Intermittent "No Signal" on reverse camera
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraPrime408, Sep 30, 2024.
  1. Sep 30, 2024 at 11:03 PM
    TundraPrime408
    TundraPrime408 [OP] New Member
    Lloyd
    2016 Toyota Tundra
    Hi guys,
    I'm needing some of your greatest expertise on this issue I'm having. My reverse camera has been intermittently been losing signal and just most recently I think it's finally done because all it just says now is "No Signal". I do have an aftermarket deck (BOSS Audio) however the back up camera is still OEM.
    I've checked on a few car audio places but they're charging an arm and a leg just to take a look and honestly, it's just not in my wheelhouse to fork up at the moment.
    Any advice would be greatly appreciated.
    Thanks!!
  2. Oct 1, 2024 at 4:55 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    If you know a fellow Tundra owner. Swap cameras real quick. That'll tell if you it's the camera or the wiring
  3. Oct 4, 2024 at 5:55 PM
    MarkM0369
    MarkM0369 New Member
    Mark
    2017 Tundra SR5 4x4
    275/70 KO2, Pro Hood Bulge and grille, OEM fender flares, Fox rear shocks
    My first check would be the plug that goes up into the tail gate, that you unplug to get the tail gate off, just unplug it check all the wires are still good and didn’t rub,or get cut on anything, then clean the connector and re seat the plug and see what’s up
