Installing Diode Dynamics LED fogs - zip ties?
Discussion in 'Lighting' started by IowaGuy, Jul 3, 2023.
  1. Jul 3, 2023 at 1:12 PM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
  2. Jul 3, 2023 at 1:24 PM
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    I actually didn't see movement when I first installed it, but maybe it was just me and that stretch of the road was bad, I "think" I "saw" very slight movement when bumpy, so I took both off and zip tie it, never saw movement again. Depends on how bad your OCD is, and if anything like mine, just zip-tie it "AFTER" you aim it and confirm it is good.
  3. Jul 7, 2023 at 8:32 AM
    Ghost Rider
    Ian
    Cypress, Texas
    The most difficult might be getting the wheel well piece out of the way so you can reach the original fog light, space can be tight so if you got big hands, might need to find someone with smaller hand to help.
  4. Jul 7, 2023 at 10:40 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    I thought it was more so the shrouds that were not very secure that people were tying up. I know I have significant play in mine that I've been too lazy to deal with.
  5. Jul 7, 2023 at 11:00 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Will they not fit into the OEM bracket?
    I haven't had OEM in years but I thought the OEM lamps came out of the brackets.
  6. Jul 7, 2023 at 11:05 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
  7. Jul 7, 2023 at 11:07 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    When I was researching fog light replacements years ago, it was mostly the resin bumper caps that had the vibration issues.
    Not so much the chrome bumper caps..
  8. Jul 7, 2023 at 11:11 AM
    Ghost Rider
    Ian
    Cypress, Texas
    Correct, aside from TRD PRO trim, which I believe uses BD as OE, other trims are merely plug and play (or swap and plug-in and turn-on_
    The housing is the same, if you have significant play, either the light is not secure, or the whole bumper piece is somehow loose.
    1lowlife[QUOTED] likes this.
  9. Jul 8, 2023 at 6:49 PM
    IowaGuy
    In Process
    UPDATE: I installed these lights today and it went well and just took a bit of finagling. I took the entire mount out from the front using a couple of plastic trim tools. There are two clips one top and one bottom that hold them. The new lights come with a new plastic mount that is square. The new mount also uses two bolts and nuts on each light to attach the mount to the light. The ligths and mount pooped back in and I needed to bent the metal clips inside the bumper end up just a bit to get it to catch. My install was made a bit more difficult because I have the ecological bumper caps. They are tight and not movement and no zip ties.
