Interior LED replaced, keyless entry acting “weird”
Discussion in 'Lighting' started by DevinH18Platinum, Jun 3, 2020.
  1. Jun 3, 2020 at 6:11 PM
    DevinH18Platinum
    DevinH18Platinum [OP] New Member
    Devin
    2018 Platinum.
    4 inch lift on 33s
    Hello,
    my 2018 Platinum CM. I replaced my map lights, dome lights, cargo lights and license plate lights, now my keyless entry is acting strange. I hit unlock to unlock drivers door and then again for the rest of the doors and it does nothing, I keep hitting it and then it unlocks just driver door again and then it unlocks the rest, almost like it’s losing signal. I can stand there next to my truck and lock and unlock the doors and every 3rd time I button mash to nothing happening. I disconnected the battery when I replaced the bulbs and now this. Any ideas? I also tried my spare key and it still acts the same. Very annoying.
  2. Jun 3, 2020 at 8:49 PM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Aries Side Bars, DeeZee low profile tool box, weathertech mats, TRD RSB
    Evening, can't help but notice that the "Cargo Lights" was on the list. From my understanding the antenna for the "key fob" is located in that area. Common problem area. I would replace LEDS back to OEM for the Cargo Lights and see if the problem is still there.
  3. Jun 3, 2020 at 9:00 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    I changed my cargo lights to LEDS and so far no issues. I used @Headlight Revolution. Don't know if the brand makes a difference or not. But I've bought all of mine from them.
    Headlight Revolution likes this.
  4. Jun 4, 2020 at 3:34 AM
    DevinH18Platinum
    Devin
    2018 Platinum.
    4 inch lift on 33s
    My plan this afternoon. Thank you!!
    Turtle[QUOTED] likes this.
  5. Jun 5, 2020 at 7:59 PM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    did you do the OEM replacement. If so did it work ?????
  6. Jun 6, 2020 at 5:37 AM
    DevinH18Platinum
    Devin
    2018 Platinum.
    4 inch lift on 33s
    I put all OE bulbs back in and yes it went back to normal. So, I’m good with standard bulbs for right now.
  7. Jun 6, 2020 at 6:15 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Others have have had this same problem with some LED cargo lights. There’s another bigger thread somewhere here in the depths of Tundras on the issue, what bulbs were and were not working.
    DevinH18Platinum[OP] likes this.
  8. Jun 6, 2020 at 6:55 AM
    Instead of swapping the cargo bulbs back to oem, why not just turn the switch off and see what happens?
    landphil likes this.
  9. Jun 6, 2020 at 8:05 AM
    Cidertom
    Cidertom Chionophile
    Tom
    2017 longbed
    FWIW The led dome lights in my snowcat wipe out vhf radio reception. It's interesting how much RF noise they generate.
  10. Jun 6, 2020 at 6:38 PM
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    That’s what I did, didn’t feel like putting the shitty OEM bulbs back. Just turn off the auto cargo light switch that makes it turn on when doors open. After I shut it off, keyless and remote start went back to normal.
    Turtle and DevinH18Platinum[OP] like this.
  11. Jun 6, 2020 at 6:52 PM
    That is weird that an led would cause this. I randomly get double beeps when I lock mine with the remote, but that is with the switch off as well. :notsure:
