Ironman UCA noise?
Discussion in 'Suspension' started by Jmccracken1214, May 31, 2022.
  1. May 31, 2022 at 9:22 AM
    Jmccracken1214
    Jmccracken1214 [OP] New Member
    2015 Tundra CM
    I put this stage 1 lift on a few weeks ago and just noticed this noise today. I’m guessing it’s the UCA? Any ideas ?
    I was standing on the step rail, moving the truck
    https://youtu.be/H-vvT6Ja4Co
  2. Jun 1, 2022 at 6:46 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    did you grease the bushings? Torque correct? Was torque done in while truck was in the air or on ground?
  3. Jun 1, 2022 at 7:58 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    That's the sound of the bushings needing to be greased.
  4. Jun 1, 2022 at 8:20 AM
    Jmccracken1214
    2015 Tundra CM
    I’m not sure how to grease the bushings on Ironmans UCA. There’s really no way to do it, the way they designed it. And they never mention of having to grease it.
  5. Jun 1, 2022 at 8:23 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Did you tighten the upper long bolt under load or unloaded? Maybe reach out to them and see what they say? I'm curious on their response.
  6. Jun 1, 2022 at 8:25 AM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    I believe you are supposed to apply a liberal amount of grease to the bushings before installation. I had to do the same when i installed SPC uppers. The upperbolt is also to be torqued when the truck is on the ground, not raised.
    reywcms likes this.
  7. Jun 1, 2022 at 8:32 AM
    Jmccracken1214
    2015 Tundra CM
    The bolt was tightened while the truck was on the ground. I took the nut loose, bounced on it, no sound. Drove it up the road, then tightened around 85 ft lbs, noise is back.
    I sent them the video yesterday, should hear back today. My passenger side is quiet as a mouse.
    here’s a pic of the bushings on their arm, you’d only be able to grease the outside, I don’t see how that would stop this noise.
    Rocko9999 likes this.
  8. Jun 1, 2022 at 2:21 PM
    Jmccracken1214
    2015 Tundra CM
    Ironman4x4 called me and since the noise goes away when I loosen the nut, they're assuming something is wrong with the bushing and are sending me another set of UCA's
  9. Jan 31, 2023 at 9:20 AM
    Kirkhamster002
    Kirkhamster002 New Member
    PJ
    2016 Blk Seq SR5 4x4
    Hello, what is the latest on this? Is the issue gone after replacing the UCA?
    I thought IM uses factory style rubber bushings that doesn't require grease. Can someone confirm?
    Also how is the UBJ holding up? Any issues?
  10. Mar 16, 2024 at 9:14 PM
    Fish2eat88
    Fish2eat88 New Member
    Jay
    2018 silver sky double cab
    295/75 3/2 lift
    Probably over torqued. Just add some thread locker blue and loosen just a little and test it.
