Instrament Cluster milage correction
Discussion in '1st Gen Tundras (2000-2006)' started by tailfinjoe, Dec 3, 2021.
  1. Dec 3, 2021 at 11:31 PM
    tailfinjoe
    tailfinjoe [OP] New Member
    2006 Tundra 6 speed 8ft bed
    none at this time
    I want to swap out clusters on my truck 2006 V6 can I put in the correct miles using a bidirectional scanner ?? If so which one ?? Has anyone did this ?? Can a dealer do it ?? If so how much ??
  2. Dec 4, 2021 at 5:32 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  3. Dec 4, 2021 at 6:31 AM
    tailfinjoe
    none at this time
  4. Dec 4, 2021 at 6:56 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm tagging another member that is a Toyota mechanic so he can share his knowledge on your questions.
  5. Dec 4, 2021 at 7:48 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You need to have the eprom chip on the cluster programmed. It’s not easily DIY’d mechanicjon on TW can do it. It involves a hex editor and bread board to get done
  6. Dec 4, 2021 at 2:09 PM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    feds are watching
    CodyP likes this.
  7. Dec 4, 2021 at 2:25 PM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    It's not a DIY job. Your milage may actually climb up.
  8. Dec 5, 2021 at 5:42 AM
    jake22si
    jake22si New Member
    kevin
    2000 tundra 4.7
    who cares they go forever?
  9. Dec 5, 2021 at 5:44 AM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    shady new member first post with resale values so high
