Interior lights dont work anymore
Discussion in '2.5 Gen Tundras (2014-2021)' started by czzar_, Jan 14, 2020.
Any ideas what could it be
  1. What could it be
    1 vote(s)
    33.3%
  2. What could it be
    2 vote(s)
    66.7%
Multiple votes are allowed.
  1. Jan 14, 2020 at 7:26 PM
    czzar_
    czzar_ [OP] New Member
    Cesar
    Bonsall, CA
    2017 sliver Tundra sr5
    Hey guys I recently got some LED lightbulbs installed them everything was going well till I got to the foot well, once I installed that one all my interior lights (Dome lights and Visor lights) went out. I have a 2017 tundra if you guys can help me out that would be grate!!
  2. Jan 14, 2020 at 7:32 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    did you check the fuse in the box under the hood?
    That one is notorious for popping during led install...normally when you accidentally ground the dome light.
  3. Jan 14, 2020 at 7:37 PM
    czzar_
    Cesar
    Bonsall, CA
    I’ve tried check in the fuse box but the thing is I don’t know what fuse exactly I’m looking for
  4. Jan 14, 2020 at 7:44 PM
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    2020 Tundra Limited CM Smoked Mesquite
    S&B intake, Corsa exhaust, TRD rear sway bar, Spec-D tail lights, wireless center console charger.
    Check all fuses with a test light. The blown fuse will only be hot on one side
  5. Jan 14, 2020 at 7:45 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Let me guess ...you didn't disconnect the battery before installing?
  6. Jan 14, 2020 at 7:52 PM
    czzar_
    Cesar
    Bonsall, CA
    No didn’t disconnect the battery and I’ll check it out right now
  7. Jan 14, 2020 at 7:58 PM
    czzar_
    Cesar
    Bonsall, CA
    Found this might be the problem
    Patch999 and BravoDeltaRomeo like this.
  8. Jan 14, 2020 at 7:59 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    First step when working with electrical or anything that has power to it, kill the power source
    ZappBrannigan likes this.
  9. Jan 14, 2020 at 8:00 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    You found your culprit.
  10. Jan 14, 2020 at 8:21 PM
    czzar_
    Cesar
    Bonsall, CA
    Fix the issue you guys thanks a lot for the help!!
  11. Jan 15, 2020 at 5:08 AM
    nodak67
    nodak67 New Member
    JR
    luckily you blew the fuse, sometimes you blow the BCM and thats about $900. see that alot on the tacoma world forums and here. the thin metal reflector is usually the culprit when people try to remove the bulbs and short the via the reflector.
    either use a plastic pry tool, duct tape to pull the bulb or disconnect the battery.
