Is a lifting a good or bad idea? pros and cons?
Discussion in 'Suspension' started by aMike, Dec 11, 2022.
  1. Dec 11, 2022 at 6:46 AM
    aMike
    aMike [OP] New Member
    My tundra is all stock, i have been toying with the idea of getting a suspension lift by paying a local shop that does this kind of work all the time.
    I am wondering what the cons are, i would like to run 33 inch tires the stocks are 31" i believe and i really don't want anything cut. Maybe a 2 inch lift nothing to drastic.
    How does lifting change the handling of the truck? Will the drive line wear out quicker if it's more at a tilt and is getting a alignment more of a issue?
    What happens when you have a load in the bed when it's lifted or toe a trailer?
    If you get a suspension lift does that level the truck as well?
    Another concern is if it will fit in my garage once lifted so if i got a 2 inch lift with 33 inch tires would the top of the cab be 4 inches taller?
    Thanks for all the info!
  2. Dec 11, 2022 at 6:51 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You can just put 275/70/18 on stock. Thats a 33
    Many guys run lifted 2 inches with very little extra wear. the ride suffers as soon as you lift it.
  3. Dec 11, 2022 at 7:01 AM
    centex
    centex New Member
    I’ve owned many lifted vehicles. Anywhere from 2-6” with tires from 33-38”. For a driver, 2” leveling kit up front with a 33” is perfect. No real extra wear to speak of, doesn’t change the handling characteristics, doesn’t change the ride, still easy to get in and out of, haven’t had an issue going in to parking garages, levels the truck out and makes for a nice look, still tows well, easy to install.
    I got out of my big lift and big tire phase a long time ago after dealing with the bs of a bunch of aftermarket parts and having to rig stuff up when//if something went wrong with a non factory part. These days I prefer a lower lift with a bigger tire. I’d rather trim a little plastic and get a bigger tire than deal with a taller lift.
  4. Dec 11, 2022 at 7:07 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Stock tires are 32". For 33" you need no mods. The number is a diameter, so the total height increase going from 32 to 33 is 1/2".
    Cheap suspension lift is almost assured to result in a firmer ride, which is usually unwelcome. I have a ~1.5" lift using Bilstein 5100 in the middle setting and aftermarket shackles in back, the truck is MUCH firmer. Right now it has got a front bumper w/ winch, steel skid plates, Leer cap and bed liner, that extra weight keeps the truck at about stock height, plus it loaded the suspension and the truck drives not as harsh as it used to be when the lift just went in.
    I would also advise getting a P-rated tires, not LT, unless you're offroading. P is softer and lighter.
  5. Dec 11, 2022 at 7:17 AM
    2mchfun
    Lift it high and enjoy it, life is short!
  6. Dec 11, 2022 at 7:56 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    What year is this Tundra? 31” would be gen 1 size stock, where 33” is a big upgrade vs. gen 3 has 32.5” from the factory wouldn’t likely notice a 33” as different.
  7. Dec 11, 2022 at 8:53 AM
    aMike
    My stock size is 275/65R18.
    How does the ride suffer?
  8. Dec 11, 2022 at 8:54 AM
    aMike
    2019 TRD, i just looked it's 275/65R18
  9. Dec 11, 2022 at 8:55 AM
    Ericsopa
    Ericsopa Old man and the sea
    Well now, this is just my opinion, and you know what they says about opinions.....
    I'm an old fogey now, and I'll say right up front that as far as I'm concerned folks can do to their own equipment whatever they choose, and I'm fine with it.
    But even though I truly think one should do as he pleases (as long as it's not a safety issue) I really don't understand why anyone would want to waste money to lift his truck and cause a stiffer, uncomfortable ride on bigger, knobby tires that I can hear coming from 2 miles away if they don't intend to ever go rock crawling or mudding, or plowing through deep sand.
    I could go on, but there's no point. Prolly no point in even expressing my opinion except to confirm my status as a bona fide "boomer." What the hell man, if you like the idea and have the wherewithal, then do it! :rofl:
    Jjclamdips, ATV25 and Melikeymy beer like this.
  10. Dec 11, 2022 at 10:46 AM
    hBaz
    hBaz New Member
    middle of nowhere south of OK City
    2021 black 1794 Edition with TRD package
    I'd say that answer to your question depends on your use. Our truck is our second vehicle, our use includes towing horses and a 16 foot trailer for hay etc. We are downgrading from a 4 horse goose neck towed by 3/4 ton to a 2 horse bumper pull (now ponies). The towing capacity of Tundra is plenty for our need, but payload of Tundras is low. We like the 1794, picked it, and knew that means lowest of low. So I won't be adding weight - lifting adds weight, bigger tires add weight. Also, I want to stick with stock suspension for towing, hoping weight distribution hitch is sufficient.
    With all that said, I do like the looks of lifted trucks with aggressive tires - moderate, not extreme. I had put a leveling kit and slightly oversized rugged style all terrain tires on our 2004 4runner. That was awesome when we lived in Arizona. But times change, needs change.
    We used the 4runner offroad so the tires looked like they were used for purpose - I do chuckle when see lifts with big tires that have never been of pavement.
  11. Dec 11, 2022 at 11:00 AM
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    The ride is highly dependent on what lift you choose. If you want a small level with oem ride I'd go with rough country 2in lift struts. I had them before my dobinsons kit and there literally was no change in ride quality. They also did not require ucas. If all I were doing was a level , I'd go that route again. For reference below in this order is 33s rough country 2 in level struts and 4500 lbs , same setup 1500 lbs trailer empty, and same setup no load. Only difference is I'm on 20s.
  12. Dec 11, 2022 at 11:01 AM
    aMike
    I don't go off road only doing it for looks.
    My other truck was a 26 year old tacoma and i love how the tundra drives and feels compared to the old truck. I hate to mess with that but i do like lifted trucks.
  13. Dec 11, 2022 at 11:11 AM
    2mchfun
    Seriously, mine was lifted to provide a more safe environment from the idiots texting, drinking, etc. while they drive. As a bonus, it also provides a better view of most everything including the eye candy.
    texasrho83 likes this.
  14. Dec 11, 2022 at 11:11 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    A 2” lift shouldn’t negatively affect anything assuming the shocks you use are decent quality. Bilstein 5100s aren’t a bad choice if you want lift. Granted mines a 1st gen, the 5100s with old man emu springs have been fantastic riding on my tundra
  15. Dec 11, 2022 at 11:40 AM
    Wahayes
    Will
    2017 tundra limited
    It should go without saying but DO NOT do a spacer lift. That will ride like shit and mess stuff up
  16. Dec 11, 2022 at 11:48 AM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    A lift will negatively impact your fuel economy, if that matters to you. IMO it also makes the ride and handling worse and reduces your payload if you tow.
    You do you.
  17. Dec 11, 2022 at 11:58 AM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    I would go with a small lift like 2”. I really didn’t notice any difference in mine until I put 305/65 r18 tires on mine. They are wide 33” tires. Took a hit on gas mileage then. About 1 mile less mpg. And I have the 4.6l v8. Probably makes a difference. I do have thế tow gears though. Overall I think the lift is worth it.
  18. Dec 11, 2022 at 12:07 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    2mchfun[QUOTED] likes this.
  19. Dec 11, 2022 at 12:09 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Just go easy on the weights and make sure you stretch before and after every session.
  20. Dec 11, 2022 at 12:18 PM
    Melikeymy beer
    Muscogee Nation
    Nice. Living up to your sig :rofl:
    2mchfun and Hightide[QUOTED] like this.
  21. Dec 11, 2022 at 12:23 PM
    1794TX
    Steven
    N.TX
    '20 1794
    I had zero experience with lifted trucks before levelling mine; and reading as much as I could and asking questions in this forum helped me a ton.
    I added 2.25" lift in the front with Falcon shocks to bring the front of the truck up to about level with the rear, removing the 'rake'; and I added .75" in the rear with '+1' shackles from Coachbuilder to add some of the rake back in. I didn't scrimp on the quality of the parts or tires, and my ride is better now by a smidge than it was stock. You can also lift the rear a smidge with a RAS / active suspension spring if you'll be towing, which will add stability and comfort. I probably should have gone that way instead of the shackles, but here I am. I didn't add aftermarket UCA's, and it aligns just fine. I'm very happy with the way it is now.
    Metric tire sizes and the sidewall ratings that typically go with them will help you keep some comfort. Going with a standard (e.g. 33" x 12") tire sizes usually comes along with a stiffer offroad sidewall, which will impact the ride quality quite a bit. Tire brands are discussed ad-nauseum in this forum, and DT and other tire sellers use ride quality and noise ratings, so that should be part of the picture for you. I'm in my mid 50's, so ride comfort and noise were important factors.
    No matter what anyone here says about whether you can do the lift yourself or not; unless you're going to spend money on a high quality - high safety tool, please OH PLEASE get a shop to mount your shocks in their springs. Compressing a spring with some cheapo or home made tool is putting your life and limbs at risk, and adding inexperience bumps that risk up. Find a reasonably priced shop and let them use their much safer equipment.
    Good luck with the endeavor, and come back with pics.
  22. Dec 11, 2022 at 12:53 PM
    JED
    JED 2016 1794 Edition
    JED
    Tennessee
    2016 Tundra 1794
    Rough Country 3 1/2 inch Lift Level (with 2 inch rear block), Fuel D556 Wheels & Bridgestone Dueler AT Revo3 Tires, Painted Brake Calipers, Interior LED Light Kit, Firestone 2445 Toyota Tundra Ride-Rite Air Helper Spring Kit, ARE Cap with 2020 4Runner Cargo Rack, Weather Tech Liners, Spray in Bed Liner
    I used Rough Country's 3.5 inch Lift/Level kit but had them swap the 1 inch rear block for a 2 inch because I like just a little rack. I ran the stock 1794 Edition wheels and tires for awhile, then bought the Fuel D556 wheels in 20x9. I had the stock tires mounted and ran that through the tread life, then bought the Bridgestone Dueler AT Revo 3's in 275/60R20 (33 inch OA height) which is my current setup. First thing you'll have to do when you add wheels and tires is remove your front scuppers (they look like mini mud flaps hanging from your front bumper) as there will definitely be rubbing on these. With my 275/60R20's on 20 x9 D556 Fuels I get just an ever so slight rub when backing up with my steering wheel at about 2/3's to lock even with the scuppers removed.
  23. Dec 12, 2022 at 1:21 AM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    doing a 6” lift requires some work and research. Tires:35”x12.5”x20” on rims: 20”x10”x-19. adjustable front and rear Vertex shocks, Coach builders steering, 1/2” bumper spacer, Jomax front sway bar end links, SDHQ BMC plate, Camburg rear shackles, Nitro 4.88 gearing. the ride is better than stock, mpg went down. only off road i do is mild off road, sand, dirt, camping and beach use ie; surfing.
    bottom line is build it for what your gonna use it for…. me it’s my fun weekend use. i drive a Rav4 for work
    V3N0M likes this.
