Installing Low Range Off-road leveling kit in driveway with jacks?
Discussion in 'Suspension' started by Grant.B., Aug 13, 2018.
  1. Aug 13, 2018 at 7:53 PM
    Grant.B.
    Grant.B. [OP] New Member
    Grant
    2014 White crewmax 1794 Edition 4x4
    Does anyone think I can install a LRO 3/1 in my driveway using jacks
  2. Aug 13, 2018 at 7:55 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Well, jacks will probably only get you so far. At some point you'll need a few tools as well. :p
    831Tun and Grant.B.[OP] like this.
  3. Aug 13, 2018 at 7:56 PM
    Grant.B.
    Grant
    Well yeah. But do you think that is doable for lift the truck up
  4. Aug 13, 2018 at 7:59 PM
    Tundra101
    Tundra101 New Member
    ODee
    Upstate NY
    2017 Quicksand Tundra SR5 4X4
    Pro Comp 6” Lift
    It’s doable if you know what you’re doing.
  5. Aug 13, 2018 at 8:01 PM
    Sas
    OKC, OK
    I would think so, but I haven't done a lift yet. There's a lot going on when it comes to suspension, so I'm planning on having a pro install mine.
  6. Aug 13, 2018 at 8:02 PM
    Grant.B.
    Grant
    That's probably what I should do
    Sas[QUOTED] likes this.
  7. Aug 13, 2018 at 8:06 PM
    Tundra101
    ODee
    Upstate NY
    Pro Comp 6” Lift
    Most likely you will need this :)
    What’s your time frame?
    Grant.B.[OP] likes this.
  8. Aug 13, 2018 at 8:07 PM
    Grant.B.
    Grant
    Thanks I'll have to tell y'all how it goes
    831Tun and Sas like this.
  9. Aug 13, 2018 at 8:08 PM
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    Definitely doable. Just be safe about it. Make sure your jack stands are tall enough. AFF9A837-A5E5-4117-8C6F-9FCA4ADD4AFA.jpgD5F09AAB-0BBC-46C9-8477-A847DA369499.jpg
    equin, Sas and Grant.B.[OP] like this.
  10. Aug 13, 2018 at 8:08 PM
    Sas
    OKC, OK
    Good luck!
  11. Aug 13, 2018 at 10:04 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
