Installing Trd pro grille with AJT relocation bracket
Discussion in '2.5 Gen Tundras (2014-2021)' started by skip1980, Jun 13, 2021.
  1. Jun 13, 2021 at 11:14 AM
    skip1980
    skip1980 [OP] New Member
    Columbia, Missouri
    So I have a 18 Limited with TSS sensor. I am wanting to install a 2014-2017 TRD pro grille. I already installed the AJT bracket but still have my stock grille on. I wanted to see if I was going to get a bunch of error messages before I forked out the money on the grille. So I drove it and occasionally I get an error message for Pre collision malfunction clean sensor. But not very often. Does anybody know if it will go away once the TRD grille is installed? Because it kinda looks like the big emblem is blocking half of the sensor and the TRD grille looks more open so the sensir might be able to "see" better. Kinda hard to see but I took a picture.
    CamaroSsToTundra likes this.
  2. Jun 13, 2021 at 11:17 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    The AJT relocation bracket didn’t work for me with the 14-17 pro grill. Got errors all the time. I switched to the Jomax relocation bracket and haven’t had a problem since.
    I really think the thickness of the sensor cover is the problem with the ajt but some have said they do not have problems. It seems to be hit or miss
    Coachbuilder1 and Saltyhero13 like this.
  3. Jun 13, 2021 at 11:18 AM
    skip1980
    Columbia, Missouri
    I went on Jomax website and don't see brackets anymore. Do you know where I can purchase one at?
  4. Jun 13, 2021 at 11:34 AM
    shawn474
    MoCo, Maryland
    Not sure unless you can find one on the used market; you can try emailing them to see if they will make another run
  5. Jun 13, 2021 at 12:53 PM
    Kanekz
    Kanekz New Member
    Levi
    2019 1794 SC
    Jomax the way to go. I have a 2019 with the 17 trd pro and has never failed.
  6. Jun 13, 2021 at 2:31 PM
    skip1980
    Columbia, Missouri
    When did you buy it? Do you have a link where I can get one?
  7. Jun 13, 2021 at 3:31 PM
    shawn474
    MoCo, Maryland
    I bough mine a year ago…..you may want to contact them via their Facebook page or website to see if they are going to make any more
  8. Jun 13, 2021 at 3:36 PM
    skip1980
    Columbia, Missouri
    Anybody know why people have issues with the AJT one? It looks like a quality piece and fits very nicely. What's the thickness of the sensor cover on the Jomax one? I wonder if the cover on the AJT one is too thick?
  9. Jun 13, 2021 at 6:52 PM
    Rpmjr77
    Rpmjr77 New Member
    Rod
    2019 Crewmax Sr5
    I use the AJT with my 19. I installed a 19 TRD pro grill and bought a sensor cover from Amazon for $25 and haven’t had any problems. It’s been about 2 weeks.
  10. Jun 13, 2021 at 7:20 PM
    skip1980
    Columbia, Missouri
    I have a cement gray truck and don't think the 2019+ grille was available in cement.
  11. Jun 13, 2021 at 7:23 PM
    Cthulhu
    2020Platinum likes this.
  12. Jun 14, 2021 at 6:02 AM
    skip1980
    Columbia, Missouri
    I know you can't see it and it's minor but don't really want to modify grill or surround.
  13. Jun 14, 2021 at 6:24 AM
    Ne1tHeRe
    Ne1tHeRe New Member
    2021 Cement Tundra CrewMax Limited TRD Off-Road
  14. Jun 14, 2021 at 7:23 AM
    shawn474
    MoCo, Maryland
    Yes but by the time you get all of the needed accessories to complete the conversion, it is close to $1100.
    The 14-17 grill is a more affordable option with the relocation bracket.....you can try the AJT bracket. Some have had success using it.
  15. Jun 14, 2021 at 10:39 AM
    skip1980
    Columbia, Missouri
    Exactly. This is more than double the price of the 14-17 grill. Cement doesn't come from toyota in that color for the 19+ grill they paint it for you.
  16. Jun 14, 2021 at 10:46 AM
    shawn474
    MoCo, Maryland
    7F2B3E41-B48A-4073-9891-328BA4179716.jpg Again, I bought the 14-17 grill.....here is a picture. Total cost was around $425 with the hood bulge after coupons I had at the time
    Tundra805 and WonkyDonkey like this.
  17. Jun 14, 2021 at 10:53 AM
    skip1980
    Columbia, Missouri
    Yeah that's the route I plan on going but want to make sure I can get the tss sensor to work correctly with bracket before I pull the trigger.
  18. Jun 14, 2021 at 10:57 AM
    hitech
    hitech New Member
    Blair
    SOMD
    2018 CM TRD OR Limited
    I have that setup, 2018 Limited with 2014-2017 TRD Pro grill and AJT bracket. I have absolutely no issues and it's been on my truck over a year. Before the AJT bracket I had a homemade redneck bracket that worked fine as well, just wanted Adam's bracket because it was much better quality.
  19. Jun 14, 2021 at 11:00 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  20. Jun 14, 2021 at 11:25 AM
    skip1980
    Columbia, Missouri
    I'm not knocking the quality of the AJT bracket. It's very nice. But I occasionally get a message to clean sensor. Really want to make sure I can relocate it without errors before I spend the money on the grille. I was thinking about making a duplicate sensor cover out of a thinner polycarbonate plastic to see if that takes care of it. The cover is kinda thick I feel like.
    Tundra805 and Tundra_Curt like this.
  21. Jun 14, 2021 at 11:25 AM
    skip1980
    Columbia, Missouri
    I emailed Jomax and have not heard back yet.
  22. Jun 14, 2021 at 11:27 AM
    skip1980
    Columbia, Missouri
    Did you run the truck with the original grille and the sensor moved before putting the new grille on? I put the stock grille on just to make sure it was good before I go further.
    Ne1tHeRe likes this.
  23. Jun 14, 2021 at 12:23 PM
    Ne1tHeRe
    Ne1tHeRe New Member
    I ordered a newer TRD grille centerpiece from MC Autoparts but was still on the fence about grabbing a paint matched older grill w/ AJT relocating bracket.
    I have trouble making up my mind or which direction I want to go with…now kind of looking at the nightshade, too…haha
  24. Jun 14, 2021 at 12:41 PM
    skip1980
    Columbia, Missouri
    How was the fit and finish of the aftermarket one?
  25. Jun 14, 2021 at 1:40 PM
    Ne1tHeRe
    Ne1tHeRe New Member
    Not sure still in box just arrived last night. Will have to check and get back to you.
  26. Jun 14, 2021 at 7:33 PM
    CamaroSsToTundra
    CamaroSsToTundra New Member
    Ohio
    2018 Tundra
    I also have 2018 Tundra and I bought the Ajt Tss relocation bracket too. But that didn’t work for me either.
  27. Jun 14, 2021 at 7:45 PM
    skip1980
    Columbia, Missouri
    Still haven't heard from Jomax. Kinda annoying that AJT is selling something that seems to only work half the time. Also annoying that Jomax doesn't seem like they are making theirs anymore. It seems like theirs worked almost 100% of the time.
  28. Jun 15, 2021 at 8:45 AM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Thanks sharing the post John!… i’ve had several viewers do this now and not a single issue reported… Very easy to do and will work with any grille on the market… let me know if I can help!
    TSS Relocation On An Aftermarket Grille (2020 Toyota Tundra)
    https://youtu.be/rDTXe9eNAFg
  29. Jun 15, 2021 at 9:35 AM
    kylerocker10
    kylerocker10 New Member
    I also have a 2019 Cement Tundra with 2017 pro grille and ajt relocation bracket. Most of the time it’s fine but I definitely get more “clean sensor” errors than I did on the stock grille.
  30. Jun 15, 2021 at 9:55 AM
    Tundra_Curt
    Tundra_Curt New Member
    Curt
    2021 Tundra Limited CrewMax
    Just getting started...
    I have the same issue on my '21 CM. I added the 14-17 TRD PRO grille and color matched surround with the AJT relocation bracket. I get intermitte23CBBAFA-8F36-4594-BD2B-780D830F54E2_1_201_a.jpg nt errors to clean the sensor. It seems to clear itself with no other intervention but it drives me and my OCD nuts. We've had some heavier rains in the PNW lately and heavy rain correlates to the sensor errors. I read someone else here had a machinist fly cut the face of the bracket to make it thinner. I think the radar doesn't like the material the cover is made from.
    So at some point this summer, I'll take the grille off and either modify the face of the bracket to be thinner or make another face plate out of polycarbonate.
    I do like this PRO grille!!
    Tundra805 and Ne1tHeRe like this.
