Installing Matt Gecko’s LED lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by Shadowfax1, Sep 2, 2022.
  1. Sep 2, 2022 at 12:41 PM
    Shadowfax1
    Shadowfax1 [OP] New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    Good morning everyone
    I’m about to buy Matt Gecko’s LED strips for my 1794 bed. I want to install it so it comes on at the same time as door unlock/cargo light/remote unlock.
    Can anyone tell me how I would do that? I’m looking for specifics - what I would wire to what and how I would do that.
    Much appreciated.
  2. Sep 2, 2022 at 2:48 PM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    On my 2010 DC, the cargo light power was a thin, brown wire under the driver’s side door sill. (Didn’t wire my Gecko’s to that, but pulled power for undercarriage lighting from there without issue.) The color may be different on your year - you can check the diagrams posted elsewhere here to be sure.
    If you pull from there you won’t need to wire in the switch, as the cargo circuit will act as your switching mechanism. Then just connect your ground wire to an appropriate point.
    Shadowfax1[OP] and HulkSmurf14 like this.
  3. Sep 2, 2022 at 8:12 PM
    TravisJr
    TravisJr New Member
    Lots o’ mods
    Here you go. From the 2018 diagrams posted here under the Electrical subforum. Looks like yours will be either pink or grey with red stripe:
    Shadowfax1[OP] likes this.
  4. Sep 2, 2022 at 11:55 PM
    SFTundra
    SFTundra New Member
    Jimmy
    I wired my bed lights so that it turns on when I open my tailgate, and turns off when I close my tailgate which is the only time I’ll need it at night.
    I also made a switch to manually turn it off if I have my tail gate open hauling items and don’t want my lights on.
    Schaf and Shadowfax1[QUOTED][OP] like this.
  5. Sep 3, 2022 at 12:38 AM
    SFTundra
    SFTundra New Member
    Jimmy
    Also I noticed you’re in the Bay Area, I can give a helping hand or guidance if you’ll like to do the same set up as mine.
  6. Sep 9, 2022 at 12:16 PM
    Schaf
    Schaf New Member
    2021 CrewMax Limited
    @SFTundra
    How did you :
    "Wired my bed lights so that it turns on when I open my tailgate, and turns off when I close my tailgate which is the only time I’ll need it at night.
    I also made a switch to manually turn it off if I have my tail gate open hauling items and don’t want my lights on."
  7. Sep 9, 2022 at 12:40 PM
    SFTundra
    SFTundra New Member
    Jimmy
    The bare minimum you’ll need a magnetic switch.
    but if you want to override and turn it off while the tail gate is open while you are driving, you’ll need another switch as well. Here are the links where I bought it.
    magnetic switch
    https://www.amazon.com/gp/aw/d/B0009SUEZY?ref=ppx_pop_mob_b_asin_title
    Switch
    https://www.amazon.com/gp/aw/d/B076GYW4KX?ref=ppx_pop_mob_b_asin_title
    Lmk if you need help with the wiring diagram.
    SoCalRandy likes this.
  8. Sep 29, 2023 at 1:53 PM
    Ekelleyco
    Ekelleyco New Member
    CT
    2014 blue tundra SR5
    does the toggle switch keep the lights on regardless of tailgate position? For example if you were in the bed of the truck and wanted the lights on with tailgate up, would this accomplish that? Thanks
