Installing TRD PRO Seqouia shocks on 2023 SR5 help!!
Discussion in 'Suspension' started by SgtSausage1978, Dec 11, 2023.
  1. Dec 11, 2023 at 6:14 PM
    SgtSausage1978
    SgtSausage1978 [OP] New Member
    Utah
    2023 SR5 crew cab
    so if i swap out my black hitachi shocks for the TRD PRO (actually came off a trd pro sequoia) shocks will i automatically gain the 1.5” up front without a spacer or collar or anything ? i know the tundra PROS come leveled is that just because the front shock is longer?
    i’m going to install the red CV axles to upgrade from the black ones
    i assume i would need new UCAs is that accurate ?
    anything else need swapped brake lines, bump stops etc.. ???
    any info would sure help thanks
  2. Dec 11, 2023 at 7:19 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    I may be wrong, but the spring rates on the sequoia and tundra are not the same. You’re not going to gain the same height on a tundra as they would produce on the sequoia. But to answer your other question….you wouldn’t need to change out all the other stuff mentioned.
  3. Dec 11, 2023 at 7:48 PM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    ok thanks i called a toyota dealership and the parts tech there said that the tundra and sequoia share the same frame..and he could not find any difference in the fox pro shock part numbers which then lead us to believe the shocks were interchangeable ..
    so the shocks may be the same but now i need to check if the springs are different thanks
  4. Dec 11, 2023 at 7:49 PM
    The new Tundras are basically Seqouias now. Should be fine.
    Hella Krusty likes this.
  5. Dec 11, 2023 at 7:54 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Is there different mounting or anything with one being straight rear axle and one being independent rear suspension between the 2?
    That'd be my main concern as well as spring rating between the 2
  6. Dec 11, 2023 at 8:01 PM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    i’m going to toyota dealer to look up exact part number for springs and shocks tomorrow ..
    hope they match exactly
    Fotnot likes this.
  7. Dec 12, 2023 at 11:00 AM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    so it does seem that the springs are different between models even though shocks are the same .. i couldn’t get exact load rates or height rates from toyota, fox, or dobinsons .
    and i could not order just the springs for the front shocks it comes as a full strut
    and of course part numbers between models are not the same
    i think the dream is dead
  8. Dec 12, 2023 at 12:29 PM
    Tom
    Tom New Member
    I have them on my truck. Fits fine. Yes you won’t get the lift but the ride under load is unmatched
    I don’t see why you can’t just order spacers from west cott
  9. Dec 12, 2023 at 12:48 PM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    the dream is back on !!!! so if i got a preload 1.5” collar lift in the front only and used the stock springs that come with the trd pro sequoia i should be 100% ready to get nasty is what you’re saying ..
    that would level out my SR5 and maybe sit a smidge higher front and back because the TRD PRO models sit a smidge higher anyway
    cinderella story tears in his eyes a lowly SR5 Po boy with a dream
    i just tow a light boat .. have 1 snowmobile in the bed at times , couple dirt bikes at times ..i don’t have tents or anything
  10. Dec 12, 2023 at 12:50 PM
    Danman34
    Danman34 New Member
    Danny
    Why not just get the ones for the tundra?
  11. Dec 12, 2023 at 12:52 PM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    because they’re over 4 grand and i got a deal on sequoia take offs
    Hella Krusty and Tom like this.
  12. Dec 12, 2023 at 12:55 PM
    Danman34
    Danman34 New Member
    Danny
    And why would the ones for the sequoia be any different?
  13. Dec 12, 2023 at 12:56 PM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    read this thread my friend ..the shocks are the same but the springs are a different height and load rate
    Ceezurin likes this.
  14. Dec 12, 2023 at 1:01 PM
    Danman34
    Danman34 New Member
    Danny
    I’m referring to the cost. The spring rate doesn’t affect the cost. Fox shocks are Fox shocks. If the tundra are $4k, the ones for the sequoia aren’t going to be any cheaper, if at all.
  15. Dec 12, 2023 at 1:05 PM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    they’re take offs on the used market not new ..
    my last question to Tom is are the strut towers the same ? the tree top thing don’t know what it’s called where the top of the strut 4 bolts go ??? can i use my hitachi SR5 top tower ?
    and i don’t need to change the upper control arms or bump stops or anything since im only going up 1.5”????
    beers on me
  16. Dec 12, 2023 at 1:36 PM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    oh hell yea great info ..so i should not install the pre load collar 1.5” lift which would then give me 2.6” total which is too much ..
    i will just use the sequoia trd pro shock and spring and that will get me a 1.1” lift in the front and i’m fine with that
    ryanwgregg likes this.
  17. Jan 2, 2024 at 5:15 AM
    CycleRacer250
    CycleRacer250 New Member
    Jay
    2023 tundra sr5
    Did you end up going through with the sequoia shocks? I have a 24 tundra sr5 and can pick up some sequoia trd pro shocks near by. Curious how much the front came up.
  18. Jan 2, 2024 at 6:52 AM
    xc_tc
    xc_tc New Member
    Is your truck a hybrid? The TRD Pro trucks are about 500 lbs heavier than the non-hybrid so you may get more lift than anticipated.
  19. Jan 2, 2024 at 7:10 AM
    Tom
    Tom New Member
    I don’t think he has a hybrid. Should be a limited and up trim. And the sequoia is a heavier vehicle
  20. Jan 2, 2024 at 8:51 AM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    SR5s don’t have the option of the hybrid engine to my understanding ..Non Hybrid
    I have not yet installed the suspension shops want close to a grand i’ll just do it myself when i get access to a lift and air tools unless someone on here has a garage i can rent near utah?? .plus i was waiting on my rims tires..
    going with a 18x9 raceline +18 offset with a set of recon grapplers 34.3” with a SL load rate at only 52 lbs..wanted to try to Falken wild peaks but they only make 10ply tires near 70lbs in anything over 33” which is overkill i feel on half tons that don’t tow heavy unless your in serious sharp rocks but fun fact of the day..
    I called Falken and they stated all their tires sidewalls are 2ply in essence on all tire models so the protection of 10 ply comes from just harder tread is my understanding ..
    but back to suspension ..I will install the Seqouia shocks with Seqouia springs..no UCAs or brake lines or bump stops or anything need to be changed i was told..these will automatically give me a 1.1” lift up front and slight lift in rear not sure how much .. i then bought a 1/4” top shim plate from Traxxda which will lift the front an extra 1/2” is what the said so that should put me at 1.6” lift in front fine by me..
    i can update this thread when i do it should be pretty soon
    CycleRacer250 likes this.
  21. Feb 6, 2024 at 9:09 PM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    suspension install 8 days away..i hope ryanwgregg is correct with that 1.1” lift from just the shock and my added 1/4” (1/2”) shim plate from Traxxda will give me a total lift of 1.6” in the front ..
    the rear TRD PRO sequoia reservoir shocks are longer than the fronts..im sure when they are under load they compress down to their sweet spot which hopefully is 1.5” lower than the front ride height ..yikes…rims/tires/ shocks going on next week i’ll update with pics IMG_0822.jpg
  22. Feb 15, 2024 at 5:39 PM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    That’s a big Fat Fing Negative ghostrider what the hell!!!!
    not only did it not raise it it lowered the front end like 3/4”!!!!
    the shocks are fine they are exactly the same but the springs are the problem here.. the shop did not put the Sequoia TRD PRO rear spring in because it was about an inch shorter than the stock SR5 Tundra rear spring ..they did install the front Sequoia shocks with the red TRD PRO springs and the 1/4” spacer up top and like i said i lost 1/2”-3/4” instead of gaining the 1.6” like i was told would happen ..talk about pissing money into the wind my god..this dude at the shop knows his stuff he just wasnt sure about the 1.1” gain from the shock ..not sure how ryan guy on here got that..i can’t the blame the people trying to help but yikes
    first pic is factory hitachi suspension with TRD 20s
    next is factory hitachi with tires/rims mounted
    next is after TRD PRO shock install
  23. Feb 15, 2024 at 5:45 PM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    so the final note here is if you can buy the shocks at a deal then do it but you might have to get some TRD PRO tundra springs or you could probably just add a 3/1 wescott lift and be good even with the sequoia springs potentially ..here i thought i’m done with the truck after my lightbar install ..negative gotta bust out the wallet once again ..
    buy spacers, buy springs not sure what would be best
  24. Feb 15, 2024 at 8:39 PM
    Tom
    Tom New Member
    Isn’t westcot designed based in Utah and did you ask them what spacers to use on this set up?
  25. Feb 15, 2024 at 8:48 PM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    negative i didn’t want the 3/1 wescott lift ..thought i could get 1.6 in the front just from the TRD PRO strut which was supposed to be 1.1” longer than stock shock and a 1/2” spacer lift ..
    now that 3/1 could come into play though that may solve it .. i was trying to avoid doing UCAs and everything else which should be done over 2” i was told
  26. Feb 16, 2024 at 11:00 AM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    the shocks are identical yes..the front spring is could be a tad shorter but don’t have a pic (i’ll get one soon) the rear is much shorter like 1”+ as seen in this pic here ..stock SR5 rear spring on left , TRD PRO Sequoia rear spring right..
    i bet you the spring rates are close enough if you use the wescott preload or whatever to achieve desired height it could work no problem ..
    i’m selling this set up if anyone is interested ..TRD pro front and rear shocks with the Sequoia TRD PRO springs 1500$ for it all ..it will come as a full front strut with the top tree so to install the wescott you’ll have compress spring take the top tree off before reassembling no big deal
  27. Feb 16, 2024 at 12:40 PM
    Hella Krusty
    Hella Krusty New Member
    I am not a suspension guy but can’t you just stuff the other spring back in?
  28. Feb 21, 2024 at 3:35 PM
    CycleRacer250
    Jay
    2023 tundra sr5
    For everyone’s awareness. I installed Pro shocks on my SR5 4x4. Gave about 2.25” in the front but may settle a tiny bit.
  29. Feb 21, 2024 at 5:54 PM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    copy confirmed thanks …. it’s the different size springs the TRD PRO SEQUOIA comes with that don’t give the tundra the proper lift without spacers or pre load collar … . the shocks are identical 2022 and up ..good looking SR5
  30. Mar 1, 2024 at 12:48 PM
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    Looks great! I'm thinking of this right now... what did you do about the rear spring? Did you get a new spring or spacer to match the front lift or left it stock? Also, did you take pre and post measurements of the front and rear?
    Luckydwg likes this.
