Interior led install
Discussion in 'Lighting' started by Grubblife18, Nov 3, 2017.
  1. Nov 3, 2017 at 2:13 PM
    Grubblife18
    Grubblife18 [OP] New Member
    2014 tundra limited
    6" readylift, rock star wheels on 33's and much more.
    i was installing led bulbs for the interior of my 2014 tundra and may have blown a fuse because no overhead lights work now. Any idea which fuse it is?
  2. Nov 3, 2017 at 4:19 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I believe the fuse is located above the kick panel on the driver’s side.
  3. Nov 3, 2017 at 5:51 PM
    Grubblife18
    2014 tundra limited
    Thanks. I’ll look for it. I thought I found a diagram that said it’s under the hood.
  4. Feb 26, 2019 at 6:43 PM
    Tundra-XP
    Tundra-XP New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    Did you find the fuse for it. I am having the same problem and the fuse panel is not labeled interior fuse like normal.
  5. Feb 26, 2019 at 6:51 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    There should be a fuse map or layout on underside of cover or in the manual
  6. Feb 26, 2019 at 6:51 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    In my ‘18 the fuse for the map/interior lights was down in the driver’s side footwell up on the left. A small fuse panel with a black cover which pops off and has the fuse diagram on it. May have been a 10 amp.
  7. Feb 26, 2019 at 6:59 PM
    Tundra-XP
    Will
    I found the fuse panel under the dash I was wandering if anyone know what fuse it was so I didn't have to pull each one out looking for it. There are labels but none that say interior or anything remotely.
  8. Feb 26, 2019 at 7:01 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    Should be labeled Cargo 7.5 amp
  9. Feb 26, 2019 at 7:05 PM
    Tundra-XP
    Will
    Great thanks, I will try that one tomorrow.
  10. Feb 26, 2019 at 7:21 PM
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    I think its labeled "dome". I blew this fuse as well when changing my lights, freaked me out lol
  11. Feb 26, 2019 at 7:58 PM
    shhernandez74
    Samuel
    I think it’s in the engine compartment if I remember correctly. Here’s a picture of the fuse cover in my kick panel and I don’t see a fuse that would be tied into the interior lights. My truck is a 17, don’t know if that makes a difference. 3C753A07-E7B2-4BD6-8BB5-02DF8D739132.jpg
    Hammy68 likes this.
  12. Feb 27, 2019 at 5:40 AM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    I stand corrected- looking back it looks like they moved the location under the dash for newer years. Looks like for 2014s it’s under the hood, a 7.5 amp.FF60E673-BBF3-4D4D-8418-238BF30D04AB.jpg
  13. Feb 27, 2019 at 5:44 PM
    Tundra-XP
    Will
    Well you were right and I don’t know how I missed it. It’s under the hood listed as Dome 7.5 amp. I appreciate the help.
    Hammy68 likes this.
  14. Feb 27, 2019 at 5:55 PM
    shhernandez74
    Samuel
    Glad you found it!
  15. Mar 1, 2019 at 8:25 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    So has anyone found the wire going to the dome through the sill plate?
