Invincible lower ball joint - Help!
Discussion in 'Suspension' started by BuckWallace, Sep 28, 2021.
  1. Sep 28, 2021 at 7:46 PM
    BuckWallace
    BuckWallace [OP] Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Long story short, I damaged the lower ball joint boot when replacing my suspension and need to replace it. I ordered a new ball joint and rented a press from Advance Auto, but this thing WILL NOT BUDGE! The thing is so stubborn I even bent the freaking C-clamp from the press kit. I now have my front steering torn apart with a now-unusable ball joint. Yes, the c-clip is removed. Any ideas??
  2. Sep 28, 2021 at 8:39 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Some heat around the arm and a lot of force should pop it. Toyota doesn’t technically sell the ball joint separate because they’re not the easiest to get out
    BuckWallace[OP] and Desert Dog like this.
  3. Sep 28, 2021 at 8:45 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    I 2nd this. Apply some heat to that area.
    BuckWallace[OP] likes this.
  4. Sep 28, 2021 at 8:56 PM
    Forcefed
    Forcefed New Member
    2007 Tundra Limited
    6 inch lift, ADS suspension, Alcan custom rear springs, 46 gallon metal gas tank, Full Line-x body, Wheels with 35's, Smittybilt bumpers front and rear, 10k warn winch, custom rack.
    I had to have a shop press them out. The shop was pissed because they broke something on the press trying to get it out. When they gave it back they said this is why they don't do 1 tons. I told them it was off a tundra. They just looked amazed.
    Sumo91 and BuckWallace[OP] like this.
  5. Sep 28, 2021 at 8:58 PM
    empty_lord
    05 rollover special
    i've gone full ape on one and gotten it out with a 4lb brass hammer.. but it was in a pinch and i would NOT recommend doing that.
    Darkness and BuckWallace[OP] like this.
  6. Sep 28, 2021 at 9:36 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Thanks, all. I was about to just call it quits, put it back together, and limp into a shop and have them do it. However, when using the ball joint press tool, I apparently damaged the threads on the ball joint and can't get the castle nut back on without turning the whole ball joint. This seemingly-simple suspension swap has turned into a nightmare just because I wasn't careful and pierced the ball joint boot. Then good ol' YouTube made the ball joint replacement look easy with a press tool, but I guess 12-year-old joints are a little more stubborn... I'll try heating it up tomorrow and pounding it out... :frusty:
  7. Sep 29, 2021 at 5:33 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Well, I tried everything, but that thing isn't budging. I was able to slap it back together so I can hobble into a shop, but there's no way I'm getting it out. Now the next question is whether the shop will be able to get it out, or if I'm going to have to get an entire new lower control arm and have them install it. I should have just paid the $360 for the shop to install my suspension!
  8. Sep 29, 2021 at 6:29 PM
    2mchfun
    Why not just replace the lower control arms complete?
    frichco228 and BuckWallace[OP] like this.
  9. Sep 29, 2021 at 6:30 PM
    2mchfun
    12 yrs bushings probably well worn anyway.
    Hbjeff likes this.
  10. Sep 29, 2021 at 6:48 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    That's my plan. I'm ordering a new LCA tomorrow and will just have the shop do the install assuming they can't/won't get the existing ball joint pressed out. I tried messing with those cam bolts when I did the suspension and there was just no way I was breaking them loose in my garage—definitely need a lift!
  11. Sep 29, 2021 at 6:54 PM
    2mchfun
    PB blaster penetrating oil and a good wrench push it with your foot.
  12. Oct 1, 2021 at 8:21 PM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    Kroil and heat if you’re replacing the LCA. I’ve pulled cam bolts on a few Toyota’s and usually Kroil by itself does it. Soak it early and often. I see you’re in Oregon so no salt here.
  13. Oct 14, 2021 at 6:22 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    So I finally gave up and just replaced the whole LCA. At least that way I have OEM parts. Anyway, the shop marked the cam bolts and lined them back up when installing the new LCA, and the mechanic said he didn't think it needed an alignment. I feel like it drives straight and it doesn't look off visually, but should I get one just to be safe?
  14. Oct 14, 2021 at 6:39 PM
    2mchfun
    Just watch your tires for a few thousand miles. Wear will talk.
  15. Oct 15, 2021 at 7:35 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I recommend getting an alignment done every time you work on your LCA, UCA and steering joints.
    BuckWallace[OP] and TXTundra2722 like this.
  16. Oct 15, 2021 at 8:24 AM
    TXTundra2722
    2015 Black Tundra
    I second the alignment comment... tires cost too much
    BuckWallace[OP] and matictundra like this.
  17. Oct 15, 2021 at 10:39 AM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Thanks, all. I think I knew the answer, I was just secretly hoping everyone would say I don't need one. The local shop charges $60, so it's cheap insurance to prevent uneven wear. Thanks again!
    2mchfun likes this.
