Intermittent wiper switch upgrading
Discussion in 'General Tundra Discussion' started by Tundrapwr16, May 23, 2018.
  1. May 23, 2018 at 8:48 PM
    Tundrapwr16
    Tundrapwr16 [OP] Best Toyota made ever
    Rob
    California
    2000 RC 3.4 liter white work truck .
    Pioneer radio and intermittent wiper switch and led lights. I also use AMZOIL Products only..
    So what’s the low down on changing a non intermittent wiper switch assembly over to a intermittent wiper assembly? And how do you take the bezel off the steering colum ?
  2. May 24, 2018 at 10:50 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    :sorry:
    Sub'd for info
  3. May 24, 2018 at 11:24 AM
    Tundrapwr16
    Rob
    California
    I think it will cross over and plug n play.i think!!!!
    15whtrd likes this.
  4. May 24, 2018 at 2:52 PM
    Uncle_Charlie
    Uncle_Charlie New Member
    2018 Tundra- Work truck package
    To remove the bezel, center the steering wheel. Turn the steering wheel 90 degrees either direction and look at the column straight on. There will be a screw. Remove it. Now turn the steering wheel 90 degrees from center the other direction and remove that screw. The bezel will now separate. As I recall, there is one screw that holds the switch in place. There is an electrical connector that has to be separated. I was concerned that the clip would break as far as I had to move the retainer, but it didn't. Other than that, it is just a matter of replacing the part.
    Midnite72 likes this.
  5. May 24, 2018 at 2:56 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  6. May 24, 2018 at 3:33 PM
    Kevin1741
    Kevin1741 New Member
    Very easy, recently purchased the part from roman and took 5 min to install!
    Roman and boostedtrdpro like this.
  7. May 24, 2018 at 6:14 PM
    Tundrapwr16
    Rob
    California
    Cool thank you guys a bunch. I’ve never done this before but with out that intermittent wiper switch. It’s a royal pain in the Rain Lol. Will keep you guys posted on my findings and success..
  8. May 26, 2018 at 2:59 PM
    Tundrapwr16
    Rob
    California
    Well thank you for the great help. Did what uncle Charlie had said and removal and install went super easy And it works great.the only Blind spot is there is a tab on the front side that you need to push in with a small flat blade screwdriver gently to unclip unit from Column. If you try to pull it off with out doing that you’ll cause a huge amount of damage. Thanks again everyone for tour help. Saved me a bunch of money . And I used a original Toyota switch not aftermarket.
  9. Jun 15, 2018 at 2:33 AM
    EastGuy
    EastGuy New Member
    2014 Tundra SR - Can I replace the wiper switch on the steering column with one that has intermittent option, if my gear shift is also on the steering column? Will the wiper switch with intermittent option fit? I cannot find anywhere the dimensions of the wiper switch with intermittent option. Thanks in advance.
  10. Jun 15, 2018 at 5:05 AM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    wait , what ? This is plug and play how did I not know this !!! @Roman you have an order for one sitting on your desk now to ship to Flowood MS ! I love my Tundra and got a deal on an SR that I could not turn down but no intermittent wipers has been a pain in the ass ! I did not realize that it did not have them until it was misting several days after I purchased it .....:frusty:
    Roman likes this.
  11. Jun 15, 2018 at 6:03 AM
    Tundrapwr16
    Rob
    California
    Hey EastGuy, follow my instructions that we’re perfect from fellow friends on here. Super easy and super clean install. Literally plug and play. Use only Stock factory Toyota parts. Mine has the gear shifter on colum too. It’s a great feeling having this switch versus the low end version. Love it
    Scpringle likes this.
  12. Jul 13, 2018 at 6:44 AM
    Fishin
    Fishin New Member
    Are there any instructions on this site? I have a 15 SR. Thanks.
  13. Jul 13, 2018 at 9:51 AM
    Scpringle
    Jackson MS
    @Fishin I did my 15 SR a month ago . Just search youtube and it shows a Tacoma being changed . Works the same way , very easy videos . 15 mins tops and that taking your time ....
  14. Jul 13, 2018 at 6:42 PM
    Fishin
    Fishin New Member
    Thanks!
  15. Jan 2, 2020 at 5:37 PM
    xtopher
    xtopher New Member
    Christopher
    2020 4x4 SR Long Bed
    Part 84652-02710 works great in my 2020 Tundra SR 4x4 Long Bed with worktruck package (BX) that came with non-intermittent wipers. The only slightly tricky part was pressing on the tongue of the retaining clip. This is the tongue part that is on the new wiper stalk. Press it with a screw driver and wiggle the wiper stalk off.
    Note that there is also a 845652-02610 that seems to go with older vehicles, but I was never able to for sure determine the difference from the -02710.
    Meanjoe and Roman like this.
  16. Jan 4, 2020 at 10:28 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    I see another mod in order, this site is never ending!
    Roman likes this.
  17. Jan 5, 2020 at 5:11 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Yep...Might as well add the automatic head light switch and the lighted key switch while you're in there. :D
  18. Nov 26, 2020 at 8:52 AM
    Meanjoe
    Meanjoe BT3 USN
    Wayde
    Salem, Oregon
    SOLD: 2020 Tundra SR 4x4 Double Cab Super White Long Bed
    Thank you for the info...I just bought a new 2020 Tundra SR5 4x4...I will be doing this....
  19. Nov 28, 2020 at 7:10 PM
    tundraterrence
    tundraterrence New Member
    Terrence
    Winchester, TN
    2021 Tundra SR5 DC- SOLD
    Just bought a 2021 SR. This is on the short list of “to do’s”. This site is a wealth of information.
    Meanjoe likes this.
  20. Mar 23, 2021 at 9:12 PM
    Tundra Bammer
    Tundra Bammer New Member
    2021 Tundra SR
  21. Mar 24, 2021 at 8:37 AM
    tundraterrence
    Terrence
    Winchester, TN
    Bammer, I called Sparks Toyota to confirm. I was told it would be direct swap for the 2 speed unit on my 2021 SR. I bought one and hadn’t had the opportunity to do the swap when I was involved in an accident and incredibly they totaled my truck. I couldn’t find a comparable SR so I picked up an SR5.
    I have the switch. I can make you a killer deal on it if you want it.
  22. Mar 24, 2021 at 10:55 AM
    Tundra Bammer
    2021 Tundra SR
    Terrence, I'm definitely interested in the switch. I just created this account last night so you'll have to tell me how we proceed from here.
  23. Mar 24, 2021 at 1:38 PM
    tundraterrence
    Terrence
    Winchester, TN
    Bammer, PM me with your email address. I can send you a few pics of the switch and additional info. We can go from there.
  24. May 10, 2022 at 6:04 PM
    Pbuch
    Pbuch New Member
    Phil
    2018 Tundra SR
    So this is an older thread, but I just bought a 2018 SR from a friend and didn’t like the 2 position switch. Got an intermittent switch from a local wreaking yard and with the help of this group, just installed it. Easy… and thanks!
  25. May 10, 2022 at 6:57 PM
    Tundrapwr16
    Rob
    California
    Yes sir thanks to the nice guys on here that are willing to help fellow tundra owners it’s so cool learning new tricks to upgrade certain parts on these different models. Thank you again everyone in helping me and the other guys on here so cool..
  26. Jun 16, 2022 at 9:02 AM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    Just ordered mine today. I can't tell you how pissed I would get every time it rains and I'm driving the truck.
    Does anyone know if it gives you few wipes when you spray the windshield cleaner? That's another thing that really grinds my gears....
  27. Jun 26, 2022 at 8:01 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    AFAIK when u hit the washerfluid it does give you a few wipes... but not sure if thats a standard or not.. I did'nt even think that intermittent wipers were an option.
    Gainer[QUOTED] likes this.
  28. Jun 27, 2022 at 5:11 AM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Hard to believe isn't it.... I installed the new switch, it took more time to round up the tools than the install took.
  29. Jan 2, 2023 at 3:28 AM
    Daniel752
    Daniel752 New Member
    Great thread. Looked up which models this switch fits and it lists "2014 Toyota Tundra 1794 Edition, Limited, Platinum, SR, SR5". Recently purchased my 2014 Tundra used - looks like a service vehicle given the lack of emblems - manual does not indicate anything other than, 'Tundra'. How do I determine what model I have (2014 4x4 long bed) to determine if I can install this upgrade?
  30. Jan 5, 2023 at 6:00 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If you dont have intermittent wipers it has to be an SR as SR5 it came standard (AFAIK). I dont think the SR had badges anywhere. If you make an account on toyota.com/owners and put in your VIN it will give you your truck specs though
