Is changing the rear pads & rotor exactly the same as the front ??
Discussion in '2nd Gen Tundras (2007-2013)' started by 10 Bears, Nov 19, 2024.
  1. Nov 19, 2024 at 9:06 AM
    10 Bears
    10 Bears [OP] New Member
    11 CREW 5.7
    None at the moment
    I've started to hear the squeak indicator on the rear passenger side plus their visually worn, I've already replaced the front rotors & pads last December...relatively easy job, it was harder removing & reinstalling the the giant 20" wheels. At that time the rear pads had plenty of meat so I let them be.
    Anyone here already change all four pads & rotors on the Tundra, is changing rears the same as the front eazy peazy or are they more involved ? Truck is a
    2011 SR5 CREWMAX disks front & rear if it matters.
    I have seen some YouTube vids but my issue with that is 90% of the how to's make everything look eazy LOL..
    ANYHOW your input or advise is welcome.
  2. Nov 19, 2024 at 9:08 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Same as the front. Two bolts removes the caliper, smack rotor off, slide pads out. Keep the parking brake off and the rotor should come off without too much fight.
    10 Bears[OP] and OldGuy03 like this.
  3. Nov 19, 2024 at 9:33 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  4. Nov 19, 2024 at 9:41 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Always needed that 8mm bolt for the rear rotors. Front ones come out fairly easy.
    Cruiserpilot and 10 Bears[OP] like this.
  5. Nov 19, 2024 at 11:09 AM
    10 Bears
    11 CREW 5.7
    None at the moment
    You answered my question before I could ask....thanks. 8 mm bolt to help remove the rotor.
    blackdemon_tt[QUOTED] likes this.
  6. Nov 20, 2024 at 9:13 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    S0CKETMAN and Cruiserpilot like this.
  7. Nov 24, 2024 at 6:47 PM
    S0CKETMAN
    S0CKETMAN New Member
    07 Limited 4x4 CM Slate Metallic
    Great video. :thumbsup:
