Interrior dome lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by Humptundra4x4, Jun 11, 2018.
  1. Jun 11, 2018 at 9:05 PM
    Humptundra4x4
    Humptundra4x4 [OP] New Member
    Slapout al
    2016 tundra crewmax tss
    Bullnose bumper, step bars, campershell
    Just bought a 2016 sr5 tundra with 90k miles only issue is the lights will notcome on when door is open i can switch the lights on with the on/door/off switch but when on door nothing happens i have checked all door switches and all work according to meter. All fuses under hood are good and the cargo light does same thing any help would be greatly appreciated.
    4x4_Angel and TXRailRoadBandit73 like this.
  2. Jun 11, 2018 at 9:08 PM
    Welcome from Texas, sorry to hear about your problem, someone else on here will chime in and assist
    Humptundra4x4[OP] likes this.
  3. Jun 11, 2018 at 9:18 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  4. Jun 11, 2018 at 9:27 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Hello and welcome from Texas!
    This may be a dumb question but....have you checked the bulbs? Are they good? Are there any even there?
    I know....i sound like the guy saying "is your computer plugged in? Is it turned on?" But you would be surprised....
    TTund16 and Y0TA PR0 like this.
  5. Jun 11, 2018 at 9:29 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Is it in the general set-up on the head unit?
  6. Jun 12, 2018 at 3:33 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Check switch positions
  7. Jun 12, 2018 at 3:34 AM
    Welcome from Ohio!
  8. Jun 12, 2018 at 4:08 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    Did you check the on/door/off switch also? and welcome
    -Jason
  9. Jun 12, 2018 at 6:29 AM
    Humptundra4x4
    Slapout al
    The on door off switch will make the lights come on when in on position but not when door position. Are there seperate bulbs for the door position? I guess the main thing thats throwing me off is that the door and cargo switch both work in on position but neither work when in door position. Thanks alot for the quick response.
  10. Jun 12, 2018 at 7:59 AM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    if is not the switch at the door it could be a bad ON/DOOR/OFF switch. Get a used one off eBay or junkyard.
  11. Jun 12, 2018 at 8:32 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Same bulbs. Are you sure the switches are in correct position? Removing the switch panel is fairly simple if you want to test the switches.
  12. Jun 12, 2018 at 8:41 AM
    Humptundra4x4
    Slapout al
    Thanks i have tested all door switches and when the doors are open the buzzer is on but i can push in door switch and cuts off im gonna try to borrow a know good switch and see if thats it
    4x4_Angel and Watt maker like this.
  13. Jun 12, 2018 at 10:17 AM
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    Rocker switch for my interior lights (in my 2017 CM SR5) - on the drivers left of the steering wheel.
    The switches on the dome light should kick on when you press the button on the light itself. If that doesn’t work it’s something to do with that fixture I’d guess.
  14. Jun 12, 2018 at 10:27 AM
    Humptundra4x4
    Slapout al
    Positive the switch is in the right position i guess im just so confused because the interrior light and cargo light both only work when the switches are in on position neither work on door ill dig more into it when i get home .
    4x4_Angel likes this.
  15. Jun 12, 2018 at 11:07 AM
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    yeah.. gotta be something with the door sensor... either not working (which you said it was) or someone/something happened so its no longer connected to the lights... previous owner could be one of these damn people modifying their trucks :rolleyes:
  16. Jun 14, 2018 at 7:10 AM
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
  17. Jun 14, 2018 at 7:18 AM
    wigsplitter
    wigsplitter New Member
    DFW Texas
    2018 SR5 TSS Crew Max
    I see that people are trying to help but I just want to be clear that when you say they work with that switch in the on position but not the door position. That rocker switch is a 3 position switch. On, Door, Off. Push top for on push bottom for off but in between is the Door position. Make sure that it is in the middle position and not just off. I've hit that switch and accidently turned off my interior lights before.
    HecticEnergy likes this.
  18. Jun 14, 2018 at 8:32 AM
    Humptundra4x4
    Slapout al
    Still not figured out but i am 100% positive switch is in correct position all lights come on when switch is turned (on) but when in (door) position no lights come on but the dash comes on and a buzzer or dinger comes on when door opens as far as testing the door switches im hoping i done correctly i removed each door switch and put one meter lead on the ground part and other lead were the wire clips then pushed the switch in to close and it ohmed out.
  19. Jun 14, 2018 at 1:46 PM
    geno0506
    geno0506 New Member
    Michael
    Welcome from Texas!
  20. Jun 15, 2018 at 3:48 AM
    astro-jason
    If the key chime works and the dash lights up when you open the doors, I would say the door switches are good. I would check the switch on the dash next. The door portion of the switch could be faulty.
    -Jason
    Watt maker and HecticEnergy like this.
  21. Jun 15, 2018 at 9:15 AM
    Humptundra4x4
    Slapout al
    Thanks that was my thoughts also im either going to order one from ebay or try to convince somebody to let me use theirs to test it
  22. Jun 25, 2018 at 7:13 AM
    Humptundra4x4
    Slapout al
    So after lots of hair pulled out and tought the kids new cuss words. I decided to take the truck to toyota and they tested everything and said its a bad main body ecu.
  23. Jun 25, 2018 at 7:31 AM
    deerfarmer
    deerfarmer New Member
    Welcome fro PA.
  24. Jun 25, 2018 at 7:48 AM
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Glad you got it figured out!
  25. Jun 25, 2018 at 7:53 AM
    Humptundra4x4
    Slapout al
    Ya i guess so just hope i can find a used one toyota wants 1200 for it if i cant find a used one ill just buy 4 flashlights and keep in each door.
  26. Jun 25, 2018 at 8:08 AM
    nodak67
    nodak67 New Member
    JR
    sounds like someone tried to replace the light bulbs and shorted out the BCM. I hear about that a lot in the Tacoma forums people shorting out the BCM. usually happens when using a metal adapter trying to pull out the light bulbs and touching the metallic surround and causing a short.
    usually the owner just lets it go (due to cost of BCM replacement) since it usually only affects the interior lights.
    just use duct tape to pull out the lights, less likely to blow a BCM :)
  27. Jun 25, 2018 at 8:50 AM
    Humptundra4x4
    Slapout al
    Ya that's what they asked me but being bought used i dunno
