Insulation for road noise
Discussion in '2nd Gen Tundras (2007-2013)' started by ToyotaTundraDoubleCab, Nov 13, 2018.
  1. Nov 13, 2018 at 1:19 PM
    ToyotaTundraDoubleCab [OP] New Member
    Does the limited trim level have more insulation to keep out road noise than the lower level trims?
    Also do the 2007-2013 have the same amount of road noise as the 2014+?
  2. Nov 13, 2018 at 1:27 PM
    MajorC
    MajorC New Member
    Major
    2007 Tundra SR5
    I have a 2007 Tundra SR-5 and it is very quite compared to my previous 2002 Ford F-150. Tires have a lot to do with it too. I rarely go off road and I spend a lot of time on the interstate, so I went with a performance rated SUV tire.
    Rex Kramer likes this.
  3. Nov 13, 2018 at 2:16 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Check out the website sound deadening showdown. Tons of good info there.
    I have my truck about 75% complete. Need to do the front floors and firewall then I'm done unless I decide to do the roof some day.
    Also would be nice to somehow do the wheelwells with some kind of rubber spray
    Mass is what kills sound so you needs lots of mass covering everything to kill road noise.
    I used CLD tiles (aka dynamat), closed cell foam, mass loaded vinyl (MLV-this is the main sound blocking item), some reflective insulation, and a few other materials. The biggest difference was when I did the back wall and front doors.
    Black Wolf and TheBeast like this.
  4. Nov 13, 2018 at 2:18 PM
    Pudge
    CT
  5. Nov 17, 2018 at 3:54 AM
    Ok. I appreciate the help but nobody actually answered my questions. I should have titled the thread differently.
  6. Nov 17, 2018 at 4:43 AM
    wigsplitter
    wigsplitter New Member
    DFW Texas
    2018 SR5 TSS Crew Max
    My guess would be there is no difference in insulation based on trim level. I owned a 2013 crew max for 4 years and now a 2018 for a year. No change in road noise for me. Both trucks had the 20" TSS wheels with BFG's on them.
  7. Nov 17, 2018 at 10:26 AM
    Pudge
    CT
    They are all insulated the same from the factory. With the exception of maybe the SR tubdra grade model. But idk that for sure.
