Intermittent crank no start 08 tundra
Discussion in 'New Member Introductions' started by Bber08527116, Apr 6, 2022.
  1. Apr 6, 2022 at 12:00 PM
    Bber08527116
    Bber08527116 [OP] New Member
    08 tundra
    Have a 08 tundra changed fuel pump mechanic said they couldn't figure out why it has intermittent starting issues so they have up need help changed fuses checked them all messed with the fuel control module when it doesn't start there's no fuel going to the rail . Suggestions?
  2. Apr 6, 2022 at 12:03 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Signal/Voltages (wiring) all good at the module and pump?
  3. Apr 6, 2022 at 12:03 PM
    Bber08527116
    08 tundra
    Took apart fuel control module doesn't looked fried was changed about 5 years ago. Could it be the connections aren't connected good on the fuel pump because I just had that changed ? Thought fuel pump was the issue but it still has no start randomly
  4. Apr 6, 2022 at 12:05 PM
    Bber08527116
    08 tundra
    I'm only getting 12 volts on one side of the fuel pump module with key on the red and blue wires I don't have nothing on my multimeter?
  5. Apr 6, 2022 at 12:13 PM
    Bber08527116
    08 tundra
    One thing I noticed it started with a boost and second time I had it towed didn't start had it out on a flat bed dropped it off and started up could the connections be loose or bad on the fuel pump or control module ?
  6. Apr 6, 2022 at 12:26 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Let me see if I can find wiring
  7. Apr 6, 2022 at 12:29 PM
    14burrito
    2014 SR5 CM 4x4 5.7
  8. Apr 6, 2022 at 12:31 PM
    Bber08527116
    08 tundra
    Ok thanks will do maybe they broke or didn't connect the plug to the fuel pump since that was. Changed going to buy a new fuel control module anyways
  9. Apr 9, 2022 at 9:18 AM
    Bber08527116
    08 tundra
    Still no start messed with wire on fuel control module and messed with some relays bought new ones turn the key on I could hear a click under the hood and it ran went of this am no click and it didn't start any ideas ?
  10. Apr 9, 2022 at 9:50 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Have you run down your battery trying to work on it?
  11. Apr 9, 2022 at 9:52 AM
    Bber08527116
    08 tundra
    No battery is good messed with relays unhooked the battery and it started for a sec then died something isn't letting it send fuel it's frustrating
  12. Apr 9, 2022 at 9:53 AM
    Bber08527116
    08 tundra
    Put a new fuel pump relay and it ran fine all day yesterday tryed starting it this am to move my boat and just crank no start again .
  13. Apr 9, 2022 at 10:59 AM
    Bber08527116
    08 tundra
    Next question I'm taking the fuelines off and the mechanic that did the fuel pump has shit ton of grease on the fuel line connectors even in the holes
  14. Apr 9, 2022 at 10:59 AM
    Bber08527116
    08 tundra
    Should this been done like thst or is it a risk for fuel line blocking?
  15. Apr 11, 2022 at 4:17 PM
    Bber08527116
    08 tundra
  16. Apr 11, 2022 at 4:57 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    If there is no continuity from one end to the other, it is possible.
