Interior lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by Meis, Jun 18, 2019.
  1. Jun 18, 2019 at 5:44 PM
    Meis
    Meis [OP] New Member
    Brandon
    2018 SR5 gray
    I have a 2018 trd 4x4 and was wondering if Anyone else has had an issue with the interior dome lights not turning off when the button is in the “door” selection mode?
  2. Jun 18, 2019 at 5:50 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    May sound dumb but they are on a timer. Do they not turn off at all? If so it could be a faulty switch or whatever senses the door is closed on the doors
  3. Jun 18, 2019 at 6:08 PM
    Meis
    Brandon
    2018 SR5 gray
    I set the timer to all options, even off and they still do not turn off unless the switch is in the off position.
  4. Jun 18, 2019 at 6:11 PM
    Pudge
    CT
    Weird. I forgot about the setting in entune. Maybe a bad switch. Seems odd though. Under warranty still? I'd bring it in fearing this issue may snowball.
  5. Jun 18, 2019 at 6:15 PM
    Meis
    Brandon
    2018 SR5 gray
    Yes, it’s under warranty still. Just wanted to see if it was an easy fix or something that I missed...
