Intermittent radio problem
Discussion in 'Audio & Video' started by e019404, Aug 29, 2022.
  1. Aug 29, 2022 at 8:03 AM
    e019404
    e019404 [OP] New Member
    2015 Tundra 4WD
    I have a 2015 SR5 crewmax. I'll be driving along and the radio will lock up. The sound stops, the display freezes. It won't accept inputs on the touch screen, etc. The only thing that works is to push the power button and hold for about 5 seconds to restart the system. Any help is appreciated. thank you.
  2. Aug 29, 2022 at 11:54 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Try updating the firmware.
    If that doesn’t fix it, it’s a sign that you should upgrade to aftermarket.
  3. Aug 29, 2022 at 12:25 PM
    e019404
    2015 Tundra 4WD
    Thanks for the reply. I assume I have to go to the Toyota service dept to upgrade the firmware on the radio, correct?
  4. Aug 29, 2022 at 2:02 PM
    BrandonL812
    Brandon
  5. Aug 29, 2022 at 4:35 PM
    e019404
    2015 Tundra 4WD
    I updated the software or firmware per your instructions and it worked. I'll see if it fixed the intermittent freeze up problem on my next long drive. Thanks for the info.
    BrandonL812 likes this.
  6. Aug 29, 2022 at 4:53 PM
    BrandonL812
    Brandon
    Great to hear. Definitely follow up if it starts acting up again.
  7. Dec 8, 2022 at 6:01 PM
    Dooders
    Dooders New Member
    D
    2014 MGM Dbl cab SR5 TSS
    The download website doesn’t let me download. Did they update the website? Can anyone else try the website and make sure it’s not just my computer acting up? Thanks.
