Intentionally running out of gas
Discussion in 'General Tundra Discussion' started by Braz, May 13, 2019.
  1. May 13, 2019 at 5:15 PM
    Braz
    Braz [OP] New Member
    My 2017 tundra low fuel light comes on at around 30 miles. When I fill the tank I can only get 28 gal in the tank yet I am supposed to have the larger 38 gal tank. This happen to anyone else? I was thinking of carrying extra gas can and running the truck until it actually runs out of gas. Good or bad Idea? Any one that has run of of gas have any problem starting the truck afterwards?
  2. May 13, 2019 at 5:18 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Lots of threads on this, upper right there is a search box. It's typical you will only fill up around 30 gallons even when empty.
    trayday, Black Wolf, T-Rex266 and 2 others like this.
  3. May 13, 2019 at 5:18 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    There are other threads you should read prior to doing that. Its 38 gallons but the fuel pump is submerged in that 38 gallons. Mine will register empty at 32 gallons. 6 gallon reserve for the fuel pump to stay submerged.
    Sas likes this.
  4. May 13, 2019 at 5:30 PM
    Braz
    I tried to find other threads before posting. Seems silly to have 6 gallon in the tank that are not useable.
    jewsNbrews likes this.
  5. May 13, 2019 at 5:39 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I agree, but it's all marketing. Claiming 38 gallon tank is better than saying 30. I dont like the search engine in here, Google search with tundras.com in the search about the gas tanks will help with the headache
    T-Rex266 likes this.
  6. May 13, 2019 at 5:42 PM
    AZTundra
    Paul
    Phoenix, AZ
    I ran mine until the light came on yesterday. I believe the computer trip counter said about 20 miles to empty. Took a hair over 30 gallons to fill it full. Unfortunately this is normal.
  7. May 13, 2019 at 7:34 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    A dry pump is a burnt up pump....don't run it to low.
    jewsNbrews and JohnLakeman like this.
  8. May 13, 2019 at 7:50 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    What this guy said. You really run the risk of burning your pump
