’s in the rear. All have worked without issue.
    With icon 3 leaf AAL, though, it appears my brake lines are much closer to being the limiting factor. I chose to run airbags and cradles vs something like RAS as I feel they are more versatile, tune-able, and less restrictive off-road. Many will say that they are susceptible to punctures and and as soon as you go off pavement they are going to pop. Mine have lasted almost 5 years and 100k without issue.
  16. Jan 10, 2023 at 5:10 PM
    VWTim
    Corvallis, OR
    They measure 25.5" from center of eyelet to mounting surface (middle of rubber bushing sandwich)
  17. Jan 25, 2023 at 8:40 PM
    SanDiegoSlovak
    San Diego, CA
    Thank you all for the advice and input! So my local suspension shop ended up recommending I start with the Icon RXT at Option 1 due to both the length of the Eibach shocks and because I was getting enough net lift at Option 1. With ~170k miles on my OEM leaf pack, I apparently didn't need to go to Option 2 just yet.
    I'll keep things slow when wheeling to see how things go. Perhaps longer rear shocks or limit straps are in my future.
  18. Mar 9, 2023 at 8:03 AM
    dhalsey
    dhalsey New Member
    If the RAS is installed while the suspension is at full droop then how would it limit down travel?
  19. Mar 9, 2023 at 8:14 AM
    dhalsey
    dhalsey New Member
    Did you mean that they limit up travel? That would make sense. I've been really interested in testing the articulation with a RAS on.
  20. Mar 9, 2023 at 8:55 AM
    memario1214
    Colton
    Missoula, MT
    You are correct at least on some level. Since the RAS engages more as additional weight is applied it will "limit" uptravel by virtue of actively resisting it. I don't know if one were to force it whether or not its build will allow it to go all the way up to the bumps, but I assume it would. What I was referring to in terms of the downtravel issue on offroad/overland builds is that many of those types of builds are going to have aftermarket leafs and aftermarket shocks which provide more atriculation. The RAS does have a limit to which it can extend downward, and aftermarket suspensions will outreach that.
  21. Mar 9, 2023 at 9:13 AM
    dhalsey
    dhalsey New Member
    Very good explanation. Thanks
    memario1214[QUOTED] likes this.
