Is anyone run running 295/60r20 in a mt?
Discussion in 'Wheels & Tires' started by hunterpedrick6, Jul 2, 2019.
  1. Jul 2, 2019 at 5:11 AM
    hunterpedrick6
    hunterpedrick6 [OP] Hunter Pedrick from Quitman ga
    Hunter
    Quitman,ga
    2019 Toyota Tundra trd off-road sport white
    i have 20inch stock trd sport rims and a lifting kit can I run them without having a wheel spacer or offset rim? I’m worried about it hitting upper control arm?
  2. Jul 2, 2019 at 5:49 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Most all MTs have an aggressive sidewall. A 295/60/20 MT will most likely hit the UCA. As mentioned in your other post...you either need new wheels or spacers.
  3. Jul 2, 2019 at 7:02 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    I run Cooper STT Pro 295/60/20, but I have a +18 offset wheel. I believe your stock wheels are probably +50 or 60 offset. Assuming the more "aggressive" 50, that's a 32mm difference, roughly 1.25". Not sure that would clear, but maybe. I'll try to get a picture for reference on mine
  4. Jul 2, 2019 at 7:03 AM
    hunterpedrick6
    Hunter
    Quitman,ga
    Okay thanks
