Intermittent vibration even after new tires, alignment, and inspections
Discussion in 'General Tundra Discussion' started by Marty 4x4, Jan 20, 2025.
  1. Jan 20, 2025 at 6:52 PM
    Marty 4x4
    Marty 4x4 [OP] New Member
    2019 limited tundra 4x4
    none
    I bought a 2019 Tundra limited double cab in 2022 with 50,000 it had a little highway vibration that comes and goes .starts around 60 to 65 and again only intermitantly, i put on new tires and the vibration continued, brought the truck back to the tire shop and had the tires rebalanced and the vibration got slightly better . the tires started to wear badly on the outside edge of both front tires . I had the alignment done and was told it was good now the vibration has gotten worse but im guessing its from the worn out tires .I am planing on putting on Michelins XLT as 2 HIghway tires . the wheel bearings are good no movement both front and rears , and the front end is tight no bad components at all very tight , truck now has a little over 100,000 . Vibration hapens under power and coasting and im stuck . allso truck had a minor hit in the passangers side rear end nothing serious bumper and fender damage no damage to the frame. any help would be appreciated.ps allso changed then front rotors and new pads.
  2. Jan 20, 2025 at 6:54 PM
    Stock suspension? No lift, leveling kit, etc?
  3. Jan 20, 2025 at 7:08 PM
    At 100k miles your factory shocks are worn out. May not have failed outright, but are not providing the dampening they used to. Worth replacing. A small shake or vibration gets amplified by inability to dampen. Worn shocks also leave the tires outside of the normal resting point more potentially creating increased tire wear.
    Florida AF and 2mchfun like this.
  4. Jan 20, 2025 at 7:50 PM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    I had the exact same problem on my 2011. I replaced my shocks all the way around, had my tires rebalanced, and the front end aligned. Vibration gone.
  5. Jan 21, 2025 at 8:44 AM
    2mchfun
    I agree shocks. However, just cuz you should, check out the driveshaft components too and verify all is well there.
    Raven67 and Thumper_6119 like this.
  6. Jan 21, 2025 at 4:42 PM
    Marty 4x4
    none
    No lift or upgrades , original shocks . vibrates between 62mph and 70 mph at higher speeds it stops . Still think its the shocks would it stop at higher speed ? thanks for the responses
    Florida AF likes this.
  7. Jan 21, 2025 at 4:44 PM
    Marty 4x4
    none
    drive shaft seams fine did a visual inspection . would the shocks needing replacement would that cause the uneven wear to outside edge of the tires?
    2mchfun likes this.
  8. Jan 21, 2025 at 5:09 PM
    Thumper_6119
    I had to replace my UCA's as they were worn out as well as my shocks. My truck wouldn't align correctly, and my tires started to wear weird, which made the whole issue worse. After the balance and alignment, the vibration was gone.
    2mchfun likes this.
  9. Jan 21, 2025 at 5:54 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Vibration when on or off the gas sounds like a bad u joint to me. Had that happen on a Ford truck. Don't just inspect it, pull the driveshaft off & check each u joint closely.
  10. Jan 21, 2025 at 5:57 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    100k on stock shocks? Haha I'd have started there.
  11. Jan 21, 2025 at 6:17 PM
    ZPMAN
    Minnesota
    Check both upper control arm bolts and make sure they are tight. Was the tire hit in the previous accident?
  12. Jan 22, 2025 at 3:17 PM
    Marty 4x4
    none
    Tire was not hit . U joints are tight no play at all . new shock/ struts may be the answer . any recommendations for new ones ? again thanks for all the advice the more i think about it it seams to happen more often on less than perfect roads.
  13. Jan 22, 2025 at 4:41 PM
    2mchfun
    @memario1214
    Thumper_6119 likes this.
  14. Jan 22, 2025 at 5:00 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Yep. At mile 60,001 you begin your shock borrowed-time journey.
    Work with Mister Missoula, Colton (memario1214), for your new shocks. It gets no better nor easier than his customer service at Hotshot Offroad.
  15. Jan 22, 2025 at 5:13 PM
    Thumper_6119
    This
    Colton hooked me up with my suspension components.
  16. Jan 28, 2025 at 5:46 AM
    xcalbr2
    xcalbr2 New Member
    Colton is the Man!
