Integrated brake controller
Discussion in 'General Tundra Discussion' started by joonbug, Feb 22, 2016.
  1. Feb 22, 2016 at 10:06 AM
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If anyone is planning to buy a brake controller, get it from Roman
    https://www.tundras.com/members/876/
    Here's the link to the brake controller
    https://www.tundras.com/out/?url=http://parts.toyotaofcoolsprings.com/oe-toyota/895470c010
    And the link to the panel
    http://parts.toyotaofcoolsprings.com/oe-toyota/554470c020c0
    I think the dealerships are charging about $320. I got mine from Roman for $225. That's for the brake controller, the new panel, and shipping. Can't pass up that deal. Everything you need is included and literally takes about 10 minutes to plug and play. It's integrated so the info displays on the dash and it lights up when the lights are on. It will work on 2015's but the 2014's aren't wired for this. And for the 2016's I believe it's standard on all 5.7 but not 4.6's. I know this has already been posted but it was too easy to miss and the price wasn't very clear. image.jpg image.jpg
    dak13, Roman and T-Rex266 like this.
  2. Feb 22, 2016 at 2:35 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Yep, Roman hooked me up. Saved $100.
    NewImprovedRon, 040Tundra and Roman like this.
  3. Feb 22, 2016 at 2:59 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Gah. He sounds like a swell guy.
    :D
  4. Feb 22, 2016 at 3:54 PM
    Ryan Mc.
    Ryan Mc. New Member
    Ryan
    Mission Viejo
    2015 Toyota Tundra SR5 Double Cab 5.7L
    Hand made bed divider, bed d-rings
    OMG!!!! FINALLY!!! Ive been lurkin around the forums waiting for someone to figure this crap out. I have a 2015, if I buy the relay, is there software already in the vehicle that will recognize it or is there a 2016 software upgrade involved?
    Also, does the existing connector behind the panel plug-n-play or is there a shorty adapter cable/harness??
  5. Feb 22, 2016 at 4:10 PM
    AMRE2ME2
    AMRE2ME2 New Member
    2016 DC 4x4 Limited TRD
    Ryan, yes and yes. Just buy the parts and plug them in. Your truck has everything else it needs. Roman posted right above you, he knows what you need.
  6. Feb 22, 2016 at 4:39 PM
    mdavis
    Michael
    Rock Hill, SC
    Yep, plug and play. Did it on my 15. Software is already there.
    NewImprovedRon likes this.
  7. Feb 22, 2016 at 5:48 PM
    Ryan Mc.
    Ryan Mc. New Member
    Ryan
    Mission Viejo
    Thanks for the quick reply. Ive been wondering ever since I bought my truck back in sept. but I was a little hesitant because of the heavy price and not knowing about the software. And at the time the parts guy I talked to here in socal said they werent available.
    Big thanks! Now the hard part....start saving up for it.
  8. Feb 23, 2016 at 6:57 AM
    Roman
    Roman
    Franklin, TN
    Yep, plug and play. It's a two beer job at most. I've got them in stock as well.
    dak13 likes this.
  9. Mar 4, 2016 at 9:53 AM
    bushwacker
    bushwacker New Member
    Will it fit a 2015 with the 4.6?
  10. Mar 4, 2016 at 12:23 PM
    Roman
    Roman
    Franklin, TN
    It fits all 2015's to my knowledge. You may want to confirm that the plug is there, just to be safe.
  11. Mar 4, 2016 at 12:26 PM
    bushwacker
    Thanks, will do.
  12. Mar 4, 2016 at 4:28 PM
    Jc77
    Jc77 New Member
    2014 limited crewmax Trd
    Will it fit 2014
  13. Mar 4, 2016 at 4:46 PM
    Roman
    Roman
    Franklin, TN
    No sir. The plug is different, and located in a different location as well.
  14. Mar 4, 2016 at 5:46 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Don't worry, I'm sh*t out of luck too!!
    Jc77[QUOTED] likes this.
  15. Mar 5, 2016 at 5:50 AM
    Jc77
    Jc77 New Member
    There's no way to make some sort of pigtail to go to the stock location ? Just wondering I would love that set up
  16. Mar 5, 2016 at 8:24 AM
    mdavis
    Michael
    Rock Hill, SC
    Not only would you need a pig tail but you would also need to go to a dealer and have the software installed (if they even will). The stock controller uses the driver info screen to adjust the gain and mode. Without that screen you would have no idea what mode your in or your gain setting.
  17. Mar 5, 2016 at 1:02 PM
    Jc77
    Jc77 New Member
    Thanks for the info. That set up is nice! To bad the poor 2014 missed out
    mdavis likes this.
  18. Mar 17, 2016 at 12:31 PM
    TRF 67
    TRF 67 New Member
    2015 Gray SR5 Tundra
    Roman,
    Do you know if the OEM Brake controller is proportional or time delay. I was going to go with a proportional Tekonsha but I came across the forum talking about the OEM controllers. They look like a nice set up. I was just wondering about the type as it seems proportional are better. I would appreciate any info.
    Thanks
  19. Apr 4, 2016 at 9:55 PM
    warrior
    warrior New Member
    Jesse
    2016 White Tundra Crew Max
    So, what about the 2016?
  20. Apr 4, 2016 at 11:09 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    They're standard. You should already have it. Actually, I think it's all 5.7's.
  21. Apr 4, 2016 at 11:30 PM
    warrior
    warrior New Member
    Jesse
    Ok, the salesman said it didn't but, he was new. If it had the controller, would there be and adjusting lever or anything? Mine is the SR5 not the plus
  22. Apr 4, 2016 at 11:34 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Do you have a 5.7 or a 4.6? I think it only comes standard on the 5.7's.
  23. Apr 4, 2016 at 11:38 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Look at the first picture, it's under the traction control button and right of the ignition. And if you scroll through your display, the integrated brake control screen should come on.
  24. Apr 5, 2016 at 12:05 AM
    warrior
    warrior New Member
    Jesse
    No I don't have any of those controls under my traction control button.
  25. Apr 5, 2016 at 12:07 AM
    warrior
    warrior New Member
    Jesse
    I have the 4.6
  26. Apr 5, 2016 at 12:25 AM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Apparently it only comes standard on the 5.7s. You can probably get this then. But ask Roman to make sure your truck is wired in.
  27. Apr 5, 2016 at 9:03 AM
    MC Mike
    MC Mike New Member
    Central NY
    2015 tundra SR5 TRD
    Fuel Pump 20x9 wheels with 33x12.5 Federal tires. 3/1 lift level kit from off road and TRD PRO grill and hood bulge
    How much are you selling them for?
  28. Apr 5, 2016 at 9:39 AM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Roman is selling them for about $225 shipped to you. There's a link on the first message.
  29. Apr 5, 2016 at 9:42 AM
    tacouser
    tacouser New Member
    Chicago
    2015 SR5 Tundra Dbl Cab 4X4
    Bilstein 5100 rear, Klein train horns! Swing Case, Tekonsha P3 brake controller, Bed LED's, Weathertech window visors and floor mats,Retrofit Source Fog Lights, Bakflip cover, Ford Rapter hood leds, Hellwig rear sway bar
    What would be the cost shipped to 60467?
    Anyone interested in a almost new Tekonsha P3 prodigy brake controller with the wiring harness?image.jpg
  30. Aug 28, 2016 at 6:52 AM
    Sickness4x4
    Sickness4x4 New Member
    Chuck
    2015 Inferno Tundra TRD Pro
    I noticed the Relay is discontinued is there a replacement part number?
