Installing coils and shackles, is it really that bad?
Discussion in 'Suspension' started by MistrRoboto, Sep 8, 2017.
  1. Sep 8, 2017 at 12:00 PM
    MistrRoboto
    MistrRoboto [OP] '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    I did the suspension on my FJ about 10 years ago and given some tight spots and stuck bolts I remember it being a real pain in the ass. But - I just watched a video on the Tundra and it seems so damn easy - is it?
    Going to summarize a bit but it seemed almost like it should take no longer than 2 hours...
    Front
    -Jack it up
    -Remove skid
    -Remove front wheels/tires
    -Remove swaybar
    -Loosen LCA bolts optional
    -Remove steering knuckle bolts
    -Remove lower shock mount nut/bolt
    -Remove upper shock mounts nuts
    -Slide out old coil
    -Slide in new coil
    Reverse and Repeat.
    Rear
    -Support diff
    -Remove rear shock
    -Put in new rear shock
    -Remove shackle bolts and slide out
    -Put in new shackles
    Reverse and Repeat.
    You guys mostly do this yourselves or take to a shop?
    -Jim
  2. Sep 8, 2017 at 12:08 PM
    MistrRoboto
    Virginia Beach, VA
    Yeah - thats basically the reason for my post. Its much spookier going to the wife for $1400 than it is for $850 and a few hours.
    GNTundra likes this.
  3. Sep 8, 2017 at 12:21 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    :thumbsup:
    Eclipsed & Floating and GNTundra like this.
  4. Sep 8, 2017 at 12:24 PM
    MistrRoboto
    Virginia Beach, VA
    My Christmas list this year will he short, sweet, and expensive. Goal is to get each family member to buy one of the suspension components in my list.
  5. Sep 8, 2017 at 12:31 PM
    TheBeast The Beach
    rear can be done at home. Front it depends if you run into issues it's nice to have access to shop tools/lift.
  6. Sep 8, 2017 at 12:55 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    I just did mine and it wasn't difficult. Time consuming, yes. Difficult, no. I did have to cut out one of the UCA bolts but a replacement from the dealer was easy to get.
    Passenger side UCA bolt is easier to remove if you pop a couple of the wire clips in the engine bay. You will have to twist it around some of the wire bundles to get it out. On the driver side, pull the battery. You'll have way more room.
    You can skip removing the knuckle bolts. If you undo the sway bay at both ends, you'll have enough play to slid the new c/o in. It will take a little bit of effort.
    If I were to do the rears again, I would remove the shock, then the leaf, then lower the rear axle a bit to make it easier to slide in a new leaf. I didn't do that and the Deavers were a work out to wrestle into place. The stock shackle is two pieces. I had to bang on the leaf a bit to knock it loose once I removed the nuts.
    I did the fronts in an afternoon (about 4 hours) then did the rears the next morning. The rears were way faster.
  7. Sep 8, 2017 at 1:02 PM
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
    MRobot. Aren't you in the virginia beach area. If so I'll be in and out of there for work Oct thru Jan. Would gladly assist for the experience alone, if my schedule allows it of course.
    MistrRoboto[OP] and GNTundra like this.
  8. Sep 9, 2017 at 9:46 AM
    nowayout
    nowayout New Member
    NY
    15 Dbl
    @MistrRoboto can you post a link to the install video you mentioned in the op?
  9. Sep 9, 2017 at 1:31 PM
    dejabrown
    dejabrown New Member
    Dave
    Gilbert, AZ
    2010 Crew Max Platinum
    Backflip cover, OME suspension, Smittybuilt M1 rear bumper, Move front bumper
    thanks for the encouragement. Good to know its not that bad. I need to do mine...
    smslavin likes this.
  10. Sep 9, 2017 at 2:34 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    :rofl::rofl::rofl::rofl: Two hours???
    I wish!!
    Front is easy to figure out, but very time consuming. I would plan for at least 4-5 hours, the rear should only take you an hour or two. So easy.
    Don't forget the alignment after!
    Eclipsed & Floating likes this.
  11. Sep 9, 2017 at 2:46 PM
    Yikes im fixing to do UCAs n new struts soon on my own...im scared...
