INterior Lights Stopped working when door opens
Discussion in '2.5 Gen Tundras (2014-2021)' started by tundracap, Mar 28, 2018.
  1. Mar 28, 2018 at 6:58 AM
    tundracap
    tundracap [OP] New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    My interior lights stopped coming on when I open the doors. They still work via the switch, but I can't figure out what or why they are no longer coming on when I open the doors or unlock the truck.
    2017 CrewMax
    I haven't changed anything recently. I did have a fuse blow a month ago that controls the accessory plugs in the cabin. Swapped the fuse and all was well.
    Until last night.
    Makes me think I have an electrical issue somewhere.
    Any ideas?
  2. Mar 28, 2018 at 7:01 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Did you accidentally bump the switch to the left of steering wheel?
    NewImprovedRon likes this.
  3. Mar 28, 2018 at 7:03 AM
    Check your settings on your head unit.
  4. Mar 28, 2018 at 7:09 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    I was going to ask the same thing...I don't touch that switch often...got my truck back from the dealer in daylight...later that evening, got in my truck in the garage and noticed no interior lights and no headlights after I started it up...forgot to check switches...techs always turn off the interior and auto-headlights when its in the shop...set switches again...problem solved with good laugh...
    If your interior lights don't come on at all regardless of switch position, I would say the interior light fuse. When I replaced the halogen bulbs with LED, I shorted out one of the map lights and had to replace the interior fuse (under the hood). But if it just doesn't work when in the middle position...
    P-Factor and NewImprovedRon like this.
  5. Mar 28, 2018 at 10:02 AM
    tundracap
    NC
    Checked head unit, didn't see anything related, but will check again.
    The lights all work, just don't come on when I open a door or unlock the truck.
    I need to look for the switch to the left of the steering wheel. I don't remember hitting it though. The one I am thinking of is only for the cargo light, not the interior lights.
  6. Mar 28, 2018 at 12:07 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    Here is the panel that Ron is referring to...switch in top row, middle that says "Door" middle position turns on "Dome" or ceiling lights when door is opened (Thanks Ron!). This is the one that techs usually turn off when she's in the shop and sometimes I hit it when cleaning. bottom left switch that looks like a cargo truck is for Cargo and Bed lights (if you have bed lights connected).
  7. Mar 28, 2018 at 12:25 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    The part in the head unit settings that is related is where you set the reaction to lock and unlock using the key fob...horn and lights, horn and no lights, lights and no horn, etc. and the how long the lights are on.
  8. Mar 28, 2018 at 2:09 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    Duh..I couldn't remember "dome"...I just happened to be heading out and snagged a quick pic - hope it all helps.
  9. Mar 28, 2018 at 6:41 PM
    tundracap
    NC
    Switch.
    Obviously bumped it with my knee getting in or out yesterday, and didn't have time last night to ferret it out properly.
    Thanks everyone.
  10. Mar 28, 2018 at 7:11 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    There you go...you are not the first or last to have this experience...
  11. Jan 15, 2020 at 3:43 PM
    theendermeister
    theendermeister New Member
    2008 Tundra 5.7L SR5
    Guys! My dome light switch is coming detached from the dash, so before I crack into the dash and try to fix it, I'd like to have a new switch in hand...but I cannot for the life of me find one online to order - any ideas??
  12. Dec 17, 2020 at 12:40 PM
    Haiti4x4
    Haiti4x4 New Member
    Seany
    2016 Black Tundra xspx 4x4
    Stock for now
    Have same issue after shop installed new head unit. Theres no way to turn it on from the new head unit. Any help
  13. Mar 23, 2023 at 1:48 PM
    itsallgood101
    itsallgood101 New Member
    Randy
    Southern Utah
    2021 Tundra SR5 4X4 crew max
    Thank you feel stupid but easy fix
