Interior Door handle fitment ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by GSD, Oct 8, 2020.
  1. Oct 8, 2020 at 9:00 PM
    GSD
    GSD [OP] New Member
    Seattle, WA
    2019 Platinum Crewmax
    Looking to replace replace my 2019 CM chrome interior door handles with black. Found a set of four on Ebay, however it says they're for 2007-2018. Any idea if these will work in a 2019? Not sure if something changed with the fitment between 2018 & 2019...
    Thanks
    BamaMan44 likes this.
  2. Oct 8, 2020 at 9:05 PM
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    Does the listing have the part number? They should fit. Nothing should have changed. I just replaced the ones in my SR5.
  3. Oct 8, 2020 at 9:06 PM
    BamaMan44
    Andre
    Tucson
    Here are the part numbers I used.
    692060C040 Interior Door Handle (Left, Front, Rear)
    692050C040 Interior Door Handle (Right, Front, Rear)
  4. Oct 8, 2020 at 9:17 PM
    GSD
    GSD [OP] New Member
    Seattle, WA
    They are referencing the part numbers you noted. However it appears your truck is a 2017, correct? I'm trying to determine if these will fit a 2019.
    BamaMan44[QUOTED] likes this.
  5. Oct 8, 2020 at 9:42 PM
    BamaMan44
    Andre
    Tucson
    Thats correct. Yea they should fit. The door handles are all the same from 07-present. The Sequoia uses the same one as well.
    GSD[QUOTED][OP] and 1lowlife like this.
  6. Oct 8, 2020 at 9:45 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    BamaMan44 and GSD[QUOTED][OP] like this.
  7. Oct 8, 2020 at 9:53 PM
    GSD
    GSD [OP] New Member
    Seattle, WA
  8. Oct 8, 2020 at 9:55 PM
    BamaMan44
    Andre
    Tucson
    I would definitely go OEM. That way you know they're going to work. Just my$.02
  9. Oct 8, 2020 at 10:04 PM
    GSD
    GSD [OP] New Member
    Seattle, WA
    It says they replace the OEM part #'s and they're like 1/2 the price, guess I'll find out whether they work.
  10. Oct 8, 2020 at 10:06 PM
    BamaMan44
    Andre
    Tucson
    Good luck!
  11. Oct 9, 2020 at 10:32 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Post your results.
    I'm thinking about swapping mine too.
  12. Oct 19, 2020 at 9:15 PM
    GSD
    GSD [OP] New Member
    Seattle, WA
    They worked! My truck is a 2019, just wasn't sure they'd fit since the ad indicated they were for 2007-2018. Look much better than the chrome, IMO.
    1lowlife[QUOTED] and BamaMan44 like this.
