Intermitent Warning Light
Discussion in '2nd Gen Tundras (2007-2013)' started by Mabelfail98, Apr 1, 2021.
  1. Apr 1, 2021 at 6:32 AM
    Mabelfail98
    Mabelfail98 [OP] New Member
    2013 Cremax
    None
    Hi folks, Got a 2013 Tundra crew cab. 4.7L. 153Kmiles. I have an engine warning light that comes on for a few hours (or days) but then goes off. No change in performance that I can detect. I had a PO441 a few weeks ago and replaced the PCV and the vapor canister purge valve /solenoid. Also checked the gas cap for a broken seal. Any clues as to what might be going on?
  2. Apr 1, 2021 at 8:37 AM
    timsp8
    NY
    Did that code go away? Any new codes? Some code readers can read pending codes or the history if the light is off now.
  3. Apr 1, 2021 at 10:21 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    It's definitely worth the money to just throw your gas cap away and buy a new OEM one.
