is 2014 or 2015 Tundra a reliable truck?
Discussion in '2.5 Gen Tundras (2014-2021)' started by yeo3th, Jul 25, 2022.
  1. Jul 25, 2022 at 6:00 AM
    yeo3th
    yeo3th [OP] New Member
    Hello,
    Recently I found out my 06 Lexus GX470 has busted front evaporator core and frame damage from rust which will cost min 5k to fix the issues.
    As I always wanted to own a pick up truck, I started doing research and looks like either 2014-2015 Tundra or 2014 F-150 would be a good option for me that will fit under my budget.
    Do Tundra from those years would have same rust issue? What are some of the common problems of Tundra from those years? and lastly what are the things I should be checking when buying a Tundra from those years?
    I did research from carcomplaints and consumer reports but I want to hear from the actual owners.
    Also, I plan on using mostly as a family car (will need to install two car seats in the back) and occasional offroading. I wonder if I am looking car for the use or if Tundra is too much of vehicle for my intended use...
    Any feedback will be appreciated!
  2. Jul 25, 2022 at 6:29 AM
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    I have a 2014. Has been outstanding in terms of reliability (just under 200k kms- highway). Only issues I have had is needing a reflash on the head unit and the rear pinion seal replaced. So far as rust, nothing significant has come up, I undercoat it which I am sure helps in northern Ontario. I don’t believe the Gen 2/2.5 trucks have the frame rust issues that occurred in Gen 1:crapstorm:I did have paint come off on my door sills, that is one common item but an easy fix.
    One thing to check might be brakes (as these are expensive wear items) but again, still have only done once since new. I could afford new but plan to keep her for a good while yet as has been solid. I would avoid Fords of the same era- or in general (former F-150 5.4L owner).
  3. Jul 25, 2022 at 9:47 AM
    Red Dragon
    Red Dragon New Member
    Pocatello, Idaho
    2015 Barcelona Red Limited TRD
    I bought a 2015 Limited Crewmax 4x4 in 2018. It had almost 50,000 miles on it. I have put nearly 30,000 miles on it since I have owned it. It has been the best truck I have ever owned. I have made two trips of almost 5,000 miles each towing a 29' travel trailer trailer from Idaho to Mississippi and back through Texas at 65 mph. It performed flawlessly on both trips. The only maintenance I have done so far is regular oil changes and a transmission/differential service (I probably didn't need the transmission service, but felt after towing our trailer, that it was probably a good idea. I haven't noticed any rust issues on mine.
    IsaiahCanada and Metro14536 like this.
  4. Jul 25, 2022 at 9:51 AM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    My brother-in-law has a 2014 that he's had since new. It has about 80k on it now. He pulls a boat and utility trailers with it regularly, and it has been subjected to the intense Minnesota winters for years. He has had no issues with it. Just routine maintenance. He loves it and has converted several friends over to Tundras as well. I wouldn't hesitate to buy a well taken care of used one.
    Metro14536 likes this.
  5. Jul 27, 2022 at 4:32 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    I have a 2014 Limited CM…bought new…still have it…94K on it now…added the TRD S/C at 6700 miles and its been great. Tows anything I need, 5k lbs boat, utility trailer etc.
    Other than normal maintenance the only thing I have replaced is the belt tensioner. Now I don’t abuse it and do all the scheduled mnx and get the oil changed every 5k miles vs 10K miles, so how a truck has been treated matters BIG TIME if you are buying used. Something about going 10K miles between oil changes doesn’t sit right with me. Look closely and carefully.
    I have been in Iowa since 2018 and haven’t had any issues with rust.
    One gripe is the head unit has been a bit of a disappointment…screen is largely unreadable in daylight and the sound is fairly lousy.
    Only thing I would have done different is gone with the Platinum trim level.
    Cant go wrong with the 2014.
  6. Aug 1, 2022 at 1:01 PM
    doggunner
    doggunner New Member
    2014 Tundra Crew max White
    I have a 2014 CM with 912,000 km
  7. Aug 1, 2022 at 1:19 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Wow. Any major repairs? How much of that is towing?
  8. Aug 1, 2022 at 1:54 PM
    AZBoatHauler
    So.Arizona
    :worthless:
    gosolo, PermaFrostTRD and KNABORES like this.
  9. Aug 1, 2022 at 2:46 PM
    PermaFrostTRD
    Northern NY
    I had 2014 double cab. Truck was awesome and the reason I have a 2019 now (wanted a crewmax and larger gas tank). The only issue I had with the 2014 was the door locks went out on it. Dealer wanted $2k+ (maybe more it was a long time ago) to fix and I’m not good enough to do it myself so I just left the truck unlocked all the time. Nothing in there that wasn’t easily replaceable and when there was, manually locking each door was annoying but successful.
    i recommend a 2016 if it’s in your budget (and a crewmax because of the car seats) for the single best improvement Toyota made to these pigs: 38 gal fuel tank.
  10. Aug 2, 2022 at 6:14 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    I have no trouble with my 2014 SR5. I do need to replace the driver side door actuator. For now I use the key to lock the driver door. I pull 5060 lb dry weight 29’ travel trailer a few times a year with no problems. A guy at the dealership told me when I asked about any past recalls (I bought it used) that most problems were worked out by the time 2014 came out. And the 5.7 V8 has enough power for me. Although a super charger would be nice. :thumbsup:I wanta do more mods and upgrades.
    AZBoatHauler likes this.
  11. Aug 2, 2022 at 6:21 AM
    2014 Black tundra
    2014 tundra sr5
    I do have a squat in the rear when the camper is hooked up. I’m still debating on how I want to address the issue. Many ways to deal with it but I’ll probably go with new heavy rated springs.
  12. Aug 2, 2022 at 2:46 PM
    Cmilla25
    Cmilla25 New Member
    2015 Tundra Trdpro
    2015 Tundra trd pro. With 85k no issues on my end. Can't go wrong with either year. My opinion
  13. Aug 2, 2022 at 2:50 PM
    Yes.....
  14. Aug 2, 2022 at 7:27 PM
    Fabian
    Fabian New Member
    Fabian
    White 2015 tundra SR5 TSS 4x4
    None
    I have a 2015 Tundra 5.7 4x4 and have about 96,000 miles and I love my truck! No issues, I do the routine maintenance and etc. I have a stillen intake and a 3in Toyo tech lift. Now I'm doing a exhaust on it
  15. Aug 2, 2022 at 7:32 PM
    Fabian
    Fabian New Member
    Fabian
    None
    Question to you all
    I wish I could afford a dirty deeds exhaust, but $1500, is a lil steep for me. Saw some YouTube videos of a 3in Carven mufflers, and making it true dual with dual tailpipes. Any reasons for concerns if I do this? Cutting out the factory muffler and putting 2 Carven 3in mufflers, and going dual exhaust.
  16. Aug 2, 2022 at 7:33 PM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    You seriously need to post a picture!
  17. Aug 2, 2022 at 7:37 PM
    Fabian
    Fabian New Member
    Fabian
    None
  18. Aug 3, 2022 at 3:24 AM
    PermaFrostTRD
    Northern NY
    Loss of low end torque going to a 3” dual system.
    Edit: Also, after seeing the pic you posted with the snow, that means you have road salt. Cutting the muffler or any of the exhaust piping to weld in some new mufflers or tail pipes will insure that your muffler & piping falls off in 2-3 years. Ask me how I know. Lots of guys on the forums selling a BAM muffler setup after swapping for a different size (going 10" to 6" or visa versa based on their needs). Not sure if you just want the sound or the look of true duals, but give Keith a call. He can at least tell you what you're looking for and then you can see if you can find it here or on FB groups, etc.
