Installing Westcott sliders
Discussion in '3rd Gen Tundras (2022+)' started by sulli155, May 27, 2023.
  1. May 27, 2023 at 6:02 AM
    sulli155
    sulli155 [OP] New Member
    Ryan
    Anyone install the westcott sliders on their truck yet? Been sitting and waiting on an install video so I don't totally screw it up but still nothing posted on the youtube.
  2. May 27, 2023 at 9:09 AM
    terraj66
    terraj66 New Member
    Las vegas
    I’m sure most mounting points should be the same or close to all other sliders. Check out the other brands for install vids
  3. May 28, 2023 at 5:49 AM
    TundraTT
    TundraTT Full Send
    17 Pro, 94 70series LC
    Westcott has great customer service, I’m sure if you contacted them they will give you specifics for the Tundra. Like terra said, should be very similar to tacoma/4Runner with minor nuances along the way
  4. Jun 1, 2023 at 5:53 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Westcott just released a install video on the 3rd gen Sequoia, similar to Tundra frame.
  5. Jun 2, 2023 at 11:23 AM
    uberoval
    uberoval New Member
    Just had them install these on mine. Excellent workmanship and buy once, cry once. They look great and solid as all get out.
  6. Jun 2, 2023 at 2:40 PM
    TundraTT
    TundraTT Full Send
  7. Jun 20, 2023 at 6:07 AM
    sulli155
    Ryan
    Was able to install these over the weekend. Using the two videos, I was able to scribble down some basic instructions to myself. A few notes:
    1. I ultimately used the rivet nut tool linked in the sequoia video. You'll need an M12 bit to get the rivet nuts installed. The handle on the one I used was 16", which was too long to get under the frame without jacking up the vehicle first. I just got the vehicle on a couple jack stands to give myself the clearance.
    2. Aligning the sliders was a bit interesting, though not that bad really. I used two jack stands and the floor jack on the mounting side. Put all of this on a huge piece of cardboard so I could "slide" them into alignment. Once aligned, the floor jack brought these right up into place.
    3. The sequoia video was helpful for sizing of tools...and step up sizes were spot on. Though, have a good set of sockets / wrenches handy as it's not an all inclusive list.
    4. The "funky little things" as quoted in the video were easy enough to get on. I originally had used an impact driver to reverse out the 5mm bolt, but found that it was actually easier for me to just use a hand ratchet with the 5mm hex bit attached. Both worked.
    They look great. I'd rate my handyman skills as "average" (enough to tackle most things on the honey-do list) though my experience on vehicles is very limited. Was able to get them on with no major issues...
    Good luck if you're going to go after these youreself!
    danhung11 and PBNB like this.
