Installing aftermarket fogs to oem fog light harness
Discussion in '2.5 Gen Tundras (2014-2021)' started by Torian13, May 2, 2021.
  1. May 2, 2021 at 7:01 PM
    Torian13
    Torian13 [OP] New Member
    2019 Tundra XSP
    Replacing stock bumper with an NFAB RSP. I am wanting to leave the oem fog light harness and purchase and install aftermarket fog lights using the oem hardware. Who has done this? Trying to avoid cutting and ruining a sturdy harness
  2. May 2, 2021 at 7:07 PM
    Which ones are you trying to install?
  3. May 2, 2021 at 7:13 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    I did this with my Baja design fogs. I wanted to save a spot on my trigger system and didn’t see a need to dim the fogs. It’s pretty straight forward just remove the female end of your harness and the wires from your existing fogs, test your polarity to ensure you have positive to positive and connect.
  4. May 2, 2021 at 7:34 PM
    Torian13
    2019 Tundra XSP
    Haven’t decided. Preferably one that can be mounted to the tube on the RSP via clamp on hardware, amber, and equipped with the female end of the Toyota oem harness lol
  5. May 2, 2021 at 7:40 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  6. May 2, 2021 at 7:50 PM
    cctxquicksand
    ^ if your not in a hurry this is the way
  7. May 2, 2021 at 9:52 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    @Torian13 If the light you are using has a Deutsch connector (most Rigids have them) this would be the way to go.
    I used to make adapters before they became aftermarket available and @TRDFerguson link is pretty much what I used to make.
    234016AF-1142-44F3-BE2C-CBD1E7894B24_zps_602c8c96f9be50865c81792939969a4fd05dc314.jpg
    If you don't need the Deutsch connector, these are what I used to use to make my adapters..
    Just test your hot and ground on your fog lights..
    Amazon.com: uxcell 5pcs 16AWG DC 12V H11 Headlight Bulb Male Wire Harness Connector Socket Adapters: Automotive
    Be careful taking the panel off to access the fog lights.
    The clips will break if you force them..
    63teqgkc_zpsiuulkvy3_4560290e6188c0c16c7645ea1fc1b940b2a710d9.jpg w1bin1u5_zpsbea9ponj_4adbcb7ceeae5a41a496ac45e7aad4935d472ab8.jpg
    TRDFerguson[QUOTED] likes this.
  8. May 2, 2021 at 10:31 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    This is the exact setup I have with the Baja Designs SAE fogs and the RSP bumper. I used Baja’s adapter to connect the lights to the stock fog harness. I tried one of the brackets to attach to the nfab bar under the headlights but did not like how everything was mounted to I had some trick tabs welded to the bumper.
  9. May 3, 2021 at 3:21 AM
    Torian13
    2019 Tundra XSP
    Thanks everyone for the replies.
  10. May 3, 2021 at 3:22 AM
    Torian13
    2019 Tundra XSP
    that’s exactly what I’m going for. Looks great man
  11. Sep 7, 2021 at 8:39 AM
    ab1653
    ab1653 Ew member
    TX
    2014 Tundra
    Do you have a picture of where the tabs were welded? I’m looking to do something very similar with some pods
  12. Sep 7, 2021 at 12:30 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    The tabs are welded to the top bar that is in the back. The lights are mounted hanging from the tabs.
    batman900 likes this.
  13. Sep 7, 2021 at 2:08 PM
    ab1653
    ab1653 Ew member
    TX
    2014 Tundra
    Awesome. Thank you for posting the pictures.
    sr5shark[QUOTED] likes this.
