Inverter won't work but still charges phone
Discussion in 'General Tundra Discussion' started by Only1rhodes, Jun 25, 2017.
  1. Jun 25, 2017 at 9:07 PM
    Only1rhodes
    Only1rhodes [OP] New Member
    Cameron
    2016 Tundra Crewmax
    On my 2016 Tundra crewmax. I recently went camping and wanted to blow up mattress with dealt inverter. When I tried it it didn't work, but was charging phones through USB port on inverter...I thought inverter was no good, but I tried inverter in different car and it worked fine... I've checked the fuses and they didn't look blown...I've also tried all my ciggarette lighter ports, nothing...why isn't drawing enough power, and a car does?...Does any know?
  2. Jun 25, 2017 at 9:21 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Check the fuse?
  3. Jun 25, 2017 at 11:10 PM
    Only1rhodes
    Cameron
    2016 Tundra Crewmax
    All fuses for power outlet and CIG lighter looked good
  4. Jun 26, 2017 at 2:47 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Is this the factory inverter? My SR5 didn't come with one :(. The old FJ had one though, it had 2 different wattage "settings"--one with the vehicle running, and one with the vehicle turned off.
    I'd imagine the design is the same. Some of Toyota's add-ons haven't changed designs in literally decades (ex: the cruise control on my '86 4 Runner is the same control I have on my '16 now)
    Only1rhodes[OP] likes this.
  5. Jun 26, 2017 at 8:10 AM
    Only1rhodes
    Cameron
    2016 Tundra Crewmax
    No, this is a Dewalt inverter that you plug in to the CIG outlet
  6. Jun 26, 2017 at 8:10 AM
    Only1rhodes
    Cameron
    2016 Tundra Crewmax
  7. Jun 26, 2017 at 9:48 AM
    DVYota
    DVYota Super stock street truck
    South Carolina
    2014 Sequoia 2021 Tacoma
    Basically stock
    How many watts does it pull?
  8. Jun 26, 2017 at 5:30 PM
    Only1rhodes
    Cameron
    2016 Tundra Crewmax
    140 Watts
  9. Jun 26, 2017 at 5:30 PM
    Only1rhodes
    Cameron
    2016 Tundra Crewmax
  10. Jun 26, 2017 at 5:39 PM
    DVYota
    South Carolina
    Basically stock
    Was the truck running? Have you tried anything else in the cig lighter plugs in your truck?
  11. Jun 26, 2017 at 8:21 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    ^^^^^^^^^^ I would try it out on different cigarette lighter ports with the truck RUNNING. If you have already tried this, I am betting it is not pulling enough electricity from truck. Good Luck!
    DalTee likes this.
  12. Jun 26, 2017 at 9:04 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Cadillacs are notorious for blowing fuses after not working the unit. Might need to buy a real inverter and relocate it under the seat for actual ability to use it
  13. Jun 26, 2017 at 10:05 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    USB charging indicates the inverter is getting power. The inverter works on another vehicle. I'm guessing the inverter has a voltage sensing circuit that shuts down the inverter if it doesn't see sufficient voltage. The only thinkg I can think of is that the lighter ports in your 3rd gen may be voltage regulated to +12 volts, and the inverter expects a higher voltage that would normally be present only when the vehicle is running.
    Use a voltmeter and check the running voltage of the lighter ports with the Truck running. Then do the same in the car in which the inverter works. I bet you see a difference.
  14. Jun 26, 2017 at 10:16 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    This guy knows his electrical
  15. Jul 5, 2017 at 4:02 AM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    Pretty sure a 140W, 14V, therefore 10 Amp inverter, P=IE, won't run a 120V compressor. Check the amp rating on your compressor.
  16. Jul 6, 2017 at 7:21 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    What is the actual voltage on the lighter? It may be less than 12-14 v. A phone charge only uses 3-5v
  17. Jul 9, 2017 at 3:21 PM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    Just look at the Amp draw on your 120V compressor.
