Is adding sound deadening to the doors worth it
Discussion in '3rd Gen Tundras (2022+)' started by elgreco, Apr 25, 2022.
  1. Apr 25, 2022 at 6:43 PM
    elgreco
    elgreco [OP] New Member
    In order to install new door handles, I need to remove the door panels. I figured while I have them off, Id add some sound deadening. Do you think this is worth it?
  2. Apr 25, 2022 at 6:49 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Seems like everyone that does is happy they did.
    If stock stereo it may not have huge sound gains but should be a bit better.
    The reduction in road noise will be nice as well as the doors feeling a bit more robust when closing.
    elgreco[OP] likes this.
  3. Apr 25, 2022 at 7:12 PM
    offshore2005
    offshore2005 New Member
    TEXAS
    2022 Tundra Limited 4x4 RC leveling kit and 295/65/20 Cooper STT PROs
    How does one go about doing this and what is the average cost?
  4. Apr 25, 2022 at 7:27 PM
    Trooper2
    JR
    Much of the material has an adhesive side to stick to the metal. Cost can vary. Haven't priced lately but a couple hundred should get the doors done. Same costs for roof, floor, and back of cab. Some have done these as well.
    There are several products out there that are different thicknesses at different costs.
    Here is one thread discussing it.
    https://www.tundras.com/threads/door-sound-deadening-placement-question.38631/#post-2687057
    Lots of info on YouTube as well
  5. Apr 25, 2022 at 7:56 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  6. Apr 25, 2022 at 8:52 PM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    Done all four doors and back panel, little better stereo, not so much sound deadening, much firmer doors.
    W3agle and elgreco[OP] like this.
  7. Apr 25, 2022 at 8:53 PM
    GNTundra
    Gino
    2013 White
  8. Apr 25, 2022 at 9:16 PM
    JamesAZ
    JamesAZ New Member
    It's worth it just for the more solid feeling alone. You don't even need that much material too. 25% coverage will be 90% effective.
    WFD473 likes this.
  9. Apr 26, 2022 at 8:31 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I've always done it to my vehicles. Inner/outer door skin, firewall, floorboard, headliner and rear wall. I used raamaudio (no longer in business) back then, not sure what to use now. Well worth it for the sound deadening and the feel of the doors.
  10. Apr 26, 2022 at 12:46 PM
    JamesAZ
    JamesAZ New Member
    SecondSkin is apparently really good and has a lot of options.
    https://www.secondskinaudio.com/shop/
    I plan on using them when I do it to my Tundra.
  11. Jan 11, 2024 at 6:43 PM
    surfmonkey
    surfmonkey New Member
    2024 Tundra Limited
    Full tank of gas
    Sorry to wake the dead on this, but has anyone chased this down?
  12. Jan 11, 2024 at 7:43 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    it’s worth it for a sound quality standpoint for upgraded speakers but don’t expect a world of difference.
  13. Jan 12, 2024 at 1:37 AM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    I had the same thought process. I'm going to have the door panels off to install my color-matched door handles, so I might as well add some deadening at the same time. The material is deceptively heavy. I suppose it needs to be. I probably won't be installing mine until Spring, as we're beginning to see negatives for highs and I'm unsure of the parameters for installation temp ranges.
    reference this thread https://www.tundras.com/threads/sound-deadening.65590/
