Intermittent startup issues
Discussion in 'General Tundra Discussion' started by Footballfan33, Jan 1, 2023.
  1. Jan 1, 2023 at 9:20 PM
    Footballfan33
    Footballfan33 [OP] New Member
    I’m having intermittent odd starting sounds.
    Battery tests good. No idiot light on.
    Today upon startup it kept trying to fire after letting off the key and did not start. Retried 2 more times and weakly started.
    Thoughts?
    2018 Tundra
  2. Jan 2, 2023 at 12:15 AM
    Mfaley
    Mfaley New Member
    2015 CM SR5
    5100’s, Coachbuilder 3+ shackles, TRD pro grille on 18” Fuel Mavericks
    I have that issue and it’s usually always a cold related problem. Pretty sure it’s the E85 content sensor that causes this issue, but I’ve never had mine flashed to fix it. Supposedly there’s a dealer flash that solves this.
    Footballfan33[OP] likes this.
  3. Jan 2, 2023 at 1:33 PM
    Footballfan33
    How cold does it have to be? It was not below 70 here when it happened. (Houston)
  4. Jan 2, 2023 at 1:57 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Reset the ethanol reading if you can or check and see if you fall under a reflash from the dealer.
  5. Jan 2, 2023 at 6:46 PM
    Footballfan33
    Yeah I’m taking it in tomorrow for a free 30 min diag.
  6. Jan 2, 2023 at 7:20 PM
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Eibach Pro Sport Shocks (1.25in), RAS HD, Sumo Springs, HAWK Talon Rotors, OEM Tow Mirrows, Lund Hard Fold Tonneau, ESP Storage, Stampede Flares, Husky xAct Fit liners, General Grabber ATX 275/60R20
    If your truck is Flex Fuel and you have less than 80k miles, show this to service advisor at Toyota. It worked out for me about 1yr ago. Good luck!
  7. Jan 3, 2023 at 3:31 PM
    Footballfan33
    How do I tell if it’s flex fuel?
  8. Jan 3, 2023 at 5:45 PM
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Should have E85/Flex Fuel across gas cap. Maybe on sticker under hood. Could also lookup VIN on Toyota site and lookup all options.
  9. Jan 4, 2023 at 4:07 PM
    Footballfan33
    Thanks. It’s apparently not a flex fuel. Nothing was on the gas cap and the sticker says gasoline/ethanol with no mention of e85 or flex fuel.
    One thing I forgot to mention is that sometimes on the start up, the power seat does not move into position. This usually coincides with the poor start up issue. Once I get driving, I realize the seat is too far back, and the steering wheel is not properly adjusted. Then I have to put it in park and hit the memory button.
  10. Jan 5, 2023 at 1:57 PM
    Footballfan33
    Just left the Toyota dealership. They couldn’t reproduce the condition and there are no codes stored.Great!
  11. Jan 18, 2023 at 4:14 PM
    Footballfan33
    Update:
    Took it to my friend’s Lexus dealership and they said the bulletin 16CM provided above does apply to my truck. Apparently, on my model, they only Label when E85 is not compatible. I’m supposed to hear back tomorrow with more info.
  12. Jan 18, 2023 at 4:23 PM
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    @Footballfan33 I'm glad this may work out for you as well! Wish I could remember and thank who originally posted it. Keep us posted on the outcome.
  13. Jan 19, 2023 at 10:24 AM
    Footballfan33
    It was the fuel pump. On back order forever
