Intermittent cruise control
Discussion in '2nd Gen Tundras (2007-2013)' started by twotoms2, Jul 31, 2019.
  1. Jul 31, 2019 at 9:53 AM
    twotoms2
    twotoms2 [OP] New Member
    Robert
    2009 Tundra, base,4.7, 4X4
    added tow controller
    Cruise is intermittent and making me crazy. Anyone have insight into this problem? Start truck, push cruise button, light comes on but cruise won't set. Travel down road and hit set again and it works. Tap brake and cruise responds, press resume and no response. press on/off switch and dash light remains on but cruise won't respond but can't turn light off. Stop engine, restart, now light dose not come on, travel 5-50 miles trying on off button occasionally and finally it comes on. Attempt to set, either no response OR sets normally or can reset speed up or down and brake and resume, all good. stop at intersection and cruise light stays on but will not respond to commands, light stays on cannot turn off without stopping engine. Drove 400 miles with no cruise. Took to dealer who replaced cruise switch, checked out okay. Drove 80 miles and cruise problem is back. Sounds like bad connection somewhere right? checked all connections, brake light switch, etc. found nothing. now questioning relays or computer, or brake light switch.
    Local mechanic can't detect any codes etc. Dealer is 90 miles away and $105 an hour. Need some input please.
  2. Jul 31, 2019 at 9:55 AM
    Cement
    Cement ...
    2019 Cement Trundra TRD
    What speeds are you trying to engage it at? No doubt this isn't your problem, but just in case... cruise wont engage under 28mph I think.
    08crewmax likes this.
  3. Jul 31, 2019 at 9:58 AM
    avt007
    avt007 New Member
    Rob
    2010 Silver Tundra Double Cab
    Might be a bad slip ring in the steering wheel.
    Black Wolf likes this.
  4. Jul 31, 2019 at 10:01 AM
    15whtrd
    15whtrd Mr. Blonde
    Could be the clock spring.
    NewImprovedRon and Black Wolf like this.
  5. Jul 31, 2019 at 1:53 PM
    twotoms2
    Robert
    I'll have to check your suggestions out and let you folks know. Appreciate your input. Oh,by the way, this afternoon in the Pouring Rain it worked flawlessly.
  6. Oct 14, 2019 at 8:17 AM
    Gunnyart
    Gunnyart New Member
    Art
    2007 Double Cab 5.7
    Did you ever sort out the problem? I'm have the exact same type of problem with my '07.
    I replaced the C.C. Stalk and it was still acting intermittently, so I replaced it again because fiddling around with it I could get it to work occasionally so it seemed like I must have got a faulty one but the new one doesn't work right either.
  7. Oct 14, 2019 at 8:29 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    My cruise control wouldn’t turn on at all and it was both the clock spring and cruise control switch. My specialist shop showed me the schematic of how they made the diagnosis. It’s fairly complex (to a layman like me), perhaps another mechanic that specializes in Toyota’s or imports is your best bet.
  8. Oct 15, 2019 at 8:03 AM
    KArnoldX85
    KArnoldX85 New Member
    Kevin
    Atlanta, GA
    2008 Black SR5 TRD Off Road Crew Max 5.7L 4x4
    I just got the truck gimme a minute Ok who’s got something for sale?
    Thank you for this answer and this post, ive been having mad issues with my CC as well, just randomly works, ive pretty much given up on it until now, is there a DIY post or is this complex enough to take it to a dealer?
    also how much did it cost to have it done?
  9. Oct 15, 2019 at 9:40 AM
    Rph74
    Rph74 New Member
    Springfield,MO
    I paid $865, but you could probably get it done for about $300 cheaper if you buy your own parts, and if you have a mechanic that will install it for you. I do have a mechanic that would’ve done it that way for me, but I needed the job done (it was a Friday and I needed the truck for a road trip Sunday) so I paid the extra at the specialist shop.
    $95 of that total was just the labor to diagnose the issue.
  10. Oct 15, 2019 at 9:44 AM
    Rph74
    Rph74 New Member
    Springfield,MO
    In my case the on/off function is what failed on the cruise control switch, while everything else still worked. And the clock spring wasn’t communicating the cruise control functions to the computer. Every other function on the clock spring still worked.
  11. Oct 16, 2019 at 2:33 PM
    Gunnyart
    Gunnyart New Member
    Art
    2007 Double Cab 5.7
    Replaced the clock spring with one for $20 from Amazon. Works perfect. Thanks
    And it took all of 15 minutes to do with no special tools. I did replace the CC stalk before so if the old one was also bad I don't know but the clock spring was definitely to culprit.
    Rph74 likes this.
