Insulating sun glass holder
Discussion in 'General Tundra Discussion' started by gdisarray, Aug 21, 2019.
  1. Aug 21, 2019 at 7:14 PM
    gdisarray
    gdisarray [OP] Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    Hotter than two rats screwing in a burlap bag here. Go to lunch and had happened to put my sunglasses up in the holder when I had gotten out this morning.
    They were REALLY hot. It was instinctual to just put them on. Bad move.
    I reach up in the holder and there is nothing in there but the bare metal of the cab roof.
    Burned my hand again.
    Any ideas on insulating it?
    Ajkkane and Patch999 like this.
  2. Aug 21, 2019 at 7:21 PM
    Ha! I thought about this too a while back, was thinking about that insulation with that silver lining, I have this at work, machine I operate has hydraulic lines next to my knee and it's gets hot, mechanics got this stuff at Napa, it's about 1/8" or 1/4" thick
    Patch999 and gdisarray[OP] like this.
  3. Aug 21, 2019 at 7:25 PM
    Something like this
  4. Aug 21, 2019 at 7:26 PM
    gdisarray
    Ha, have a big roll of radiant barrier at work. Bit to get snipped off the end. :eek::D
    TXRailRoadBandit73 likes this.
  5. Aug 21, 2019 at 7:28 PM
    Let me know if it works and size to fit, I'll try this as well
  6. Aug 21, 2019 at 7:32 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I'm also interested in how this works out...
  7. Aug 21, 2019 at 7:42 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Thermo-Tec Acoustical & Heat Control Mats
    Patch999 likes this.
  8. Aug 21, 2019 at 7:45 PM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    Great idea. Now I need a solution as well.
  9. Aug 21, 2019 at 7:51 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Those for house HVAC ducts, you could get it from homedepot
  10. Aug 21, 2019 at 7:52 PM
    Yeah I know, but mechanics at my work got from Napa
  11. Aug 21, 2019 at 7:54 PM
    Yeah that's it, mechanics got me the FR one
    Winning8[QUOTED] likes this.
  12. Aug 21, 2019 at 9:11 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Hot rod guys us it on their firewall, transmission tunnel and floor pan, factory have some of the cotton under the carpet as well.
  13. Aug 21, 2019 at 9:15 PM
    Yeah I operated a machine that had it wrapped around it's hydraulic lines and made the cab a bit cooler, so I wanted some as well
  14. Aug 22, 2019 at 3:47 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    At some point, I'd like to use this to insulate the whole roof under the headliner. There's nothing insulative under the headliner. Kinda surprised me when I had the headliner edges down to install my roof rack. Would help with cooling down the cab on those crazy hot summer days. Next project! :woot:
    jewsNbrews likes this.
  15. Aug 23, 2019 at 10:33 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I pulled down the overhead console to see what we could work with space-wise; I don't think there is anywhere to put insulation. The sunglass holder is bolted flat against the metal support. Any ideas?
  16. Aug 23, 2019 at 11:23 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    I’m sorry,,, I can only help you if you have 2 chipmunks screwing in a burlap bag. I would check the F150 forums for advice on mice and rats..:rofl::)
  17. Aug 23, 2019 at 12:03 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Between the metal
    gdisarray[OP] likes this.
  18. Aug 23, 2019 at 4:27 PM
    gdisarray
    Thanks. I was just figuring how to pull that panel. Now I see! :thumbsup:
  19. Aug 23, 2019 at 4:30 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Just 4 T15 screws. You'll need to pull the card holder/clip and trim for 2 of them, and the other two are inside the sunglass holder.
    gdisarray[QUOTED][OP] likes this.
  20. Aug 24, 2019 at 4:09 PM
    gdisarray
    Couldn't put it between the metal. That is a box beam and you can't get behind at the front above the glass holder.
    I just grabbed some radiant barrier for metal roofing from our warehouse. Basically bubble wrap with foil on one side. Cut it into two pieces, stuck it in the hole foil side up, and screwed the trim piece back in. Plenty of room. Finally put in my LED bulbs while I was at it.
    Two pieces seemed like a better fit but I may end up just making it one piece.
    I'll find out tomorrow if it makes any difference.
    OR18TRD, Ely010606, Pudge and 2 others like this.
  21. Aug 24, 2019 at 4:19 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    you lost R value when you compress the insulation, but should be better then nothing
  22. Aug 24, 2019 at 4:25 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    That stuff is maybe R1 to begin with. The idea here was strictly reflection of heat. I hope it helps a little bit. I used a similar material called reflectix as part of my sound deadening and it seemed to help with heat around the transmission tunnel area. Is basically foil lined bubble wrap, the stuff I used was foil on both sides but looks very similar
  23. Aug 24, 2019 at 5:33 PM
    gdisarray
    It didn't pinch. Actually tightened up snug against the headliner before screws could snug the bezel against the mounts. So no it didn't lose the R value.
    And damnit, I forgot to look to see what that small vent is for that is on the front of that bezel.
    TRDFerguson and Winning8[QUOTED] like this.
  24. Aug 24, 2019 at 8:06 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Great thread! My Wife forgot her sunglasses and I gave her my emergency pair that has been in there for at least 6 months. They were extremely hot.
    Thanks for the ideas!
  25. Aug 24, 2019 at 8:28 PM
    Shephard_Of_The_Tundra
    Shephard_Of_The_Tundra DIY try guy
    Corpus Christi, TX
    2016 Black Tundra SR5 4.6 DC 2WD
    Morimoto 2 stroke H4 LED Headlight Bulb VLEDs 3157ck Amber Triton V6 TurnSignal Auxito LED reverse bulbs OEM Toyota LED smoked fog lights Auxito LED T10 license plate bulbs Auxito LED T10 Side marker headlights LASFIT LED T10 3rd brake light Xenon Depot T10 LED Bed/Brake Lights TRD Off-Road Black/Chrome Wheels Bridgestone Duellers 255/70/R18 Front & Rear TRD Sway bars MBRP Dual side exhaust exits Drop-in K&N air filter TRD air flow accelerator Toyota Rubber floor liners OEM Rear under seat storage box Kenwood DMX7706S head unit TRD Shifter knob Center console organizer tray Dual USB fast chargers center stack
    I believe that vent is for the factory car stereo microphone...
  26. Aug 24, 2019 at 8:29 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yep. I put my aftermarket mic there after swapping head units.
    Pudge likes this.
  27. Aug 25, 2019 at 5:21 PM
    gdisarray
    I thought the mic was here above the drivers visor.
  28. Aug 25, 2019 at 5:59 PM
    Corpus Christi, TX
    You have the jbl system?
  29. Aug 25, 2019 at 6:00 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Lol the stuff you guys make me think about doing to my truck...
  30. Aug 25, 2019 at 6:03 PM
    gdisarray
    No. Entunre Premium Plus w/Nav and Apps from the factory. It is a 2019 TSS in the cool color. MGM.
