Is body lift kit worth it
Discussion in 'Suspension' started by Lossy87, May 1, 2020.
  1. May 1, 2020 at 5:51 PM
    Lossy87
    Lossy87 [OP] New Member
    Carlos
    2014 Tundra Crewmax
    Is it worth buying a 3/1 or 3/2 ready lift kit or should I save money to get a trd pro suspension lift or Bds coilover 3inch lift
    and if I do do the ready lift what’s the max size tire I can run with out having to do any cutting
  2. May 2, 2020 at 5:49 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Stay away from spacer lifts if you can and also rear blocks. Bilstein 5100’s or 6112’s are a cheap alternative. Get shackles for the rear not blocks.
    Sunnier and Tundra234 like this.
  3. May 2, 2020 at 5:54 AM
    Lossy87
    Carlos
    2014 Tundra Crewmax
    Ok cool
  4. May 2, 2020 at 6:39 AM
    Lossy87
    Carlos
    2014 Tundra Crewmax
    See I want this but I need to save and do some more research. I don’t want lose mpg or do any trimming or mods or to fit a tire so I was hoping I can fit a 32 or 32.5 tire on their 20 inch wheel and not rub on this bds 3 inch coilover lift
  5. May 2, 2020 at 6:46 AM
    IMO, that's an expensive lift for what you are trying to do. A 32 is a stock tire and will look small with a 3 inch lift. I went the Toytec route...which is what I'm installing today. As @LT75 said, stay away from spacers and blocks. I have the Readylift 3/2 and that's what I am removing after a year and a half.
    Sunnier likes this.
  6. May 2, 2020 at 6:50 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I agree. A 3” lift with anything less than 34”-35” tires will look small.
    Sunnier and jewsNbrews like this.
  7. May 2, 2020 at 6:56 AM
    Cthulhu
    @Lossy87 do you plan on doing some really heavy offroading, or are you just lifting to get tire clearance? For heavy offroading, I agree, you should go the route of a suspension lift with no front spacers and no rear blocks (use shackles for the rear if you want to maintain a close-to-factory rake). If all you need is tire clearance, front spacers are fine with bump stock extensions, but I still would not use rear blocks, for shackles aren't that much more expensive. It also depends on whether or not you're installing yourself; if you are having someone install, by the time labor is added, it's only a little more expensive to go with a Bilstein 6112/5160 (or 5100 in the rear) suspension lift with shackles (if you want to maintain said rake), or even cheaper with 5100’s all around, versus doing a front spacer lift. I learned that the hard way. :( Lots of guys run the 6112/5160 (or 5100) set-up on this forum; there's a whole thread dedicated to it. :thumbsup:
    One more thing, anytime you go to a bigger tire, you can forget about maintaining your MPG's...
    jewsNbrews and Lossy87[OP] like this.
  8. May 2, 2020 at 6:57 AM
    I run 34's with the Readylift. Switching over to these today. Shackles are on the way.
    jewsNbrews likes this.
  9. May 2, 2020 at 7:25 AM
    Lossy87
    Carlos
    2014 Tundra Crewmax
    Thanks yall
  10. May 2, 2020 at 7:29 AM
    Lossy87
    Carlos
    2014 Tundra Crewmax
    I’d like to be able to go off-roading . Just want to be versatile
  11. May 2, 2020 at 9:02 AM
    Cthulhu
    Cool. That Fox kit though might be a little overkill for only part-time offroading...6112/5160 set-up will give you the clearance, and is more than capable for offroading. BUT...it’s YOUR money, spend it how you would like! That Fox set-up on your truck would be AWESOME!!
  12. May 2, 2020 at 10:01 AM
    buckeyeinlv
    buckeyeinlv International Man of Mystery
    Brandon
    Henderson, NV
    2020 Army Green TRD Pro CrewMax
    OEM Power Tailgate Lock, Peragon Tonneau Cover, S&B Intake, Bora 1” Spacers, ceramic window tint. Interior: OCD Organizer, AJT Designs Cup Tray and Shift Trim, JDMCar Rubber inserts. Tires: 285/70R18 Old Truck: Base:2017 Inferno SR5 CM 4x4 Mods: Interior- OCD organizer, Proclip USA iPhone X Mount, Wireless center console charger, TRD shift knob. Exterior- Backflip G2 Tonneau Cover, Amp Research Powersteps and Bed Step, Pop and Lock tailgate lock, Ceramic window tint, Blackout emblems, TRD Pro Grille, Stubby antenna, Vinyl American flag TRD graphics, Color matched and bullet lined bumper ends, 18x9/+25 Method NV305 Bronze wheels Engine- Stock
    The TRD Pro Fox setup will clear a 33.5 easily without any modification/trimming. I run Nitto Ridge Grappler 285/70R-18 ~33.5” on my stock Pro. No rubbing, no trimming, barely noticeable MPG loss. Recently added 1” Bora Spacers to make the wheels come outside the body a tad. Still no rubbing. I agree with the previous posters as well. Definitely do coil overs and shackles vs blocks. 32’s look too small on our trucks. Good luck!
    Lossy87[OP], Sunnier and jewsNbrews like this.
  13. May 2, 2020 at 10:32 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Nitto is listed at 33.98 in that size, are they closer to 33.5" or 34"
    I have been going back and forth on size and brand and can't make up my mind. Nitto like yours or bfg km3 in same size 285/70/18, or faulken wildpeak at3 in 275/70/18.
    Spacers make the stance look better, but not sure if I want to use them or not.
    buckeyeinlv[QUOTED] likes this.
  14. May 2, 2020 at 11:23 AM
    buckeyeinlv
    Brandon
    Henderson, NV
    According to Tiresize.com it’s 33.7”. Each tire manufacturer is a little different in overall size. So I’d believe it being closer to 34. If you don’t want to run spacers to achieve a wider stance just run after market wheels with a larger offset. About +18 - +22 seems to be the sweet spot. I wanted to keep the stock BBS Pro Wheels. After doing quite a bit of research I found that so long as you use a reputable brand spacer (Bora, Spidertrax) you are safe. That said, the wider you go the more likely to experience problems. That why I went with the 1”. 1: Bora custom makes each spacer to order and are arguably one of the best in the spacer market. 2: 1” is the absolute minimum width without having to modify the lugs. 3: It was going to make the tire stick out just the right amount for my liking.
    I wouldn’t go any bigger than 1.25” though.
  15. May 2, 2020 at 12:36 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    The manufacturer on the bfg states 33.7
    I really want 285/75/18, as it's closer to a 35 but not as wide as most 35s. But to fit that I think I would need a new bumper or lots of trimming of the stock one. Basically I am indecisive as of right now.
    Your truck looks great by the way
    buckeyeinlv likes this.
  16. May 2, 2020 at 1:28 PM
    buckeyeinlv
    Brandon
    Henderson, NV
    I have no experience with that size. I think some of the others here have run a 35 on a stock Pro setup. Not sure if they had to trim though. Have you considered 295/70/18? It’s not a 35 but bigger than 34. Thanks for the compliment!
  17. May 2, 2020 at 1:34 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Rear lift blocks are pretty standard in lift kits. The people who really need to worry about it are trail runners...the boulder crawling trail rigs where articulation angles can pop a block right out.
  18. May 2, 2020 at 3:35 PM
    I run the 285/70/18 Ridge Grappler. It's right at a 34. The 295/70 is only about a 1/2 inch bigger and 10 lbs heavier than the 285.
  19. May 2, 2020 at 6:13 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    They are standard. But because Toyota has weak rear leafs many have had them flatten prematurely due to blocks.
  20. May 2, 2020 at 6:14 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I could see that. My buddy's 2017 Taco has flat almost neg arch leaves and he just put a lift on it
  21. May 5, 2020 at 2:40 PM
    Lossy87
    Carlos
    2014 Tundra Crewmax
    Do you have a link to that 6112/5160 set up
  22. May 5, 2020 at 3:00 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    I have a 2019 with a flat spring @ 5000 mi.
  23. May 5, 2020 at 3:10 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Will a warranty address it? Should have a TSB
  24. May 5, 2020 at 4:24 PM
    Lossy87
    Carlos
    2014 Tundra Crewmax
    Ok so if I do the:
    Bilstein 6112 so what’s that a 2.75 lift in front
    What would I do the rear to level it out
    Bilstein 5160 with 1 or 2 inch shackles
  25. May 5, 2020 at 6:09 PM
    Cthulhu
  26. May 5, 2020 at 6:14 PM
    Lossy87
    Carlos
    2014 Tundra Crewmax
  27. May 5, 2020 at 6:36 PM
    Cthulhu
    :thumbsup:
