Intermittent steering difficulty
Discussion in '1st Gen Tundras (2000-2006)' started by brigdh, Feb 12, 2022.
  1. Feb 12, 2022 at 7:26 PM
    brigdh
    brigdh [OP] New Member
    My 2002 Limited has been giving me some weird steering issues lately. I'll turn the wheel (left or right) and I'll hit a random spot where it is like the power steering cut out - the wheel gets very difficult to turn compared to normal. I can continue to turn the wheel with effort to get through the sticking point, or I can back off a bit and then continue my turn. Either way, the steering returns to normal for a time.
    I don't hear any noises when this happens.
    I replaced all the front ball joints about 6 months ago, before this issue started happening.
    About a week ago I flushed the power steering fluid and I thought that fixed the issue for a day or two, but it was back soon after.
    Suggestions?
  2. Feb 12, 2022 at 7:27 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Bleed the power steering system if you haven't. You might have an air pocket.
    DaWhiteTundra likes this.
  3. Feb 12, 2022 at 7:44 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    One thing to potentially look at is the steering shaft U-joint (assuming tundras have them). Not saying it is this, but the same issue happened to me on my f150 and it was the u-joint. Essentially the joint wears out and becomes becomes difficult to flip over, but once the joint flips then it becomes easy to turn again until the joint has to flip over again. Take it for what it’s worth
    looks like part #4529034010.
  4. Feb 12, 2022 at 9:51 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    It’s most likely the steering shaft u joint. That’s what mine was. There’s this plastic insert in there that binds. Just grease it.
    des2mtn and Jack McCarthy like this.
  5. Feb 13, 2022 at 4:18 PM
    brigdh
    Welp, I made a mess.
    I tried lubing the joint. Made the problem worse. As I tried to figure out why, the u joint started breaking apart. So, I'm prioritizing a replacement. I'll have to re-evaluate the issue after that work is done.
  6. Feb 13, 2022 at 4:25 PM
    Jack McCarthy
    Bill
    North of Boston
    Hmmn, maybe I should replace mine. It looks like its held together by rust.
    bmf4069 likes this.
  7. Feb 13, 2022 at 4:34 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    I first used wd-40 and that worked for 100 miles or so. Then used marine grease on mine (hoping it’d stick and work better) and it made it worse as well. Ended up replacing it and all was well. Once a u-joint goes that’s pretty much the end for it. Better off just replacing as you’re doing
  8. Feb 13, 2022 at 4:52 PM
    Aerindel
    Aerindel New Member
    Montana
    At least the good news is, you know what the problem was.
    Mater likes this.
