intake question
Discussion in 'Performance and Tuning' started by bobothegreat, Oct 28, 2022.
  1. Oct 28, 2022 at 9:36 AM
    bobothegreat
    bobothegreat [OP] New Member
    jason
    07 super white tundra
    i have a 07 tundra and i removed the secondary filter inside the stick system. after about a mile the truck shutoff and would not run. i did put it back in bu now im wondering why it did that lol. i mean if i wanted to install a cold air intake am i going to have this issue?
  2. Oct 28, 2022 at 10:12 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    No benefit to installing a CAI on a Tundra, the stock system is already a CAI. You will not gain anything with a CAI other than it will be louder. You can gain some HP/Torque with an exhaust, @dirtydeeds systems actually make HP and dont lose low end like most catbacks.
    GODZILLA likes this.
  3. Oct 28, 2022 at 10:16 AM
    AZBoatHauler
    So.Arizona
    You mean the active charcoal in the intake tube?
    if you disconnect the battery, the truck should relearn what fuel it needs based on whatever change was made.
  4. Oct 28, 2022 at 10:43 AM
    I don't know why removing that charcoal filter would cause his issues.
    ColoradoTJ likes this.
  5. Oct 28, 2022 at 10:49 AM
    AZBoatHauler
    So.Arizona
    I don’t know anything that would cause his issue… but a reset might help assuming intake parameters have changed.
  6. Oct 28, 2022 at 10:55 AM
    Only CAI I would consider for your Tundra is Stillen. The air intake temps will be ambient with that true CAI system pulling air from the front of the trucks grille.
    https://stillen.com/products/2014-2020-toyota-tundra-trupower-by-stillen-cold-air-intake
    Do some CAI systems suck? Yes. Do a few actually improve performance? Yes. I have plenty of data logged hours from my Edge CTS3 before and after installing my Banks Ram Air on my D-Max. During some drives before the CAI, my air intake temps were 25*F hotter than ambient. So on a 92* day I could be reading 117*F cruising down the freeway. In town where the intake would get heat soaked…135+* was common.
    e30cabrio, Saltyhero13 and reywcms like this.
  7. Oct 28, 2022 at 11:58 AM
    bobothegreat
    jason
    my truck actually had an exhaust put in on it when i bought it. but i havent really looked to see whats type it is. it does have trd tips but i believe its just the tips lol.
  8. Oct 28, 2022 at 11:59 AM
    bobothegreat
    jason
    yes the charcoal filter
  9. Oct 28, 2022 at 12:04 PM
    AZBoatHauler
    So.Arizona
    Maybe double check the air box, filter, and all fittings / connections to make sure you don’t have a leak. If that doesn’t work double check / clean the MAF would be my next move.
  10. Oct 28, 2022 at 12:06 PM
    Maybe air fuel ratio? When I removed the factory charcoal filter in my 2012 Tundra the battery was disconnected, so maybe that reset the ECU and my truck fired right up.
    The charcoal filter allegedly reduces flow 10-25% from air flow testing. That’s quite a bit.
    AZBoatHauler likes this.
