Interior Wood Grain trim
Discussion in '1st Gen Tundras (2000-2006)' started by BlueGarden, Jan 14, 2024.
  1. Jan 14, 2024 at 1:24 PM
    BlueGarden
    BlueGarden [OP] New Member
    Paducah, KY
    2002 Tundra Limited 4x4 4.7L
    Anybody ever tried to vinyl wrap the interior wood grain trim in their FGT? It's in perfect condition, I just dont like the look of it. Would I be able to wrap it without removing the trim? I've never done vinyl wrap and I'm kinda curious.
  2. Jan 14, 2024 at 6:52 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    You could but it would probably look cheap and could leave a lot of glue and nastiness if you ever wanted to remove it. I would watch eBay for wood grain pieces from Tundras and go that route.
  3. Jan 14, 2024 at 11:18 PM
    BlueGarden
    Paducah, KY
    That's what I'm afraid of too...it looking cheap. Thanks!
  4. Jan 14, 2024 at 11:51 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Is the wood grain on just the center stack and the door panels or is there more to it?
  5. Jan 15, 2024 at 1:15 PM
    BlueGarden
    Paducah, KY
    That's all there is.
  6. Jan 15, 2024 at 1:23 PM
    Hydro dip would work better on an irregular piece like that
  7. Jan 15, 2024 at 5:01 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    If you’re tired of the oak, just switch it out to colonial pine
    KNABORES and shifty` like this.
  8. Jan 15, 2024 at 5:46 PM
    mmmmmm, birch
  9. Jan 16, 2024 at 11:09 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Wouldn't it be easier to just get junkyard non wood grain trim? I feel like if yours are in good shape someone will buy them and you can essentially do the swap for free.
    BlueGarden[OP] likes this.
  10. Jan 18, 2024 at 1:42 PM
    BlueGarden
    Paducah, KY
    From what I understand it's pretty labor intense to do that, but yeah that's an option for sure. It seems lkke i might have to live with the wood grain.
  11. Jan 18, 2024 at 2:09 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    shifty` likes this.
  12. Jan 20, 2024 at 11:17 AM
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    Swapping to a black setup isn't hard. I swapped wood INTO mine and detailed a bit of it in my build thread (linked below). I'd get some black pieces on eBay and have at it if I were you. YMMV
  13. Jan 20, 2024 at 12:11 PM
    shifty` In South Dakota Trouble ain't hard to find
    I was going to echo same earlier. I'd just add, the big thing to ensure is that it's from your same year (since '05-'06 is different) and you'll want to swap over the HVAC controls, since those are also not the same internally across even the same years in some cases.
