Intro/Payload Capacity
Discussion in 'New Member Introductions' started by 22TundraTRDPRO, Jun 6, 2024.
  1. Jun 6, 2024 at 9:45 AM
    22TundraTRDPRO
    22TundraTRDPRO [OP] New Member
    Aram
    2022 Toyota Tundra TRD PRO
    Slide out kitchen (Bushtucker kitchens), Diamondback HD cover, Truss Uptop bed rack, roof Condor Overland 2 RTT, Uptop Alpha roof rack, pelican cases, saw 60% backseat delete
    Good day and thank you for allowing me in the forum. Name is Aram and I reside in SOCAL, I just embarked on my overlanding project converting my 2022 Tundra TRD PRO. components of the buildout include:
    1. Diamondback HD Cover
    2. Pull out kitchen/drawers from Bushtucker kitchens, Australia https://www.bushtuckerkitchens.com.au/
    3. Uptop Truss bed rack
    4. Roofnest Condor Overland 2
    5. Roofnest crossbars
    6. 300 watt Solar panel
    7. SHE rear seat delete
    8. Anker F2000 power station
    9. Uptop Alpha Roof Rack
    10. Pelican cases
    11. etc.
    80% into the project, I found out that I should be using the 1350lbs load capacity specific to my vehicle and not just by subtracting the truck's curb weight from its GVWR written on the driver door panel sticker and the difference is substantial!
    Well, 4 175lbs passengers and 22 gallons of gas at roughly 6lbs a gallon adds up to 832 pounds leaving me with 482lbs! Between the 190lb roof tent and CBI front and rear bumpers with swing outs, I am already over without the winch, cargo, water, etc. I am projecting I will be at around 1950-2000lbs. I have seen many similar buildouts and I am not going above and beyond from what I have seen.
    I am sure many of you have experienced the same and any recommendations would be greatly appreciated.
    P.S. I've decided on manual airbags (to eliminate the weight of the compressor) and the Powerbreak upgrade.
  2. Jun 6, 2024 at 2:18 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! There have been many discussions - and complaints - about the Tundra's relatively low payload. A search on here for that topic will keep you busy reading for awhile!
    22TundraTRDPRO[OP] likes this.
  3. Jun 6, 2024 at 2:51 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Welcome from the valley.
    How will you air up your tyres after a overland adventure? I think on board air is more important than half the stuff you have listed
  4. Jun 6, 2024 at 3:06 PM
    22TundraTRDPRO
    Aram
    Of course! ARB dual in the bed on a Molle panel right next to the 400W outlet, this is what it will look like.
  5. Jun 6, 2024 at 3:07 PM
    22TundraTRDPRO
    Aram
    Will be using the Rago bed rail mounts.
  6. Jun 6, 2024 at 4:37 PM
    Welcome from NY.
